OSError: [Errno 121] Remote I/O error
Hi all,
I’m facing an issue while running the basic_motion.pynb file on Jupyter Notebook. Specifically, the error occurs when I try to execute the following code cell:
robot = Robot()
As soon as I run this cell, an error pops up. I’ve attached a screenshot of the error for reference.
After checking the error path, I noticed that the directory mentioned in the error message (/usr/local/lib/python3.6/dist-packages/jetbot-0.4.1-py3.6.egg/jetbot/robot.py) does not exist on my system. When navigating to the path, the directory appears to be empty.
error:
/usr/local/lib/python3.6/dist-packages/jetbot-0.4.1-py3.6.egg/jetbot/robot.py in init(self, *args, **kwargs)
20 def init(self, *args, **kwargs):
21 super(Robot, self).init(*args, **kwargs)
—> 22 self.motor_driver = Adafruit_MotorHAT(i2c_bus=self.i2c_bus)
23 self.left_motor = Motor(self.motor_driver, channel=self.left_motor_channel, alpha=self.left_motor_alpha)
24 self.right_motor = Motor(self.motor_driver, channel=self.right_motor_channel, alpha=self.right_motor_alpha)
/usr/local/lib/python3.6/dist-packages/Adafruit_MotorHAT-1.4.0-py3.6.egg/Adafruit_MotorHAT/Adafruit_MotorHAT_Motors.py in init(self, addr, freq, i2c, i2c_bus)
229 self.motors = [ Adafruit_DCMotor(self, m) for m in range(4) ]
230 self.steppers = [ Adafruit_StepperMotor(self, 1), Adafruit_StepperMotor(self, 2) ]
→ 231 self._pwm = PWM(addr, debug=False, i2c=i2c, i2c_bus=i2c_bus)
232 self._pwm.setPWMFreq(self._frequency)
233
/usr/local/lib/python3.6/dist-packages/Adafruit_MotorHAT-1.4.0-py3.6.egg/Adafruit_MotorHAT/Adafruit_PWM_Servo_Driver.py in init(self, address, debug, i2c, i2c_bus)
57 self.i2c = get_i2c_device(address, i2c, i2c_bus)
58 logger.debug(“Reseting PCA9685 MODE1 (without SLEEP) and MODE2”)
—> 59 self.setAllPWM(0, 0)
60 self.i2c.write8(self.__MODE2, self.__OUTDRV)
61 self.i2c.write8(self.__MODE1, self.__ALLCALL)
/usr/local/lib/python3.6/dist-packages/Adafruit_MotorHAT-1.4.0-py3.6.egg/Adafruit_MotorHAT/Adafruit_PWM_Servo_Driver.py in setAllPWM(self, on, off)
93 def setAllPWM(self, on, off):
94 “Sets a all PWM channels”
—> 95 self.i2c.write8(self.__ALL_LED_ON_L, on & 0xFF)
96 self.i2c.write8(self.__ALL_LED_ON_H, on >> 8)
97 self.i2c.write8(self.__ALL_LED_OFF_L, off & 0xFF)
/usr/local/lib/python3.6/dist-packages/Adafruit_GPIO-1.0.4-py3.6.egg/Adafruit_GPIO/I2C.py in write8(self, register, value)
114 “”“Write an 8-bit value to the specified register.”“”
115 value = value & 0xFF
→ 116 self._bus.write_byte_data(self._address, register, value)
117 self._logger.debug(“Wrote 0x%02X to register 0x%02X”,
118 value, register)
/usr/local/lib/python3.6/dist-packages/Adafruit_PureIO-1.1.7-py3.6.egg/Adafruit_PureIO/smbus.py in write_byte_data(self, addr, cmd, val)
320 # Send the data to the device.
321 self._select_device(addr)
→ 322 self._device.write(data)
323
324 def write_word_data(self, addr, cmd, val):
I’ve attempted some initial troubleshooting but haven’t been able to resolve the issue. Has anyone encountered this problem before or can provide guidance on how to resolve it?
Any help would be greatly appreciated!
Duplicated with OSError: [Errno 121] Remote I/O error - Jetson & Embedded Systems / Jetson Orin Nano - NVIDIA Developer Forums.
