OTA update
I have some doubt on OTA update
Base_BSP = 36.4.0 and targer bsb= 36.5
Is any possible to update boot loader alone?
How to achieve?
In case same version of boot loader OTA update is possible?
like BASE_BSP - 36.5 and TARGET_BSP = 36.5
what about roots changes?
hello muralikrishnan.t,
please see-also developer guide, Update Bootloader.
you may create BUP payload for updating bootloader.
please visit L4T page, Jetson Linux Archive | NVIDIA Developer to download the [OTA Tools]
for instance,
$OUT/Linux_for_Tegra/tools/ota_tools/version_upgrade/Image_based_OTA_Examples.txt
l4t_generate_ota_package.sh also have the options (-b) to update bootloader only.
please check the readme file for the sample steps.
Hi Jerry,
The below command i used to create the boot loader update
sudo ROOTFS_AB=1 ./tools/ota_tools/version_upgrade/l4t_generate_ota_package.sh -b --external-device nvme0n1 jetson-orin-nano-devkit R36-4
After update device was not booting, refer the attachment.
error.txt (39.1 KB)
this looks strange, it’s the command-line to update bootloader only, however, you’ve ROOTFS_AB=1 included, which the options for root file system.
FYI, you cannot enable rootfs redundancy via OTA update.
is this target flashed with root file system redundancy enabled?
We enabled redundancy
may I know the source/target BSP version you’re trying to do bootloader update only?
we usually do bootloader update only on the same release version,
it should not supported due to there’re several releases, for example, there’re r36.4.3, r36.4.4, and then r36.5.0.
hence..
please have OTA update for moving forward to r36.5.0, and then having bootloader update only for your use-case.
Hi Jerry,
Thanks for your input and in case without partition change only bootloader and rootfs update is possible right?
what about rootfs update , this also expecting same version?
the Jetson image-based OTA design, the -r (rootfs only) and -b (bootloader only) OTA payload is only supported when you stay on the same BSP version and there no partition-layout change.
please use a full image-based OTA payload if you’re having cross-release upgrades, (such as 36.4.0 → 36.5)
so that it updates all required partitions, such as, firmware, kernel, and user-space…etc, all stay in a consistent release version.
Hi Jerry,
I have one doubt about exiting partition layouts, whether they also effect from OTA update?
My agent is no layout change only upgrade.
The Jetson image-based OTA design, the -r (rootfs only) and -b (bootloader only) OTA payload is only supported when you stay on the same BSP version and there no partition-layout change.
Above case the BASE and TARGET BSP path export is same right?
yes, that’s based-on the same BSP release.
What about partition? it will effect or not
what partition you’re mentioned above? please share your test steps and results for reference.
We enabled ROOTFS_AB support and user partition, After OTA any change in partition layout
you’ll use this partition layout for OTA update, it’ll not change the partitions.
${LINUX_BASE_DIR}/tools/kernel_flash/flash_l4t_t234_nvme_rootfs_ab.xml
Hi Jerry,
The partition layout is mandatory for OTA update?
no.. see-also List of Translated Keywords for details.
Hi muralikrishnan.t,
OTA will not change the partition layout running in your board, The layout will remain the same as the layout you used when flashing the board.
just take in consideration if your board uses redundancy, you also need to specify the ROOTFS_AB flag in the OTA payload generation, so the OTA tools will check the reference xml layout to create the pauload according to the partitions that should be running in your board,
this for AB redundancy as Jerry mentioned, but this will not change partitions after or during the OTA update.
Hi Jerry,
My ota update was failed due to no space , any suggestion to fix this?
