Good afternoon, I have made the following changes to the pinmux in the files I use to flash Orin NX modules:
GPIO #3, Set req initial state to drive 1
GPIO #6, Set Pin Direction to Input, req initial state to N/A
GPIO #12 Set Pin Direction to Output, Req initial state to Drive 1
CAM1_PWDN Change Req initial state to Z
GPIO #9 Change Pin Direction to bidirectional
I generate the following files with the excel sheet after making the above changes:
pinmux.dtsi
gpio.dtsi
padvoltage.dtsi
I then copy the padvoltage.dtsi and pinmux.dtsi files to the <l4t_top>/bootloader/t186ref/BCT/ directory and copy the gpio.dtsi file to the <l4t_top>/bootloader/ directory and edit the board conf file to point to those newly generated files
I then flash the Orin NX module inside the Xavier NX devkit using the following command:
This is using L4T 35.2.1 and JetPack 5.1 on Orin NX
Problem: After flashing with the above steps, I cannot access voltage and current readings that should be available through /sys/bus/i2c/drivers/ina3221/1-0040/hwmon/hwmon4/in1_input or /sys/bus/i2c/drivers/ina3221/1-0040/hwmon/hwmon4/curr1_input
Orin NX series have a 3-channel INA3221 power monitor at the 0x40 I2C address.
assume you’re able to read those before flashing the pinmux config, right?
could you please try $ sudo find / -name hwmon, and let’s check whether you still see voltage and current nodes under hardware monitor,
thanks
we may need the details of your repo steps.
for example,
there’re 4 sheets in Jetson_Orin_NX_series_and_Orin_Nano_series_Pinmux_Config_Template.xlsm.
do you use Jetson_Orin_NX_Series_+HDMI A03 for your target?
and…
had you also replaced the following lines with generated dtsi in p3509-a02+p3767-0000.conf? PINMUX_CONFIG=“tegra234-mb1-bct-pinmux-p3767-hdmi-a03.dtsi”; PMC_CONFIG=“tegra234-mb1-bct-padvoltage-p3767-hdmi-a03.dtsi”;
I used Jetson_Orin_NX_Series+HDMI A03 as my target and I modified the PINMUX_CONFIG and PMC_CONFIG names in the board.conf file to match those new dtsi files that were generated by the excel document.
I see this output when I do sudo dmesg | grep ina3221:
[ 12.540928] ina3221 1-0040: Unable to reset device
[ 12.545890] ina3221: probe of 1-0040 failed with error -110
I suspect I set some pins in the pinmux to unused that might effect this device? Is there any way for me to restore access to ina3221 without re-flashing?
ya… it may pin configuration to cause such issue, the software reset of the INA3221 has failed.
also, the error code… probe of 1-0040 failed with error -110. it means connection has timed out.
it’s device tree to apply the pin settings after kernel booting up. you may modify /boot/extlinux/extlinux.conf to specify FDT entry for updating this without re-flashing the target.
moreover,
you may disassembler the dtb file into text file, for example, $ dtc -I dtb -O dts -o output.dts tegra234-p3767-0000-p3768-0000-a0.dtb
please examine the node within…
i2c@c240000 {
ina32211_1_40: ina3221@40 {
it’s also able to convert the DTS into a new DTB file for quick testing
for example, $ dtc -I dts -O dtb -o output.dtb output.dts
