Hi, I’m trying to create an Image based OTA package for orin NX, I would like to know if this is supported
for this board since the documentation nor the scripts help messages mention it (for instance what name should
I use when the scripts require a board name such as here (step 7):
For the Orin-NX/Nano, since the r35.3 is the first public release, so we will support image-based OTA from r35.3 to r35.3+ in the next JP5.1.2 (r35.4).
What contents in rootfs you want to update?
There are some device trees and kernel image in rootfs too.
You could use backup/restore feature to update them only.
I’m looking to have a generic system for updating content on the rootfs, this could be adding configuration files or binaries. I want to avoid using apt or other package management to maintain a consistent state across devices and roll back atomically to the other partition if any component fails
From what I see in the documentation you link this method requires an external host in order to perform the restore so it’s not applicable in my case