tar: ./boot: Cannot mkdir: No space left on device
tar: ./boot/kernel_tegra234-p3768-0000+p3767-0001-nv.dtb: Cannot open: No such file or directory
tar: ./boot/tegra234-p3737-0000+p3701-0000-as-p3767-0003.dtbo: Cannot open: No such file or directory
tar: ./boot/tegra234-p3737-0000+p3701-0000.dtb: Cannot open: No such file or directory
tar: ./boot/tegra234-p3737-0000+p3701-0004.dtb: Cannot open: No such file or directory
tar: ./boot/tegra234-p3737-camera-p3762-a00-2Hawk-overlay.dtbo: Cannot open: No such file or directory
tar: ./boot/tegra234-p3737-0000+p3701-0000-hdr40.dtbo: Cannot open: No such file or directory
tar: ./boot/tegra234-p3767-0000+p3509-a02-audio-respeaker-4-mic-array.dtbo: Cannot open: No such file or directory
tar: ./boot/tegra234-p3737-camera-p3762-a00-4Owl-overlay.dtbo: Cannot open: No such file or directory
tar: ./boot/tegra234-p3768-0000+p3767-0003-nv.dtb: Cannot open: No such file or directory
tar: ./boot/kernel_tegra234-p3768-0000+p3767-0005-nv.dtb: Cannot open: No such file or directory
tar: ./boot/tegra234-p3767-0000+p3509-a02-audio-respeaker-4-mic-lin-array.dtbo: Cannot open: No such file or directory
tar: ./boot/tegra234-p3737-0000+p3701-0000-audio-adafruit-uda1334a.dtbo: Cannot open: No such file or directory
tar: ./boot/tegra234-p3737-camera-imx185-overlay.dtbo: Cannot open: No such file or directory
tar: ./boot/tegra234-p3740-0002+p3701-0008-m2kb.dtbo: Cannot open: No such file or directory
tar: ./boot/tegra234-p3737-0000+p3701-0000-audio-adafruit-sph0645lm4h.dtbo: Cannot open: No such file or directory
tar: ./boot/tegra234-p3737-camera-e3331-overlay.dtbo: Cannot open: No such file or directory
tar: ./boot/tegra234-p3767-camera-p3768-imx219-dual.dtbo: Cannot open: No such file or directory
tar: ./boot/tegra234-p3740-0002+p3701-0008-nv.dtb: Cannot open: No such file or directory
tar: ./boot/tegra234-p3767-0000+p3509-a02-m2ke.dtbo: Cannot open: No such file or directory
tar: ./boot/tegra234-p3740-0002+p3701-0008-m2ke.dtbo: Cannot open: No such file or directory
tar: ./boot/dtb: Cannot mkdir: No such file or directory
tar: ./boot/dtb/kernel_tegra234-p3768-0000+p3767-0000-nv.dtb: Cannot open: No such file or directory
tar: ./boot/oot-stub: Cannot open: No such file or directory
tar: ./boot/tegra234-p3737-camera-dual-hawk-ar0234-e3653-overlay.dtbo: Cannot open: No such file or directory
tar: ./boot/tegra234-p3768-0000+p3767-0001-nv.dtb: Cannot open: No such file or directory
tar: ./boot/tegra234-p3768-0000+p3767-0001-nv-super.dtb: Cannot open: No such file or directory
tar: ./boot/tegra234-p3740-0002+p3701-0008-hdr20.dtbo: Cannot open: No such file or directory
tar: ./boot/tegra234-p3737-0000+p3701-0008.dtb: Cannot open: No such file or directory
tar: ./boot/kernel_tegra234-p3768-0000+p3767-0000-nv.dtb: Cannot open: No such file or directory
tar: ./boot/tegra234-audio-overlay.dtbo: Cannot open: No such file or directory
tar: ./boot/tegra234-p3737-0000+p3701-0000-audio-fe-pi.dtbo: Cannot open: No such file or directory
tar: ./boot/tegra234-p3767-camera-p3768-imx219-imx477.dtbo: Cannot open: No such file or directory
tar: ./boot/tegra234-dcb-p3767-0000-hdmi.dtbo: Cannot open: No such file or directory
tar: ./boot/tegra234-p3737-camera-e3333-overlay.dtbo: Cannot open: No such file or directory
tar: ./boot/tegra234-p3767-camera-p3768-imx477-A.dtbo: Cannot open: No such file or directory
tar: ./boot/tegra234-p3767-camera-p3768-imx477-imx219.dtbo: Cannot open: No such file or directory
tar: ./boot/tegra234-p3740-0002+p3701-0008.dtb: Cannot open: No such file or directory
tar: ./boot/tegra234-p3768-0000+p3767-0000-nv-taylor-low.dtb: Cannot open: No such file or directory
tar: ./boot/tegra234-p3737-0000+p3701-0000-as-p3767-0001.dtbo: Cannot open: No such file or directory
