I see that many people asking the same question but no solution or reason,I know reflash can be the solution but it will cover everything,so I wonder if overlay_mb1bct_36.x.tbz2 can be the solution?Or have you findout anything with the problem of can’t find partuuid?Both devkit and custom board
Hello @MaxineZ
Could you share your JetPack version, boot media (eMMC/NVMe/SD), and the flashing method or command used?
It may be worth comparing your process against this flashing guide:
Feel free to contact us for more details.
Felipe Solano
Embedded SW Engineer at RidgeRun
Contact us: support@ridgerun.com
Developers wiki: https://developer.ridgerun.com
Website: www.ridgerun.com
Mostly found in Jetpack6.2,boot with nvme,and I backup an image to recover with all the other boards.I’m sorry that I can’t open the link
And I found that uuid is mentioned in extlinux.conf default,can I change to other option such as /dev/nvmexxx
Do you use the l4t_backup_restore.sh scripts?
If no, please tell me how do you do backup restore?
Yes,and always do like this in this few years,but recently the problem occur frequently
What are the configuration differences between the working setup and the one that failed? Specifically:
Are you using a different BSP version?
Are you using a different NVMe drive?
I think maybe mostly found in Jetpack6.2 because it never happened when using Jetpack5.1.4,after we update to JP5.1.5 and JP6.2 that cause a lot of problem,the problem of can’t find uuid mostly found in this few month but it maybe happened before we realized.Others always the same,how to backup,how to recover,how to use orin,what kind of nvme ssd we use,these are always the same
Anyone can help?I feel so confused about this
Since JetPack 6.2 is already the latest version. Could you capture the full serial console (UART) log while you run the backup/restore, and continue capturing through the boot attempt that hits the “can’t find PARTUUID” error? Please also share the exact l4t_backup_restore.sh commands you use. That will let us pin down where the PARTUUID is getting lost.
