When running DeepStream, NETDEV WATCHDOG: eth0 (r8168): transmit queue 0 timed out
I’m running a DeepStream (version 6.3) application processing RTSP streams continuously on a Jetson Orin Nano 4GB device, and approximately once per day, randomly, I encounter the following error:
After this happens, the Ethernet briefly disconnects and reconnects (eth0: link up).
I’ve already tried troubleshooting based on similar discussions
(e.g., this forum post)
but the issue persists.
Here is my current environment:
  • Jetson Orin Nano Developer Kit (4GB)
  • JetPack: 5.1.2-b104 (Kernel version: 5.10.120-tegra)
  • Ethernet Driver (Realtek): r8168 version r8168 8.051.10m_pll-NAPI
  • DeepStream SDK: 6.3
Output from ethtool --show-eee eth0 shows EEE is currently enabled and active:
EEE status: enabled - active
  • TSO and GSO are already disabled:
tcp-segmentation-offload: off
generic-segmentation-offload: off [requested on]
Could you provide guidance on resolving or mitigating this error without upgrading JetPack to a newer version?
Specifically:
  • Is there a known issue or patch available for the r8168 driver on JetPack 5.1?
  • Would disabling EEE (sudo ethtool --set-eee eth0 eee off) help, or is there another recommended workaround?
Thank you for your assistance!
There is a known issue in r8168 driver:
Ethernet Disconnects with "r8168: eth0: link up" Message in kern.log During Deep Stream RTSP Streaming - #5 by WayneWWW
It is fixed in Jetpack 6.1 and 5.1.5. Would suggest upgrade to the version.
我们在Orin NX套件上同样遇到“NETDEV WATCHDOG: eth1 (r8168): transmit queue 0 timed out”问题,JetPack5.1.2【LT4 35.4.1】 内核版本:5.10.120-tegra,r8168版本r8168 8.051.10m_pll-NAPI,如何在不升级新Jetpack版本下解决这个问题或适合当前JetPack版本的补丁可用,感谢您的帮助!
The mentioned patch, can it be applied to JetPack 5.1.2? Where can I download the patch for Jetpack 5.1.2?
We would suggest upgrade to later Jetpack 5 release. If you have to stay in previous version, you may try to port the patches. Or use driver code of Jetpack 5.1.5 to apply to previous version for a try.
Jetpack 5.1.6?the latest version is 5.1.5…
Instead of upgrading the Jetpack version, we prefer to try applying the driver code to previous version. What should I do to port the patches, and is there any documentation??
The driver code is public. Please check the source to do the porting.
Commits for r35 are listed in
NETDEV WATCHDOG: eth1 (r8168): transmit queue 0 timed out - #8 by DaneLLL