tar: ./boot/tegra234-p3768-0000+p3767-0000-dynamic.dtbo: Cannot open: No such file or directory
tar: ./boot/tegra234-p3768-0000+p3767-0004.dtb: Cannot open: No such file or directory
tar: ./boot/tegra234-p3737-camera-imx390-overlay.dtbo: Cannot open: No such file or directory
tar: ./boot/tegra234-p3737-0000+p3701-0000-audio-respeaker-4-mic-lin-array.dtbo: Cannot open: No such file or directory
tar: ./boot/tegra234-p3737-0000+p3701-0000-as-p3767-0004.dtbo: Cannot open: No such file or directory
tar: ./boot/tegra234-p3737-0000+p3701-0000-as-p3701-0004.dtbo: Cannot open: No such file or directory
tar: ./boot/tegra234-p3737-0000+p3701-0004-nv.dtb: Cannot open: No such file or directory
tar: ./boot/tegra234-p3768-0000+p3767-0000-nv.dtb: Cannot open: No such file or directory
tar: ./boot/tegra234-p3740-camera-p3783-a00-overlay.dtbo: Cannot open: No such file or directory
tar: ./etc/fonts/conf.d/89-tlwg-kinnari-synthetic.conf: Cannot create symlink to ‘/usr/share/fontconfig/conf.avail/89-tlwg-kinnari-synthetic.conf’: No space left on device
tar: ./etc/fonts/conf.d/61-urw-standard-symbols-ps.conf: Cannot create symlink to ‘/usr/share/fontconfig/conf.avail/urw-standard-symbols-ps.conf’: No space left on device
tar: ./etc/fonts/conf.d/89-tlwg-laksaman-synthetic.conf: Cannot create symlink to ‘/usr/share/fontconfig/conf.avail/89-tlwg-laksaman-synthetic.conf’: No space left on device
tar: ./etc/fonts/conf.d/89-tlwg-garuda-synthetic.conf: Cannot create symlink to ‘/usr/share/fontconfig/conf.avail/89-tlwg-garuda-synthetic.conf’: No space left on device
tar: ./etc/fonts/conf.d/89-tlwg-umpush-synthetic.conf: Cannot create symlink to ‘/usr/share/fontconfig/conf.avail/89-tlwg-umpush-synthetic.conf’: No space left on device
tar: ./etc/fonts/conf.d/61-urw-fallback-backwards.conf: Cannot create symlink to ‘/usr/share/fontconfig/conf.avail/urw-fallback-backwards.conf’: No space left on device
tar: ./etc/alternatives/openblas_config.h-aarch64-linux-gnu: Cannot create symlink to ‘/usr/include/aarch64-linux-gnu/openblas-pthread/openblas_config.h’: No space left on device
tar: ./etc/alternatives/openblas.pc-aarch64-linux-gnu: Cannot create symlink to ‘/usr/lib/aarch64-linux-gnu/openblas-pthread/pkgconfig/openblas.pc’: No space left on device
tar: ./etc/alternatives/gdm-theme.gresource: Cannot create symlink to ‘/usr/share/gnome-shell/theme/Yaru/gnome-shell-theme.gresource’: No space left on device
tar: ./etc/alternatives/blas.pc-aarch64-linux-gnu: Cannot create symlink to ‘/usr/lib/aarch64-linux-gnu/openblas-pthread/pkgconfig/blas-openblas.pc’: No space left on device
tar: ./etc/alternatives/lapack.pc-aarch64-linux-gnu: Cannot create symlink to ‘/usr/lib/aarch64-linux-gnu/openblas-pthread/pkgconfig/lapack-openblas.pc’: No space left on device
tar: ./etc/alternatives/libopenblas.so.0-aarch64-linux-gnu: Cannot create symlink to ‘/usr/lib/aarch64-linux-gnu/openblas-pthread/libopenblas.so.0’: No space left on device
tar: ./etc/ssl/certs/OISTE_WISeKey_Global_Root_GB_CA.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/OISTE_WISeKey_Global_Root_GB_CA.crt’: No space left on device
tar: ./etc/ssl/certs/Hellenic_Academic_and_Research_Institutions_RootCA_2015.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/Hellenic_Academic_and_Research_Institutions_RootCA_2015.crt’: No space left on device
tar: ./etc/ssl/certs/NetLock_Arany_=Class_Gold=Főtanúsítvány.pem: Cannot create symlink to '/usr/share/ca-certificates/mozilla/NetLock_Arany=Class_Gold=Főtanúsítvány.crt’: No space left on device
tar: ./etc/ssl/certs/SwissSign_Silver_CA
-G2.pem: Cannot create symlink to '/usr/share/ca-certificates/mozilla/SwissSign_Silver_CA-G2.crt’: No space left on device
