核心板是ORIN NX 16GB,jetpack版本为5.1.2,间歇性出现NETDEV WATCHDOG: eth1 (r8168): transmit queue 0 timed out
Continuing the discussion from Ethernet Disconnects with "r8168: eth0: link up" Message in kern.log During Deep Stream RTSP Streaming:
我们也遇到了transmit queue 0 timed out的情况 :
Mar 19 12:48:37 node-101-12 kernel: [14196.645033] ------------[ cut here ]------------
Mar 19 12:48:37 node-101-12 kernel: [14196.649862] NETDEV WATCHDOG: eth1 (r8168): transmit queue 0 timed out
Mar 19 12:48:37 node-101-12 kernel: [14196.649906] WARNING: CPU: 6 PID: 0 at net/sched/sch_generic.c:467 dev_watchdog+0x3b4/0x3c0
Mar 19 12:48:37 node-101-12 kernel: [14196.658440] Modules linked in: veth xt_nat xt_tcpudp xt_multiport xt_conntrack xt_MASQUERADE nf_conntrack_netlink nfnetlink iptable_nat nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 xt_addrtype iptable_filter br_netfilter fuse nvidia_modeset(OE) md5 tcp_diag inet_diag lzo_rle lzo_compress zram overlay ramoops reed_solomon 8021q garp mrp loop nvgpu r8168 aes_ce_blk crypto_simd cryptd snd_hda_codec_hdmi snd_soc_tegra210_adsp aes_ce_cipher snd_hda_tegra ghash_ce snd_hda_codec snd_soc_tegra186_asrc sha2_ce snd_soc_tegra210_ope snd_soc_tegra210_mvc snd_soc_tegra186_dspk nvadsp snd_soc_tegra210_iqc snd_soc_tegra186_arad sha256_arm64 snd_soc_tegra210_adx snd_soc_tegra210_afc snd_soc_tegra210_dmic snd_soc_tegra210_admaif snd_soc_tegra_machine_driver snd_soc_tegra210_i2s snd_soc_tegra210_amx snd_soc_tegra210_mixer snd_soc_tegra210_sfc sha1_ce snd_hda_core snd_soc_tegra_pcm snd_soc_tegra_utils snd_soc_tegra210_ahub nvidia(OE) snd_soc_spdif_tx spi_tegra114 nv_imx219 pwm_fan
Mar 19 12:48:37 node-101-12 kernel: [14196.658601]  snd_soc_simple_card_utils tegra210_adma ina3221 fusb301 tegra_bpmp_thermal userspace_alert nvmap binfmt_misc drbd lru_cache libcrc32c ip_tables x_tables [last unloaded: mtd]
Mar 19 12:48:37 node-101-12 kernel: [14196.658641] CPU: 6 PID: 0 Comm: swapper/6 Tainted: G           OE     5.10.120-tegra #2
Mar 19 12:48:37 node-101-12 kernel: [14196.658644] Hardware name: Unknown NVIDIA Orin NX Developer Kit/NVIDIA Orin NX Developer Kit, BIOS 4.1-33958178 08/01/2023
Mar 19 12:48:37 node-101-12 kernel: [14196.658650] pstate: 60400009 (nZCv daif +PAN -UAO -TCO BTYPE=--)
Mar 19 12:48:37 node-101-12 kernel: [14196.658655] pc : dev_watchdog+0x3b4/0x3c0
Mar 19 12:48:37 node-101-12 kernel: [14196.658659] lr : dev_watchdog+0x3b4/0x3c0
Mar 19 12:48:37 node-101-12 kernel: [14196.658661] sp : ffff800010033d50
Mar 19 12:48:37 node-101-12 kernel: [14196.658664] x29: ffff800010033d50 x28: 0000000000000001
Mar 19 12:48:37 node-101-12 kernel: [14196.658671] x27: 0000000000000004 x26: 0000000000000140
Mar 19 12:48:37 node-101-12 kernel: [14196.658677] x25: ffff1cacbe15e680 x24: 00000000ffffffff
