I am using orin nano developer kit for integrating a camera sensor. Here I am finding an issue while trying to stream via argus application, i.e using calculated pixel clock value(resolution*fps) I can able to get the stream in cam1 port but with the same value I cannot get the stream in cam0 port. And I have even tried with many other pixel clock values that is by using other calculation methods that you have given in the developer guide, even then I could not get the stream via argus application only in cam0. Below is the calculation method I have followed.
pixel_clk_hz` = sensor output size Ă— frame rate
= (4072 * 3176)*12
= 155192064
is there anything I am missing or I need to handle specifically?
hello naveenkumar.kamalakannan,
please note that there’s lane polarity, CSI0 D1 and CSI1 D0 P/N will always been swizzle for P/N.
hence, please review the sensor device tree, you may configure lane_polarity for a polarity swap on any lane.
you may see-also reference driver, such as tegra234-camera-rbpcv2-imx219.dtsi to configure the polarity settings.
thanks
Hi JerryChang
Thank you for your response.
Yes I have seen that lane_polarity parameter and I have already enabled it in my sensor device tree, here I can able to get the stream via V4L2 in cam0 port, the issue is I cannot able to get the stream via argus_application. When I start the stream with argus_application I can only able to see black screen in cam0 port and I am not even getting any logs in the dmesg, but with V4L2 it works fine.
may I know the kernel failure messages when you start the stream with argus_application?
besides, please also putting argus daemon in the foreground to obtain Argus daemon logs,
for example,
$ sudo su
# pkill nvargus-daemon
# nvargus-daemon
or.. # nvargus-daemon 2>&1 | tee argus-output.log
Hi JerryChang
Below you can find the logs of nvargus-daemon log, trace log and dmesg log .
nvargus-daemon log :
port0_argus-output.log (3.2 KB)
trace log:
port0_trace.log (6.5 KB)
dmesg log:
port0_dmesg.log (543 Bytes)
according to the failure,
there’s timeout for waiting frame-start, it doubts sensor did not output frames to CSI channel.
since you’re able to fetch the stream by v4l standard ioctl. you may examine the settings within tegra-camera-platform{}.
BTW,
how you connect these cam0 and cam1 camera sensors, are you using a customize carrier board?
Hi JerryChang
- Yes I have examined the
tegra-camera-platform{}, I think it’s almost correct, below you can find those settings that I have used in my sensor device tree.
tcp: tegra-camera-platform {
compatible = “nvidia, tegra-camera-platform”;
num_csi_lanes = <4>;
max_lane_speed = <1500000>;
min_bits_per_pixel = <10>;
vi_peak_byte_per_pixel = <2>;
vi_bw_margin_pct = <25>;
max_pixel_rate = <160000>;
isp_peak_byte_per_pixel = <5>;
isp_bw_margin_pct = <25>;
modules {
cam_module0: module0 {
status = “okay”;
badge = “eimx485_front_0485”;
position = “front”;
orientation = “1”;
cam_module0_drivernode0: drivernode0 {
pcl_id = “v4l2_sensor”;
devname = “e-con_cam 9-0042”;
proc-device-tree = “/proc/device-tree/cam_i2cmux/i2c@0/eimx485_a@42”;
status = “okay”;
cam_module1: module1 {
badge = “eimx485_rear_0485”;
position = “rear”;
orientation = “1”;
cam_module1_drivernode0: drivernode0 {
devname = “e-con_cam 10-0042”;
proc-device-tree = “/proc/device-tree/cam_i2cmux/i2c@1/eimx485_c@42”;
status = “okay”;
Note: With this settings I can able to get the stream via argus application for cam1.
- No I am not using any custom carrier board, I am using only Nvidia’s Orin Nano developer kit
Hi JerryChang
Is there any update on this?
Is there any update on this? We’re running into similar issues trying to sync cameras.
please also contact with sensor vendor since you’re using camera module from e-con team.