tar: ./etc/ssl/certs/DigiCert_Global_Root_CA.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/DigiCert_Global_Root_CA.crt’: No space left on device
tar: ./etc/ssl/certs/GlobalSign_Root_CA
-R3.pem: Cannot create symlink to '/usr/share/ca-certificates/mozilla/GlobalSign_Root_CA-R3.crt’: No space left on device
tar: ./etc/ssl/certs/Entrust.net_Premium_2048_Secure_Server_CA.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/Entrust.net_Premium_2048_Secure_Server_CA.crt’: No space left on device
tar: ./etc/ssl/certs/AffirmTrust_Networking.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/AffirmTrust_Networking.crt’: No space left on device
tar: ./etc/ssl/certs/Certum_Trusted_Network_CA.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/Certum_Trusted_Network_CA.crt’: No space left on device
tar: ./etc/ssl/certs/Buypass_Class_3_Root_CA.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/Buypass_Class_3_Root_CA.crt’: No space left on device
tar: ./etc/ssl/certs/SSL.com_TLS_ECC_Root_CA_2022.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/SSL.com_TLS_ECC_Root_CA_2022.crt’: No space left on device
tar: ./etc/ssl/certs/Atos_TrustedRoot_Root_CA_ECC_TLS_2021.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/Atos_TrustedRoot_Root_CA_ECC_TLS_2021.crt’: No space left on device
tar: ./etc/ssl/certs/TUBITAK_Kamu_SM_SSL_Kok_Sertifikasi
-Surum_1.pem: Cannot create symlink to '/usr/share/ca-certificates/mozilla/TUBITAK_Kamu_SM_SSL_Kok_Sertifikasi-Surum_1.crt’: No space left on device
tar: ./etc/ssl/certs/USERTrust_RSA_Certification_Authority.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/USERTrust_RSA_Certification_Authority.crt’: No space left on device
tar: ./etc/ssl/certs/Entrust_Root_Certification_Authority
-G4.pem: Cannot create symlink to '/usr/share/ca-certificates/mozilla/Entrust_Root_Certification_Authority-G4.crt’: No space left on device
tar: ./etc/ssl/certs/Microsoft_RSA_Root_Certificate_Authority_2017.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/Microsoft_RSA_Root_Certificate_Authority_2017.crt’: No space left on device
tar: ./etc/ssl/certs/CommScope_Public_Trust_ECC_Root-02.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/CommScope_Public_Trust_ECC_Root-02.crt’: No space left on device
tar: ./etc/ssl/certs/emSign_ECC_Root_CA
-G3.pem: Cannot create symlink to '/usr/share/ca-certificates/mozilla/emSign_ECC_Root_CA-G3.crt’: No space left on device
tar: ./etc/ssl/certs/Hongkong_Post_Root_CA_3.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/Hongkong_Post_Root_CA_3.crt’: No space left on device
tar: ./etc/ssl/certs/e-Szigno_Root_CA_2017.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/e-Szigno_Root_CA_2017.crt’: No space left on device
tar: ./etc/ssl/certs/DigiCert_Assured_ID_Root_CA.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/DigiCert_Assured_ID_Root_CA.crt’: No space left on device
tar: ./etc/ssl/certs/GDCA_TrustAUTH_R5_ROOT.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/GDCA_TrustAUTH_R5_ROOT.crt’: No space left on device
tar: ./etc/ssl/certs/CommScope_Public_Trust_RSA_Root-02.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/CommScope_Public_Trust_RSA_Root-02.crt’: No space left on device
tar: ./etc/ssl/certs/COMODO_Certification_Authority.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/COMODO_Certification_Authority.crt’: No space left on device
tar: ./etc/ssl/certs/CommScope_Public_Trust_ECC_Root-01.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/CommScope_Public_Trust_ECC_Root-01.crt’: No space left on device
tar: ./etc/ssl/certs/AffirmTrust_Premium_ECC.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/AffirmTrust_Premium_ECC.crt’: No space left on device
