hi,What is the reason
You should probably start by seeing what device tree changes are needed. Every carrier can require a different device tree.
If your custom board is with same USB HW as developer kit, probably you don’t apply
[url]Jetson/TX2 USB - eLinux.org
For further investigation you need to check oem design guide and adaptation guide to modify device tree accordingly.
[ 5.948325] tegra-xotg xotg: usb2 phy is not available yet
[ 5.948554] tegra-usb-cd usb_cd: otg phy is not available yet
[ 5.949065] tegra-xudc-new 3550000.xudc: usb2 phy is not available yet
[ 5.949261] tegra186-padctl 3520000.pinctrl: padctl mmio start 0x000000000352 0000 end 0x0000000003520fff
[ 5.949267] tegra186-padctl 3520000.pinctrl: ao mmio start 0x0000000003540000 end 0x0000000003540fff
[ 5.949305] tegra186-padctl 3520000.pinctrl: FUSE_SKU_USB_CALIB_0 0x2eb894
[ 5.949308] tegra186-padctl 3520000.pinctrl: FUSE_USB_CALIB_EXT_0 0x9
[ 5.950082] tegra186-padctl 3520000.pinctrl: using UTMI port 0 for otg
[ 5.952159] Wake76 for irq=199
[ 5.952160] Wake77 for irq=199
[ 5.952161] Wake78 for irq=199
[ 5.952162] Wake79 for irq=199
[ 5.952162] Wake80 for irq=199
[ 5.952163] Wake81 for irq=199
[ 5.952163] Wake82 for irq=199
[ 5.952349] xhci-tegra 3530000.xhci: can’t get usb3-0 phy (-517)
[ 6.078571] systemd[1]: Started Braille Device Support.
[ 6.085216] systemd[1]: Created slice User and Session Slice.
[ 6.092075] systemd[1]: Reached target Slices.
[ 6.099331] systemd[1]: Starting Create list of required static device nodes for the current kernel…
[ 6.110514] systemd[1]: Listening on Journal Audit Socket.
[ 6.118235] systemd[1]: Starting Journal Service…
[ 6.124354] systemd[1]: Created slice system-getty.slice.
[ 6.132689] systemd[1]: Mounted Debug File System.
[ 6.139084] systemd[1]: Started Load Kernel Modules.
[ 6.145597] systemd[1]: Started Remount Root and Kernel File Systems.
[ 6.154594] systemd[1]: Started Create list of required static device nodes f or the current kernel.
[ 6.177183] systemd[1]: Started Journal Service.
[ 6.233036] systemd-journald[276]: Received request to flush runtime journal from PID 1
[ 6.283327] random: nonblocking pool is initialized
[ 6.475656] tegra-pcie 10003000.pcie-controller: 4x1, 1x1 configuration
[ 6.483690] Wake76 for irq=199
[ 6.484120] tegra-pcie 10003000.pcie-controller: PCIE: Enable power rails
[ 6.484526] tegra-pcie 10003000.pcie-controller: probing port 0, using 4 lane s
[ 6.485900] tegra-pcie 10003000.pcie-controller: probing port 2, using 1 lane s
[ 6.512093] Wake77 for irq=199
[ 6.512094] Wake78 for irq=199
[ 6.512094] Wake79 for irq=199
[ 6.512095] Wake80 for irq=199
[ 6.512096] Wake81 for irq=199
[ 6.512096] Wake82 for irq=199
[ 6.512453] tegra-xotg xotg: usb2 phy is not available yet
[ 6.512712] tegra-usb-cd usb_cd: otg phy is not available yet
[ 6.513272] tegra-xudc-new 3550000.xudc: usb2 phy is not available yet
[ 6.513603] tegra186-padctl 3520000.pinctrl: padctl mmio start 0x000000000352 0000 end 0x0000000003520fff
[ 6.513609] tegra186-padctl 3520000.pinctrl: ao mmio start 0x0000000003540000 end 0x0000000003540fff
[ 6.513643] tegra186-padctl 3520000.pinctrl: FUSE_SKU_USB_CALIB_0 0x2eb894
[ 6.513646] tegra186-padctl 3520000.pinctrl: FUSE_USB_CALIB_EXT_0 0x9
[ 6.515537] tegra186-padctl 3520000.pinctrl: using UTMI port 0 for otg
[ 6.521953] Wake76 for irq=199
[ 6.521954] Wake77 for irq=199
[ 6.521955] Wake78 for irq=199
[ 6.521956] Wake79 for irq=199
[ 6.521957] Wake80 for irq=199
[ 6.521957] Wake81 for irq=199
[ 6.521958] Wake82 for irq=199
[ 6.522437] xhci-tegra 3530000.xhci: can’t get usb3-0 phy (-517)
[ 6.643878] dhd_module_init in
[ 6.648333] tegra_net_perf_init: cannot get wifi sclk
[ 6.654384] found wifi platform device bcmdhd_wlan
[ 6.668073] gpio tegra-gpio-aon wake69 for gpio=59(FF:3)
[ 6.674062] wifi_platform_get_country_code_map: could not get country_code_ma p
