I have an orin nx dev kit that is getting a MIPI stream from an FPGA.
My FPGA is outputting 8 bits per component RGB888_24 stream. (2 Lanes)
However when I try to receive on the orin and save to a file using V4L2 as follows I get:
My device tree:
rbpcv2_imx219_c@10 {
compatible = "sony,imx219";
reg = <0x10>;
devnode = "video1";
physical_w = "3.680";
physical_h = "2.760";
sensor_model = "imx219";
use_sensor_mode_id = "true";
reset-gpios = <0x50 0xa0 0x00>;
phandle = <0x494>;
sensor-bpp = "24";
mode0 {
mclk_khz = "400000";
//mclk_khz = "24000";
num_lanes = "2";
tegra_sinterface = "serial_c";
phy_mode = "DPHY";
discontinuous_clk = "no";
dpcm_enable = "false";
cil_settletime = "0";
lane_polarity = "0";
active_w = "1920";
active_h = "1080";
pixel_t = "rgb_rgb88824";
// mode_type = "rgb";
//pixel_phase = "uyvy";
csi_pixel_bit_depth = "24";
//dynamic_pixel_bit_depth = "24";
readout_orientation = "0";
line_length = "1920";
inherent_gain = [31 00];
mclk_multiplier = "9.33";
//pix_clk_hz = "182400000";
//pix_clk_hz = "200000000";
pix_clk_hz = "66666667";
gain_factor = "16";
framerate_factor = "1000000";
exposure_factor = "1000000";
min_gain_val = "16";
max_gain_val = "170";
step_gain_val = [31 00];
default_gain = "16";
min_hdr_ratio = [31 00];
max_hdr_ratio = [31 00];
min_framerate = "2000000";
max_framerate = "30000000";
step_framerate = "1";
default_framerate = "30000000";
min_exp_time = "13";
max_exp_time = "683709";
step_exp_time = [31 00];
default_exp_time = "2495";
embedded_metadata_height = "0";
ports {
#address-cells = <0x01>;
#size-cells = <0x00>;
port@0 {
reg = <0x00>;
endpoint {
status = "okay";
port-index = <0x02>;
bus-width = <0x02>;
remote-endpoint = <0x2c8>;
phandle = <0x289>;
I calculated the following with 800 Mhz lane rate * 2 lanes / 24 bits per pixel = 66Mhz pixel clock
800 Mhz lane rate / 2 lane = 400 Mhz Mclk
However I get this error:
[ 142.077702] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 4194402
[ 142.110172] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 4194402
[ 142.142653] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 4194402
[ 142.175130] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 4194402
[ 142.207619] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 4194402
[ 142.240109] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 4194402
[ 142.272566] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 4194402
[ 142.305049] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 4194402
[ 142.337523] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 4194402
[ 142.370000] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 4194402
[ 142.383740] bwmgr API not supported
[ 142.481226] arm-smmu 10000000.iommu: Unhandled context fault: fsr=0x80000402, iova=0x7ffb2a4400, fsynr=0x600013, cbfrsynra=0xc04, cb=1
[ 142.497350] mc-err: unknown mcerr fault, int_status=0x00101000, ch_int_status=0x00000000, hubc_int_status=0x00000000 sbs_int_status=0x00000000, hub_int_status=0x00000000
And here is the output of tracing:
kworker/2:9-162 [002] .... 522.256687: rtcpu_nvcsi_intr: tstamp:16907611281 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:2 vc:0 status:0x00000004
kworker/2:9-162 [002] .... 522.256687: rtcpu_nvcsi_intr: tstamp:16907612221 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:2 vc:0 status:0x00000004
kworker/2:9-162 [002] .... 522.256687: rtcpu_nvcsi_intr: tstamp:16907612221 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:2 vc:0 status:0x00000004
kworker/2:9-162 [002] .... 522.256688: rtcpu_nvcsi_intr: tstamp:16907613161 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:2 vc:0 status:0x00000004
kworker/2:9-162 [002] .... 522.256688: rtcpu_nvcsi_intr: tstamp:16907613161 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:2 vc:0 status:0x00000004
kworker/2:9-162 [002] .... 522.256688: rtcpu_nvcsi_intr: tstamp:16907614101 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:2 vc:0 status:0x00000004
kworker/2:9-162 [002] .... 522.256688: rtcpu_nvcsi_intr: tstamp:16907614101 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:2 vc:0 status:0x00000004