tar: ./etc/ssl/certs/DigiCert_Trusted_Root_G4.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/DigiCert_Trusted_Root_G4.crt’: No space left on device
tar: ./etc/ssl/certs/SSL.com_Root_Certification_Authority_RSA.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/SSL.com_Root_Certification_Authority_RSA.crt’: No space left on device
tar: ./etc/ssl/certs/Atos_TrustedRoot_2011.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/Atos_TrustedRoot_2011.crt’: No space left on device
tar: ./etc/ssl/certs/DigiCert_Assured_ID_Root_G3.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/DigiCert_Assured_ID_Root_G3.crt’: No space left on device
tar: ./etc/ssl/certs/Go_Daddy_Root_Certificate_Authority
-G2.pem: Cannot create symlink to '/usr/share/ca-certificates/mozilla/Go_Daddy_Root_Certificate_Authority-G2.crt’: No space left on device
tar: ./etc/ssl/certs/TrustAsia_Global_Root_CA_G3.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/TrustAsia_Global_Root_CA_G3.crt’: No space left on device
tar: ./etc/ssl/certs/ePKI_Root_Certification_Authority.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/ePKI_Root_Certification_Authority.crt’: No space left on device
tar: ./etc/ssl/certs/GlobalSign_ECC_Root_CA
-R5.pem: Cannot create symlink to '/usr/share/ca-certificates/mozilla/GlobalSign_ECC_Root_CA-R5.crt’: No space left on device
tar: ./etc/ssl/certs/SSL.com_EV_Root_Certification_Authority_RSA_R2.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/SSL.com_EV_Root_Certification_Authority_RSA_R2.crt’: No space left on device
tar: ./etc/ssl/certs/TWCA_Root_Certification_Authority.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/TWCA_Root_Certification_Authority.crt’: No space left on device
tar: ./etc/ssl/certs/IdenTrust_Commercial_Root_CA_1.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/IdenTrust_Commercial_Root_CA_1.crt’: No space left on device
tar: ./etc/ssl/certs/DigiCert_Global_Root_G2.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/DigiCert_Global_Root_G2.crt’: No space left on device
tar: ./etc/ssl/certs/TrustAsia_Global_Root_CA_G4.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/TrustAsia_Global_Root_CA_G4.crt’: No space left on device
tar: ./etc/ssl/certs/SSL.com_Root_Certification_Authority_ECC.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/SSL.com_Root_Certification_Authority_ECC.crt’: No space left on device
tar: ./etc/ssl/certs/SSL.com_TLS_RSA_Root_CA_2022.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/SSL.com_TLS_RSA_Root_CA_2022.crt’: No space left on device
tar: ./etc/ssl/certs/Sectigo_Public_Server_Authentication_Root_R46.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/Sectigo_Public_Server_Authentication_Root_R46.crt’: No space left on device
tar: ./etc/ssl/certs/DigiCert_High_Assurance_EV_Root_CA.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/DigiCert_High_Assurance_EV_Root_CA.crt’: No space left on device
tar: ./etc/ssl/certs/Entrust_Root_Certification_Authority.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/Entrust_Root_Certification_Authority.crt’: No space left on device
tar: ./etc/ssl/certs/NAVER_Global_Root_Certification_Authority.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/NAVER_Global_Root_Certification_Authority.crt’: No space left on device
tar: ./etc/ssl/certs/AffirmTrust_Commercial.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/AffirmTrust_Commercial.crt’: No space left on device
tar: ./etc/ssl/certs/QuoVadis_Root_CA_2_G3.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/QuoVadis_Root_CA_2_G3.crt’: No space left on device
tar: ./etc/ssl/certs/Starfield_Services_Root_Certificate_Authority
-G2.pem: Cannot create symlink to '/usr/share/ca-certificates/mozilla/Starfield_Services_Root_Certificate_Authority-G2.crt’: No space left on device