Mar 19 12:48:37 node-101-12 kernel: [14196.658683] x23: ffff1cacbdf503dc x22: ffffda99cbaf6000
Mar 19 12:48:37 node-101-12 kernel: [14196.658688] x21: ffff1cacbdf50000 x20: ffff1cacbdf50480
Mar 19 12:48:37 node-101-12 kernel: [14196.658694] x19: 0000000000000000 x18: 0000000000000000
Mar 19 12:48:37 node-101-12 kernel: [14196.658699] x17: 0000000000000000 x16: ffffda99c9e05220
Mar 19 12:48:37 node-101-12 kernel: [14196.658705] x15: ffff1cac80220570 x14: ffffffffffffffff
Mar 19 12:48:37 node-101-12 kernel: [14196.658710] x13: ffffda99cbe18de8 x12: ffffda99cbe18a38
Mar 19 12:48:37 node-101-12 kernel: [14196.658716] x11: 34203a6874676e65 x10: 0000000000000000
Mar 19 12:48:37 node-101-12 kernel: [14196.658721] x9 : 00000000fffffffe x8 : 756f2064656d6974
Mar 19 12:48:37 node-101-12 kernel: [14196.658727] x7 : 2030206575657571 x6 : c0000000ffffefff
Mar 19 12:48:37 node-101-12 kernel: [14196.658733] x5 : ffff1cafee837958 x4 : ffffda99cbb17a48
Mar 19 12:48:37 node-101-12 kernel: [14196.658738] x3 : 0000000000000001 x2 : ffff1cafee837960
Mar 19 12:48:37 node-101-12 kernel: [14196.658744] x1 : 0000000000000000 x0 : 0000000000000000
Mar 19 12:48:37 node-101-12 kernel: [14196.658749] Call trace:
Mar 19 12:48:37 node-101-12 kernel: [14196.658755]  dev_watchdog+0x3b4/0x3c0
Mar 19 12:48:37 node-101-12 kernel: [14196.658762]  call_timer_fn+0x3c/0x200
Mar 19 12:48:37 node-101-12 kernel: [14196.658766]  run_timer_softirq+0x50c/0x5e0
Mar 19 12:48:37 node-101-12 kernel: [14196.658771]  __do_softirq+0x140/0x3e8
Mar 19 12:48:37 node-101-12 kernel: [14196.658778]  irq_exit+0xc0/0xe0
Mar 19 12:48:37 node-101-12 kernel: [14196.658785]  __handle_domain_irq+0x74/0xd0
Mar 19 12:48:37 node-101-12 kernel: [14196.658788]  gic_handle_irq+0x68/0x134
Mar 19 12:48:37 node-101-12 kernel: [14196.658792]  el1_irq+0xd0/0x180
Mar 19 12:48:37 node-101-12 kernel: [14196.658800]  cpuidle_enter_state+0xb8/0x410
Mar 19 12:48:37 node-101-12 kernel: [14196.658805]  cpuidle_enter+0x40/0x60
Mar 19 12:48:37 node-101-12 kernel: [14196.658809]  call_cpuidle+0x44/0x80
Mar 19 12:48:37 node-101-12 kernel: [14196.658813]  do_idle+0x208/0x270
Mar 19 12:48:37 node-101-12 kernel: [14196.658816]  cpu_startup_entry+0x2c/0x70
Mar 19 12:48:37 node-101-12 kernel: [14196.658823]  secondary_start_kernel+0x14c/0x170
Mar 19 12:48:37 node-101-12 kernel: [14196.658826] ---[ end trace 8c85d3be61de1d2a ]---
Mar 19 12:48:40 node-101-12 Keepalived_vrrp[2840]: (VI_1) Entering MASTER STATE
Mar 19 12:48:41 node-101-12 kernel: [14200.719610] r8168: eth1: link up
项目中已有一定量的设备基于jetpack5.1.2版本在运行,升级有难度,请问这里面提到的针对 r8168的patch有适用于jetpack5.1.2版本的吗?
No, there is no patch ready, you need to do the comparison to know what changes to see if can back porting by youself. Thanks
