Orin NX no PWM output on PWM1
The pinmux has the PWM enabled as an output, the device tree has the peripheral enabled, but there is no output on the PWM pin.
28 (soc_gpio39_pn1):
        pull=0
        tristate=0
        enable-input=0
        open-drain=0
        io-reset=0
        rcv-sel=0
        io-hv=0
        loopback=0
        schmitt=0
        pull-down-strength=0
        pull-up-strength=0
        drive-type=0
        func=gp
We are using the 8gb Orin NX on JP 5.1.1
here is /sys/kernel/debug/pwm
platform/39c0000.tachometer, 1 PWM device
 pwm-0   ((null)              ): period: 0 ns duty: 0 ns polarity: normal
platform/32c0000.pwm, 1 PWM device
platform/32a0000.pwm, 1 PWM device
 pwm-0   (pwm-fan             ): requested enabled period: 45334 ns duty: 45333 ns polarity: normal
platform/3280000.pwm, 1 PWM device
 pwm-0   (sysfs               ): requested enabled period: 1000 ns duty: 500 ns polarity: normal
It doesn’t work on the devkit carrier board, let alone our custom carrier
Hi akhil.veeraghanta,
Are you using Orin Nano devkit(p3768) for Orin NX?
Please also help to provide the full dmesg for further check.
It ended up being the Req Initial State
setting it to high impedance broke it, when we set it to N/A the output came through
thanks!