tar: ./etc/ssl/certs/Comodo_AAA_Services_root.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/Comodo_AAA_Services_root.crt’: No space left on device
tar: ./etc/ssl/certs/Autoridad_de_Certificacion_Firmaprofesional_CIF_A62634068.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/Autoridad_de_Certificacion_Firmaprofesional_CIF_A62634068.crt’: No space left on device
tar: ./etc/ssl/certs/HARICA_TLS_RSA_Root_CA_2021.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/HARICA_TLS_RSA_Root_CA_2021.crt’: No space left on device
tar: ./etc/ssl/certs/T-TeleSec_GlobalRoot_Class_3.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/T-TeleSec_GlobalRoot_Class_3.crt’: No space left on device
tar: ./etc/ssl/certs/DigiCert_TLS_RSA4096_Root_G5.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/DigiCert_TLS_RSA4096_Root_G5.crt’: No space left on device
tar: ./etc/ssl/certs/USERTrust_ECC_Certification_Authority.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/USERTrust_ECC_Certification_Authority.crt’: No space left on device
tar: ./etc/ssl/certs/Security_Communication_RootCA3.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/Security_Communication_RootCA3.crt’: No space left on device
tar: ./etc/ssl/certs/QuoVadis_Root_CA_3_G3.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/QuoVadis_Root_CA_3_G3.crt’: No space left on device
-C3.pem: Cannot create symlink to '/usr/share/ca-certificates/mozilla/emSign_ECC_Root_CA-C3.crt’: No space left on device
tar: ./etc/ssl/certs/UCA_Extended_Validation_Root.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/UCA_Extended_Validation_Root.crt’: No space left on device
tar: ./etc/ssl/certs/COMODO_RSA_Certification_Authority.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/COMODO_RSA_Certification_Authority.crt’: No space left on device
tar: ./etc/ssl/certs/QuoVadis_Root_CA_1_G3.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/QuoVadis_Root_CA_1_G3.crt’: No space left on device
tar: ./etc/ssl/certs/DigiCert_Global_Root_G3.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/DigiCert_Global_Root_G3.crt’: No space left on device
tar: ./etc/ssl/certs/CommScope_Public_Trust_RSA_Root-01.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/CommScope_Public_Trust_RSA_Root-01.crt’: No space left on device
tar: ./etc/ssl/certs/DigiCert_TLS_ECC_P384_Root_G5.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/DigiCert_TLS_ECC_P384_Root_G5.crt’: No space left on device
tar: ./etc/ssl/certs/Certum_Trusted_Network_CA_2.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/Certum_Trusted_Network_CA_2.crt’: No space left on device
tar: ./etc/ssl/certs/D-TRUST_EV_Root_CA_1_2020.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/D-TRUST_EV_Root_CA_1_2020.crt’: No space left on device
tar: ./etc/ssl/certs/Security_Communication_ECC_RootCA1.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/Security_Communication_ECC_RootCA1.crt’: No space left on device
tar: ./etc/ssl/certs/Trustwave_Global_ECC_P256_Certification_Authority.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/Trustwave_Global_ECC_P256_Certification_Authority.crt’: No space left on device
tar: ./etc/ssl/certs/Security_Communication_Root_CA.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/Security_Communication_Root_CA.crt’: No space left on device
tar: ./etc/ssl/certs/SwissSign_Gold_CA
-G2.pem: Cannot create symlink to '/usr/share/ca-certificates/mozilla/SwissSign_Gold_CA-G2.crt’: No space left on device
tar: ./etc/ssl/certs/AC_RAIZ_FNMT-RCM_SERVIDORES_SEGUROS.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/AC_RAIZ_FNMT-RCM_SERVIDORES_SEGUROS.crt’: No space left on device