[ 6.682807] wifi_plat_dev_drv_probe:platform country code map is not availabl e
[ 6.691948] Power-up adapter ‘DHD generic adapter’
[ 6.699356] wifi_platform_set_power = 1
[ 6.734314] cfg80211: World regulatory domain updated:
[ 6.740306] cfg80211: DFS Master region: unset
[ 6.740306] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 6.740310] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 6.740312] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 6.740313] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[ 6.740316] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 6.740320] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[ 6.740322] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 6.740323] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[ 6.740325] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[ 6.905761] wifi_platform_bus_enumerate device present 1
[ 6.913622] Wake76 for irq=199
[ 6.917643] Wake77 for irq=199
[ 6.919762] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[ 6.928864] Wake78 for irq=199
[ 6.930090] wifi_platform_bus_enumerate device present 0
[ 6.930843] F1 signature read @0x18000000=0x17214354
[ 6.934689] F1 signature OK, socitype:0x1 chip:0x4354 rev:0x1 pkg:0x2
[ 6.935175] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[ 6.935230] wifi_platform_prealloc: failed to alloc static mem section 7
[ 6.935236] wifi_platform_get_mac_addr
[ 6.935753] CFG80211-ERROR) wl_setup_wiphy : Registering Vendor80211
[ 6.979667] Wake79 for irq=199
[ 6.979668] Wake80 for irq=199
[ 6.979671] Wake81 for irq=199
[ 6.979672] Wake82 for irq=199
[ 6.979933] tegra-xotg xotg: usb2 phy is not available yet
[ 6.984140] tegra-usb-cd usb_cd: otg phy is not available yet
[ 6.984700] tegra-xudc-new 3550000.xudc: usb2 phy is not available yet
[ 6.984919] tegra186-padctl 3520000.pinctrl: padctl mmio start 0x0000000003520000 end 0x0000000003520fff
[ 6.984925] tegra186-padctl 3520000.pinctrl: ao mmio start 0x0000000003540000 end 0x0000000003540fff
[ 6.984963] tegra186-padctl 3520000.pinctrl: FUSE_SKU_USB_CALIB_0 0x2eb894
[ 6.984966] tegra186-padctl 3520000.pinctrl: FUSE_USB_CALIB_EXT_0 0x9
[ 6.985874] tegra186-padctl 3520000.pinctrl: using UTMI port 0 for otg
[ 6.989519] Wake76 for irq=199
[ 6.989520] Wake77 for irq=199
[ 6.989521] Wake78 for irq=199
[ 6.989522] Wake79 for irq=199
[ 6.989523] Wake80 for irq=199
[ 6.989523] Wake81 for irq=199
[ 6.989524] Wake82 for irq=199
[ 6.989766] xhci-tegra 3530000.xhci: can’t get usb3-0 phy (-517)
[ 6.990055] Wake76 for irq=199
[ 6.990056] Wake77 for irq=199
[ 6.990057] Wake78 for irq=199
[ 6.990057] Wake79 for irq=199
[ 6.990058] Wake80 for irq=199
[ 6.[ 7.970505] gk20a 17000000.gp10b: railgate is disabled.
[ 8.092976] CPU1: shutdown
[ 8.095792] psci: CPU1 killed.
[ 8.127024] CPU2: shutdown
[ 8.129757] psci: CPU2 killed.
[ 8.285742] tegra-pcie 10003000.pcie-controller: link 2 down, retrying
[ 8.703014] tegra-pcie 10003000.pcie-controller: link 2 down, retrying
[ 9.114268] tegra-pcie 10003000.pcie-controller: link 2 down, retrying
[ 9.122985] tegra-pcie 10003000.pcie-controller: link 2 down, ignoring
[ 9.129663] tegra-pcie 10003000.pcie-controller: PCIE: no end points detected
[ 9.138976] tegra-pcie 10003000.pcie-controller: PCIE: Disable power rails
[ 9.546301] fuse init (API version 7.23)
[ 9.924777] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
Above is our serial port printing information
Is your custom board same as develoer kit? One USB3 Type A and one USB2 micro AB?
I uploaded the circuit diagram of the USB part of the hardware schematic. Please see if there is any problem?
Yes,One USB3 Type A and one USB2 micro AB
Please apply Jetson/TX2 USB - eLinux.org and rebuild dtb. It fixes the error:
[ 5.952349] xhci-tegra 3530000.xhci: can't get usb3-0 phy (-517)
Thank you, the problem has been solved.