kworker/2:9-162 [002] .... 522.256688: rtcpu_nvcsi_intr: tstamp:16907615040 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:2 vc:0 status:0x00000004
kworker/2:9-162 [002] .... 522.256689: rtcpu_nvcsi_intr: tstamp:16907615040 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:2 vc:0 status:0x00000004
kworker/2:9-162 [002] .... 522.256689: rtcpu_nvcsi_intr: tstamp:16907615980 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:2 vc:0 status:0x00000004
kworker/2:9-162 [002] .... 522.256689: rtcpu_nvcsi_intr: tstamp:16907615980 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:2 vc:0 status:0x00000004
kworker/2:9-162 [002] .... 522.256689: rtcpu_nvcsi_intr: tstamp:16907616919 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:2 vc:0 status:0x00000004
kworker/2:9-162 [002] .... 522.256689: rtcpu_nvcsi_intr: tstamp:16907616919 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:2 vc:0 status:0x00000004
kworker/2:9-162 [002] .... 522.256689: rtcpu_nvcsi_intr: tstamp:16907617859 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:2 vc:0 status:0x00000004
kworker/2:9-162 [002] .... 522.256690: rtcpu_nvcsi_intr: tstamp:16907617859 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:2 vc:0 status:0x00000004
kworker/2:9-162 [002] .... 522.256690: rtcpu_nvcsi_intr: tstamp:16907618799 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:2 vc:0 status:0x00000004
kworker/2:9-162 [002] .... 522.256690: rtcpu_nvcsi_intr: tstamp:16907618799 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:2 vc:0 status:0x00000004
kworker/2:9-162 [002] .... 522.256690: rtcpu_nvcsi_intr: tstamp:16907619739 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:2 vc:0 status:0x00000004
kworker/2:9-162 [002] .... 522.256690: rtcpu_nvcsi_intr: tstamp:16907619739 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:2 vc:0 status:0x00000004
kworker/2:9-162 [002] .... 522.256691: rtcpu_nvcsi_intr: tstamp:16907620679 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:2 vc:0 status:0x00000004
kworker/2:9-162 [002] .... 522.256691: rtcpu_nvcsi_intr: tstamp:16907620679 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:2 vc:0 status:0x00000004
kworker/2:9-162 [002] .... 522.256691: rtcpu_nvcsi_intr: tstamp:16907621618 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:2 vc:0 status:0x00000004
kworker/2:9-162 [002] .... 522.256691: rtcpu_nvcsi_intr: tstamp:16907621618 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:2 vc:0 status:0x00000004
kworker/2:9-162 [002] .... 522.256691: rtcpu_nvcsi_intr: tstamp:16907622558 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:2 vc:0 status:0x00000004
kworker/2:9-162 [002] .... 522.256692: rtcpu_nvcsi_intr: tstamp:16907622558 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:2 vc:0 status:0x00000004
kworker/2:9-162 [002] .... 522.256692: rtcpu_nvcsi_intr: tstamp:16907623497 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:2 vc:0 status:0x00000004
kworker/2:9-162 [002] .... 522.256692: rtcpu_nvcsi_intr: tstamp:16907623497 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:2 vc:0 status:0x00000004
kworker/2:9-162 [002] .... 522.256692: rtcpu_nvcsi_intr: tstamp:16907624437 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:2 vc:0 status:0x00000004
kworker/2:9-162 [002] .... 522.256692: rtcpu_nvcsi_intr: tstamp:16907624437 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:2 vc:0 status:0x00000004
kworker/2:9-162 [002] .... 522.256693: rtcpu_nvcsi_intr: tstamp:16907625377 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:2 vc:0 status:0x00000004
kworker/2:9-162 [002] .... 522.256693: rtcpu_nvcsi_intr: tstamp:16907625377 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:2 vc:0 status:0x00000004
kworker/2:9-162 [002] .... 522.256693: rtcpu_nvcsi_intr: tstamp:16907626317 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:2 vc:0 status:0x00000004
kworker/2:9-162 [002] .... 522.256693: rtcpu_nvcsi_intr: tstamp:16907626317 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:2 vc:0 status:0x00000004
kworker/2:9-162 [002] .... 522.256693: rtcpu_nvcsi_intr: tstamp:16907627256 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:2 vc:0 status:0x00000004