tar: ./etc/ssl/certs/HARICA_TLS_ECC_Root_CA_2021.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/HARICA_TLS_ECC_Root_CA_2021.crt’: No space left on device
tar: ./etc/ssl/certs/TeliaSonera_Root_CA_v1.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/TeliaSonera_Root_CA_v1.crt’: No space left on device
tar: ./etc/ssl/certs/Trustwave_Global_Certification_Authority.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/Trustwave_Global_Certification_Authority.crt’: No space left on device
tar: ./etc/ssl/certs/Baltimore_CyberTrust_Root.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/Baltimore_CyberTrust_Root.crt’: No space left on device
tar: ./etc/ssl/certs/Starfield_Root_Certificate_Authority
-G2.pem: Cannot create symlink to '/usr/share/ca-certificates/mozilla/Starfield_Root_Certificate_Authority-G2.crt’: No space left on device
tar: ./etc/ssl/certs/Microsec_e-Szigno_Root_CA_2009.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/Microsec_e-Szigno_Root_CA_2009.crt’: No space left on device
tar: ./etc/ssl/certs/IdenTrust_Public_Sector_Root_CA_1.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/IdenTrust_Public_Sector_Root_CA_1.crt’: No space left on device
tar: ./etc/ssl/certs/OISTE_WISeKey_Global_Root_GC_CA.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/OISTE_WISeKey_Global_Root_GC_CA.crt’: No space left on device
tar: ./etc/ssl/certs/Atos_TrustedRoot_Root_CA_RSA_TLS_2021.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/Atos_TrustedRoot_Root_CA_RSA_TLS_2021.crt’: No space left on device
tar: ./etc/ssl/certs/DigiCert_Assured_ID_Root_G2.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/DigiCert_Assured_ID_Root_G2.crt’: No space left on device
-EC1.pem: Cannot create symlink to '/usr/share/ca-certificates/mozilla/Entrust_Root_Certification_Authority-EC1.crt’: No space left on device
tar: ./etc/ssl/certs/D-TRUST_Root_Class_3_CA_2_2009.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/D-TRUST_Root_Class_3_CA_2_2009.crt’: No space left on device
tar: ./etc/ssl/certs/ANF_Secure_Server_Root_CA.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/ANF_Secure_Server_Root_CA.crt’: No space left on device
tar: ./etc/ssl/certs/Sectigo_Public_Server_Authentication_Root_E46.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/Sectigo_Public_Server_Authentication_Root_E46.crt’: No space left on device
tar: ./etc/ssl/certs/Security_Communication_RootCA2.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/Security_Communication_RootCA2.crt’: No space left on device
tar: ./etc/ssl/certs/SSL.com_EV_Root_Certification_Authority_ECC.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/SSL.com_EV_Root_Certification_Authority_ECC.crt’: No space left on device
-G2.pem: Cannot create symlink to '/usr/share/ca-certificates/mozilla/Entrust_Root_Certification_Authority-G2.crt’: No space left on device
tar: ./etc/ssl/certs/Certum_Trusted_Root_CA.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/Certum_Trusted_Root_CA.crt’: No space left on device
tar: ./etc/ssl/certs/Buypass_Class_2_Root_CA.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/Buypass_Class_2_Root_CA.crt’: No space left on device
tar: ./etc/ssl/certs/D-TRUST_BR_Root_CA_1_2020.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/D-TRUST_BR_Root_CA_1_2020.crt’: No space left on device
tar: ./etc/ssl/certs/COMODO_ECC_Certification_Authority.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/COMODO_ECC_Certification_Authority.crt’: No space left on device
tar: ./etc/ssl/certs/Hellenic_Academic_and_Research_Institutions_ECC_RootCA_2015.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/Hellenic_Academic_and_Research_Institutions_ECC_RootCA_2015.crt’: No space left on device
