This function compiles fine with PTX but fails with Optix-IR. Specifically it fails on this line:
float inv_dim_x = 1.0f / (float)dim.x;
The only thing I changed is -optix-ir instead of -ptx
I am using sm_86 on cuda 13.1 and optix 9.0
It fails when I call optixModuleCreate
My raygen program that calls computeRay will end up with 0 instructions
static forceinline device void
computeRay(uint3 idx, uint3 dim, float3 &origin, float3 &direction) {
const float3 U = params.cam_u;
const float3 V = params.cam_v;
const float3 W = params.cam_w;
// Use reciprocal multiplication instead of division
float inv_dim_y = 1.0f / (float)dim.y;
float u = 2.0f * (float)idx.x * inv_dim_x - 1.0f;
float v = 2.0f * (float)idx.y * inv_dim_y - 1.0f;
origin = params.cam_eye;
// Compute direction
float3 dir;
dir.x = u * U.x + v * V.x + W.x;
dir.y = u * U.y + v * V.y + W.y;
dir.z = u * U.z + v * V.z + W.z;
// Normalize
float len = sqrtf(dir.x * dir.x + dir.y * dir.y + dir.z * dir.z);
float inv_len = 1.0f / len;
direction = make_float3(dir.x * inv_len, dir.y * inv_len, dir.z * inv_len);
EDIT:
Here is a reproduction, please check the README for build instructions
optix_ir_bug_repro.zip (8.8 KB)
You can actually toggle the reproduction step with this minimal raygen
this will not error:
// BUG TRIGGER: These division operations cause OptiX IR JIT to fail
float inv_dim_x = 1.0f; // / (float)dim.x;
direction = make_float3(inv_dim_x, 0.f, 0.f);
this will:
build steps
mkdir build && cd build
cmake .. -G “Visual Studio 17 2022” -DUSE_OPTIX_IR=ON
cmake --build . --config Release
Release\optix_ir_bug_repro.exe
^^ fails
cmake .. -G “Visual Studio 17 2022” -DUSE_OPTIX_IR=OFF
^^ works
my system info:
| NVIDIA-SMI 591.44 Driver Version: 591.44 CUDA Version: 13.1 |
| GPU Name Driver-Model | Bus-Id Disp.A | Volatile Uncorr. ECC |
| | | MIG M. |
| 0 NVIDIA GeForce RTX 3060 … WDDM | 00000000:01:00.0 Off | N/A |
| N/A 62C P0 752W / 60W | 0MiB / 6144MiB | 0% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| No running processes found |
Windows version
systeminfo | findstr /B /C:“OS Name” /C:“OS Version”
OS Name: Microsoft Windows 11 Pro
OS Version: 10.0.26200 N/A Build 26200
CUDA version
nvcc --version
Copyright (c) 2005-2025 NVIDIA Corporation
Built on Fri_Nov__7_19:25:04_Pacific_Standard_Time_2025
Cuda compilation tools, release 13.1, V13.1.80
Build cuda_13.1.r13.1/compiler.36836380_0
-- The CXX compiler identification is MSVC 19.44.35221.0
