Orin NX flashing issue - cannot set terminal process group (-1): Inappropriate ioctl for device
I ran into an issue when flashing my Orin NX 16GB to Jetpack 6.1. I attached all the logs (from the flash command, console log during flash and after trying to boot the device). In short:
As per the instructions I started the process with:
 sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 -c tools/kernel_flash/flash_l4t_t234_nvme.xml -p '-c bootloader/generic/cfg/flash_t234_qspi.xml' --showlogs --network usb0 jetson-orin-nano-devkit internal
The process stops with:
/home/nvidia/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra
*  Step 3: Start the flashing process *
Waiting for target to boot-up...
Timeout
Device failed to boot to the initrd flash kernel. Please retrive the serial log during flashing to debug further.
Cleaning up...
on the console log on Orin NX I see:
[    4.897073] spi-nor spi0.0: mx25u51279g (65536 Kbytes)
[    5.916377] using random self ethernet address
[    5.916385] using random host ethernet address
[    5.919840] usb0: HOST MAC 96:b8:cf:21:8f:fb
[    5.919845] usb0: MAC 26:3b:04:bb:c7:71
[    5.921004] tegra-xudc 3550000.usb: EP 0 (type: ctrl, dir: out) enabled
bash: cannot set terminal process group (-1): Inappropriate ioctl for device
bash: no job control in this shell
bash-5.1# [GFX1-]: Managed to allocate after flush.
I tried many other things but with no luck. What could be wrong? The issue is the same when I use sdkmanager directly, it hungs at 99% but the underlying logs are the same.
Please let me know what needs to be done differently, I followed the instructions as per your documentation. The device was running ok with JP5 previously.
boot_log_after_flash.txt (32.6 KB)
console_log.txt (80.4 KB)
flash_log.txt (306.3 KB)
Some questions to confirm:
  • Is your Orin NX using a Orin Nano Developer Kit or other custom board?
  • Is your ubuntu running on a physical machine or a virtual machine (e.g. WSL, VirtualBox, VMware)
  • It is a yahboom board
  • physical machine + docker
thank you
Is your BSP from yahboom vendor or our download center?
If from our, please reach out to the yahboom vendor to get customized bsp.