-R4.pem: Cannot create symlink to '/usr/share/ca-certificates/mozilla/GlobalSign_ECC_Root_CA-R4.crt’: No space left on device
tar: ./etc/ssl/certs/Trustwave_Global_ECC_P384_Certification_Authority.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/Trustwave_Global_ECC_P384_Certification_Authority.crt’: No space left on device
tar: ./etc/ssl/certs/D-TRUST_Root_Class_3_CA_2_EV_2009.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/D-TRUST_Root_Class_3_CA_2_EV_2009.crt’: No space left on device
tar: ./etc/ssl/certs/T-TeleSec_GlobalRoot_Class_2.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/T-TeleSec_GlobalRoot_Class_2.crt’: No space left on device
-R6.pem: Cannot create symlink to '/usr/share/ca-certificates/mozilla/GlobalSign_Root_CA-_R6.crt’: No space left on device
tar: ./etc/ssl/certs/Actalis_Authentication_Root_CA.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/Actalis_Authentication_Root_CA.crt’: No space left on device
tar: ./etc/ssl/certs/Microsoft_ECC_Root_Certificate_Authority_2017.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/Microsoft_ECC_Root_Certificate_Authority_2017.crt’: No space left on device
tar: ./etc/systemd/user/gnome-session.target.wants/org.freedesktop.IBus.session.GNOME.service: Cannot create symlink to ‘/usr/lib/systemd/user/org.freedesktop.IBus.session.GNOME.service’: No space left on device
tar: ./etc/systemd/user/graphical-session-pre.target.wants/xdg-desktop-portal-rewrite-launchers.service: Cannot create symlink to ‘/usr/lib/systemd/user/xdg-desktop-portal-rewrite-launchers.service’: No space left on device
tar: ./etc/systemd/system/nv-l4t-usb-device-mode.service: Cannot create symlink to ‘/opt/nvidia/l4t-usb-device-mode/nv-l4t-usb-device-mode.service’: No space left on device
tar: ./etc/systemd/system/nv-l4t-bootloader-config.service: Cannot create symlink to ‘/opt/nvidia/l4t-bootloader-config/nv-l4t-bootloader-config.service’: No space left on device
tar: ./etc/systemd/system/nv-l4t-usb-device-mode-runtime.service: Cannot create symlink to ‘/opt/nvidia/l4t-usb-device-mode/nv-l4t-usb-device-mode-runtime.service’: No space left on device
tar: ./etc/systemd/system/multi-user.target.wants/nv-l4t-usb-device-mode.service: Cannot create symlink to ‘/opt/nvidia/l4t-usb-device-mode/nv-l4t-usb-device-mode.service’: No space left on device
tar: ./etc/systemd/system/multi-user.target.wants/nv-l4t-bootloader-config.service: Cannot create symlink to ‘/opt/nvidia/l4t-bootloader-config/nv-l4t-bootloader-config.service’: No space left on device
tar: ./etc/systemd/system/multi-user.target.wants/l4t-rootfs-validation-config.service: Cannot create symlink to ‘/opt/nvidia/l4t-rootfs-validation-config/l4t-rootfs-validation-config.service’: No space left on device
tar: ./etc/systemd/system/l4t-rootfs-validation-config.service: Cannot create symlink to ‘/opt/nvidia/l4t-rootfs-validation-config/l4t-rootfs-validation-config.service’: No space left on device
tar: ./etc/libreoffice/registry/oo-ad-ldap.xcd.sample: Cannot create symlink to ‘/usr/share/doc/libreoffice-common/examples/oo-ad-ldap.xcd.sample’: No space left on device
tar: ./etc/libreoffice/registry/oo-ldap.xcd.sample: Cannot create symlink to ‘/usr/share/doc/libreoffice-common/examples/oo-ldap.xcd.sample’: No space left on device
tar: Exiting with failure status due to previous errors
Failed to decompress rootfs image into /dev/nvme0n1p2
Failed to run “update_rootfs_partition /ota_work/external_device/system.img /dev/nvme0n1p2 /ota_work”
Failed to run command “/ota_work/nv_ota_rootfs_updater.sh -p /dev/nvme0n1p2 -d /ota_work /ota_work/external_device/system.img”
Failed to run “update_rootfs_runtime /ota_work B external_device”
Failed to run “update_rootfs_with_a_b_enabled /ota_work”
Failed to run “update_rootfs /ota_work”
