ORIN AGX with custom board - HDMI not working
Dear Nvidia Team
We are testing the Orin AGX from the DevKit with our custom carrier board. Our board has a HDMI instead of a DP interface. Therefore we applied the DTSI file to Enable HDMI on Jetson AGX Orin Custom Carrier Boards. Furthermore we would need to swap HDMI lanes of the ORIN as we are able with the AGX Xavier using the device tree property nvidia,xbar-ctrl under the sor node. Is this possible with the ORIN? We have not found yet a similar setting to do this.
Thank you for your support.
That is no longer possible in Orin. Please make sure you have a correct hardware design follow up with design guide.
