I’m using Jetson Nano 2G or 4G, I can run through the usb camera object detection deepstream app by a build-in config from Deepstream 6 SDK (I installted it by .deb).
I want to output those inference results to my custom endpoint rather than only shows a monitor console or RTSP stream, the results include:
- Detected objects’ bounding box and labels for each frame.
- confidence of each object.
- Timestamp of the detection.
the result should be a structured data like json.
The endpoint is a local tcp connection, or mqtt, or http web api.
please give some advice, thanks!
