I am using OrinNX L4T Version 35.5.0 Jetpack 5.1.3 I am getting issue of SCF Timeout error in between the livestream. Could you please suggest the root cause for this issue. I am facing this issue from the last few months but could not be able to find out the actual reason for this.
Here is the journalctl log below:
journalctl -u nvargus-daemon -f
– Logs begin at Thu 1970-01-01 00:00:40 UTC. –
Nov 14 12:57:25 orin nvargus-daemon[1119]: SCF: Error BadParameter: Sensor could not be opened. (in src/services/capture/CaptureServiceDeviceSensor.cpp, function getSourceFromGuid(), line 726)
Nov 14 12:57:25 orin nvargus-daemon[1119]: SCF: Error BadParameter: (propagating from src/services/capture/CaptureService.cpp, function addSourceByGuid(), line 453)
Nov 14 12:57:25 orin nvargus-daemon[1119]: SCF: Error BadParameter: (propagating from src/api/CameraDriver.cpp, function addSourceByIndex(), line 347)
Nov 14 12:57:25 orin nvargus-daemon[1119]: SCF: Error BadParameter: (propagating from src/api/CameraDriver.cpp, function getSource(), line 519)
Nov 14 12:57:25 orin nvargus-daemon[1119]: E/ libnvphs:socket: Error[2]: socket connection /var/lib/nvphs/nvphsd.ctl to PHS failed: No such file or directory
Nov 14 12:57:25 orin nvargus-daemon[1119]: D/ libnvphs:socket: Warning: connecting to Power Hinting Service failed. Is PHS running?
Nov 14 12:57:25 orin nvargus-daemon[1119]: === gst-launch-1.0[2765]: CameraProvider initialized (0xffffb46cc450)SCF: Error BadValue: NvPHSSendThroughputHints (in src/common/CameraPowerHint.cpp, function sendCameraPowerHint(), line 56)
Nov 14 12:57:25 orin nvargus-daemon[1119]: E/ libnvphs: Error: NvPHSSendThroughputHints[usecase=camera, hint=MinCPU, value=4294967295, timeout_ms=1000]: queue_or_send() failed
Nov 14 12:58:38 orin nvargus-daemon[1119]: Module_id 30 Severity 2 : (fusa) Error: InvalidState Status syncpoint signaled but status value not updated in:/capture/src/fusaIspHandler.cpp 848
Nov 14 12:58:38 orin nvargus-daemon[1119]: Module_id 30 Severity 2 : (fusa) Error: InvalidState propagating from:/capture/src/fusaIspHandler.cpp 770
Nov 14 12:58:38 orin nvargus-daemon[1119]: SCF: Error Timeout: FuSa Capture Status failed! (in src/services/capture/FusaCaptureIspHw.cpp, function waitIspFrameEnd(), line 365)
Nov 14 12:58:38 orin nvargus-daemon[1119]: SCF: Error ResourceAlreadyInUse: (propagating from src/services/capture/FusaCaptureIspHw.cpp, function startCaptureInternal(), line 139)
Nov 14 12:58:38 orin nvargus-daemon[1119]: SCF: Error ResourceAlreadyInUse: (propagating from src/services/capture/CaptureRecord.cpp, function doMEMtoISPCapture(), line 631)
Nov 14 12:58:38 orin nvargus-daemon[1119]: SCF: Error ResourceAlreadyInUse: (propagating from src/services/capture/CaptureRecord.cpp, function issueCapture(), line 495)
Nov 14 12:58:38 orin nvargus-daemon[1119]: SCF: Error ResourceAlreadyInUse: (propagating from src/services/capture/CaptureServiceDevice.cpp, function issueCaptures(), line 1530)
Nov 14 12:58:38 orin nvargus-daemon[1119]: SCF: Error ResourceAlreadyInUse: (propagating from src/services/capture/CaptureServiceDevice.cpp, function issueCaptures(), line 1359)
Nov 14 12:58:38 orin nvargus-daemon[1119]: Module_id 30 Severity 2 : (fusa) Error: ResourceAlreadyInUse All descriptors are already pending, no idle descriptors available in:/capture/src/fusaIspHandler.cpp 685
Nov 14 12:58:38 orin nvargus-daemon[1119]: Module_id 30 Severity 2 : (fusa) Error: ResourceAlreadyInUse propagating from:/capture/src/fusaIspHandler.cpp 401
Nov 14 12:58:38 orin nvargus-daemon[1119]: SCF: Error Timeout: (propagating from src/api/Buffer.cpp, function waitForUnlock(), line 644)
Nov 14 12:58:38 orin nvargus-daemon[1119]: SCF: Error Timeout: (propagating from src/components/CaptureContainerImpl.cpp, function returnBuffer(), line 426)
Nov 14 12:58:38 orin nvargus-daemon[1119]: SCF: Error ResourceAlreadyInUse: (propagating from src/common/Utils.cpp, function workerThread(), line 114)
Nov 14 12:58:38 orin nvargus-daemon[1119]: SCF: Error ResourceAlreadyInUse: Worker thread CaptureScheduler frameStart failed (in src/common/Utils.cpp, function workerThread(), line 133)
Nov 14 12:58:47 orin nvargus-daemon[1119]: SCF: Error Timeout: (propagating from src/services/capture/CaptureServiceEvent.cpp, function wait(), line 59)
Nov 14 12:58:47 orin nvargus-daemon[1119]: Error: Camera HwEvents wait, this may indicate a hardware timeout occured,abort current/incoming cc for sensor guid 1 count -1092955392
Nov 14 12:58:56 orin nvargus-daemon[1119]: SCF: Error InvalidState: 4 buffers still pending during EGLStreamProducer destruction (in src/services/gl/EGLStreamProducer.cpp, function freeBuffers(), line 300)
Nov 14 12:59:01 orin nvargus-daemon[1119]: waitForIdleLocked remaining request 3317
Nov 14 12:59:01 orin nvargus-daemon[1119]: waitForIdleLocked remaining request 3316
Nov 14 12:59:01 orin nvargus-daemon[1119]: waitForIdleLocked remaining request 3315
Nov 14 12:59:01 orin nvargus-daemon[1119]: waitForIdleLocked remaining request 3314
Nov 14 12:59:01 orin nvargus-daemon[1119]: SCF: Error Timeout: waitForIdle() timed out (in src/api/Session.cpp, function waitForIdleLocked(), line 969)
Your help would be highly appreciated.
Thanks in advance..