kworker/2:9-162 [002] .... 522.256694: rtcpu_nvcsi_intr: tstamp:16907627256 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:2 vc:0 status:0x00000004
kworker/2:9-162 [002] .... 522.256694: rtcpu_nvcsi_intr: tstamp:16907628196 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:2 vc:0 status:0x00000004
kworker/2:9-162 [002] .... 522.256694: rtcpu_nvcsi_intr: tstamp:16907628196 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:2 vc:0 status:0x00000004
kworker/2:9-162 [002] .... 522.256694: rtcpu_nvcsi_intr: tstamp:16907629135 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:2 vc:0 status:0x00000004
kworker/2:9-162 [002] .... 522.256694: rtcpu_nvcsi_intr: tstamp:16907629135 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:2 vc:0 status:0x00000004
kworker/2:9-162 [002] .... 522.256694: rtcpu_nvcsi_intr: tstamp:16907630075 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:2 vc:0 status:0x00000004
kworker/2:9-162 [002] .... 522.256695: rtcpu_nvcsi_intr: tstamp:16907630075 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:2 vc:0 status:0x00000004
kworker/2:9-162 [002] .... 522.256695: rtcpu_nvcsi_intr: tstamp:16907631015 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:2 vc:0 status:0x00000004
kworker/2:9-162 [002] .... 522.256695: rtcpu_nvcsi_intr: tstamp:16907631015 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:2 vc:0 status:0x00000004
kworker/2:9-162 [002] .... 522.256695: rtcpu_nvcsi_intr: tstamp:16907631955 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:2 vc:0 status:0x00000004
kworker/2:9-162 [002] .... 522.256695: rtcpu_nvcsi_intr: tstamp:16907631955 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:2 vc:0 status:0x00000004
kworker/2:9-162 [002] .... 522.256696: rtcpu_nvcsi_intr: tstamp:16907632894 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:2 vc:0 status:0x00000004
kworker/2:9-162 [002] .... 522.256696: rtcpu_nvcsi_intr: tstamp:16907632894 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:2 vc:0 status:0x00000004
kworker/2:9-162 [002] .... 522.256696: rtcpu_nvcsi_intr: tstamp:16907633834 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:2 vc:0 status:0x00000004
kworker/2:9-162 [002] .... 522.256696: rtcpu_nvcsi_intr: tstamp:16907633834 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:2 vc:0 status:0x00000004
kworker/2:9-162 [002] .... 522.256696: rtcpu_nvcsi_intr: tstamp:16907634774 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:2 vc:0 status:0x00000004
kworker/2:9-162 [002] .... 522.256697: rtcpu_nvcsi_intr: tstamp:16907634774 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:2 vc:0 status:0x00000004
kworker/2:9-162 [002] .... 522.256697: rtcpu_nvcsi_intr: tstamp:16907635713 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:2 vc:0 status:0x00000004
kworker/2:9-162 [002] .... 522.256697: rtcpu_nvcsi_intr: tstamp:16907635713 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:2 vc:0 status:0x00000004
kworker/2:9-162 [002] .... 522.256697: rtcpu_nvcsi_intr: tstamp:16907636648 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:2 vc:0 status:0x00000004
kworker/2:9-162 [002] .... 522.256697: rtcpu_nvcsi_intr: tstamp:16907636648 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:2 vc:0 status:0x00000004
v4l2-ctl-3158 [001] .... 522.256975: tegra_channel_set_power: 13e40000.host1x:nvcsi@15a00000- : 0x0
v4l2-ctl-3158 [001] .... 522.256979: csi_s_power: enable : 0x0
kworker/2:9-162 [002] .... 522.375894: rtcpu_vinotify_event: tstamp:16910791085 cch:-1 vi:1 tag:FE channel:0x00 frame:0 vi_tstamp:541145251776 data:0x0000000000000022
kworker/2:9-162 [002] .... 522.375897: rtcpu_vinotify_event: tstamp:16910791286 cch:-1 vi:1 tag:CHANSEL_SHORT_FRAME channel:0x04 frame:0 vi_tstamp:541145251776 data:0x0173200001000000
kworker/2:9-162 [002] .... 522.375897: rtcpu_vinotify_event: tstamp:16910791465 cch:-1 vi:1 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:541145251776 data:0x0000000800000000
The command I am trying to use to capture output is:
sudo v4l2-ctl --stream-mmap --stream-count=1 -d /dev/video1 --stream-to=test.raw
Any help here would be appreciated.
