Although I have built Optix 5.1 successfully, I am not able to run some of the SDK examples. For example, optixMotionBlur.
See:
[ 97%] Built target primeMultiGpu
[ 98%] Linking CXX executable ../bin/primeMultiBuffering
[ 98%] Built target primeMultiBuffering
[100%] Linking CXX executable ../bin/primeSimplePP
[100%] Built target primeSimplePP
$ cd bin
$ ./optixDeviceQuery
OptiX 5.1.1
Number of Devices = 1
Device 0 (0000:26:00.0): Quadro M2000
Compute Support: 5 2
Total Memory: 4236902400 bytes
Clock Rate: 1162500 kilohertz
Max. Threads per Block: 1024
SM Count: 6
Execution Timeout Enabled: 1
Max. HW Texture Count: 1048576
TCC driver enabled: 0
CUDA Device Ordinal: 0
Constructing a context...
Created with 1 device(s)
Supports 2147483647 simultaneous textures
Free memory:
Device 0: 4045930496 bytes
$ ./optixMotionBlur
No animation specified; using default translation of (0.1, 0, 0) times scene scale
OptiX Error: 'Unknown error (Details: Function "RTresult _rtBufferCreateFromGLBO(RTcontext, unsigned int, unsigned int, RTbuffer_api**)" caught exception: Encountered a CUDA error: cuGLGetDevices returned (304): Operating system call failed
Backtrace:
(0) () +0x711f17
(1) () +0x7102cb
(2) () +0x321a7f
(3) () +0x19eb43
(4) rtBufferCreateFromGLBO() +0x5b1
(5) createBufferImpl(optix::Handle<optix::ContextObj>, RTformat, unsigned int, unsigned int, bool, RTbuffertype) +0xea
(6) sutil::createOutputBuffer(optix::Handle<optix::ContextObj>, RTformat, unsigned int, unsigned int, bool) +0x40
(7) createContext(int) +0x223
(8) main() +0x287
(9) __libc_start_main() +0xe7
(10) _start() +0x2a
If rtBufferCreateFromGLBO fails that is a sign for no proper NVIDIA OpenGL implementation being found by the application to do the OpenGL interoperabilty for the output buffer for faster display of the result.
That your system reports a CUDA error that cuGLGetDevices fails indicates that as well.
You would either need to install a compatible NVIDIA OpenGL driver to allow that fast display of the output buffer or disable the OpenGL interop inside the application. For the latter, search this forum for rtBufferCreateFromGLBO or use the -h or --help command on the examples to find the necessary command line option.
Regarding the Nvidia OpenGL driver, I have installed the following packages
$ dpkg -l | grep mesa-*
ii libegl-mesa0:amd64 18.0.5-0ubuntu0~18.04.1 amd64 free implementation of the EGL API -- Mesa vendor library
ii libegl1-mesa:amd64 18.0.5-0ubuntu0~18.04.1 amd64 transitional dummy package
ii libegl1-mesa-dev:amd64 18.0.5-0ubuntu0~18.04.1 amd64 free implementation of the EGL API -- development files
ii libgl1-mesa-dev:amd64 18.0.5-0ubuntu0~18.04.1 amd64 free implementation of the OpenGL API -- GLX development files
ii libgl1-mesa-dri:amd64 18.0.5-0ubuntu0~18.04.1 amd64 free implementation of the OpenGL API -- DRI modules
ii libgl1-mesa-glx:amd64 18.0.5-0ubuntu0~18.04.1 amd64 transitional dummy package
ii libglapi-mesa:amd64 18.0.5-0ubuntu0~18.04.1 amd64 free implementation of the GL API -- shared library
ii libgles2-mesa-dev:amd64 18.0.5-0ubuntu0~18.04.1 amd64 free implementation of the OpenGL|ES 2.x API -- development files
ii libglu1-mesa:amd64 9.0.0-2.1build1 amd64 Mesa OpenGL utility library (GLU)
ii libglu1-mesa-dev:amd64 9.0.0-2.1build1 amd64 Mesa OpenGL utility library -- development files
ii libglx-mesa0:amd64 18.0.5-0ubuntu0~18.04.1 amd64 free implementation of the OpenGL API -- GLX vendor library
ii libwayland-egl1-mesa:amd64 18.0.5-0ubuntu0~18.04.1 amd64 implementation of the Wayland EGL platform -- runtime
ii mesa-common-dev:amd64 18.0.5-0ubuntu0~18.04.1 amd64 Developer documentation for Mesa
ii mesa-utils 8.4.0-1 amd64 Miscellaneous Mesa GL utilities
ii mesa-utils-extra 8.4.0-1 amd64 Miscellaneous Mesa utilies (opengles, egl)
ii mesa-va-drivers:amd64 18.0.5-0ubuntu0~18.04.1 amd64 Mesa VA-API video acceleration drivers
ii mesa-vdpau-drivers:amd64 18.0.5-0ubuntu0~18.04.1 amd64 Mesa VDPAU video acceleration drivers
As a summary, the OpenGL version is
$ glxinfo | grep "OpenGL version"
OpenGL version string: 3.0 Mesa 18.0.5
What is that exactly? Can I obtain that from nvidia website?
I can’t help much with Linux driver specific questions myself.
The NVIDIA display driver download search page is this: [url]https://www.nvidia.com/Download/Find.aspx?lang=en-us[/url]
If the CUDA driver (with support for CUDA 9.0 or higher, see the release notes of OptiX and your driver version) works on your system, disabling OpenGL interop buffers inside the application with the command line option --nopbo available in most OptiX SDK examples should be enough to get things going without updating drivers.
The optixConsole example inside the OptiX SDK should just work in that case, because it only prints ASCII characters.
Thank you. The “-n | --nopbo” fixes that at the moment.
