Write CNN outputs into file or make them accessible by another process
• Hardware Platform (Jetson / GPU) Jetson Nano
• DeepStream Version Deep-Stream-5.1
• JetPack Version (valid for Jetson only) JetPack 4.6.1
• TensorRT Version TensorRT 7.1.3
I setup my Jetson NANO and my goal is to save the predictions of a CNN into a file. I managed to get a live stream from my CSI camera (IMX290).
I’m using deepstream-app with the following configuration files:
/opt/nvidia/deepstream/deepstream-5.1/samples/configs/deepstream-app/config_infer_primary.txt
# Copyright (c) 2018-2020, NVIDIA CORPORATION. All rights reserved.
# Permission is hereby granted, free of charge, to any person obtaining a
# copy of this software and associated documentation files (the "Software"),
# to deal in the Software without restriction, including without limitation
# the rights to use, copy, modify, merge, publish, distribute, sublicense,
# and/or sell copies of the Software, and to permit persons to whom the
# Software is furnished to do so, subject to the following conditions:
# The above copyright notice and this permission notice shall be included in
# all copies or substantial portions of the Software.
# THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
# IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
# FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT.  IN NO EVENT SHALL
# THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
# LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
# FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
# DEALINGS IN THE SOFTWARE.
# Following properties are mandatory when engine files are not specified:
#   int8-calib-file(Only in INT8)
#   Caffemodel mandatory properties: model-file, proto-file, output-blob-names
#   UFF: uff-file, input-dims, uff-input-blob-name, output-blob-names
#   ONNX: onnx-file
# Mandatory properties for detectors:
#   num-detected-classes
# Optional properties for detectors:
#   cluster-mode(Default=Group Rectangles), interval(Primary mode only, Default=0)
#   custom-lib-path,
#   parse-bbox-func-name
# Mandatory properties for classifiers:
#   classifier-threshold, is-classifier
# Optional properties for classifiers:
#   classifier-async-mode(Secondary mode only, Default=false)
# Optional properties in secondary mode:
#   operate-on-gie-id(Default=0), operate-on-class-ids(Defaults to all classes),
#   input-object-min-width, input-object-min-height, input-object-max-width,
#   input-object-max-height
# Following properties are always recommended:
#   batch-size(Default=1)
# Other optional properties:
#   net-scale-factor(Default=1), network-mode(Default=0 i.e FP32),
#   model-color-format(Default=0 i.e. RGB) model-engine-file, labelfile-path,
#   mean-file, gie-unique-id(Default=0), offsets, process-mode (Default=1 i.e. primary),
#   custom-lib-path, network-mode(Default=0 i.e FP32)
# The values in the config file are overridden by values set through GObject
# properties.
[property]
gpu-id=0
net-scale-factor=0.0039215697906911373
model-file=../../models/Primary_Detector/resnet10.caffemodel
proto-file=../../models/Primary_Detector/resnet10.prototxt
model-engine-file=../../models/Primary_Detector/resnet10.caffemodel_b30_gpu0_int8.engine
labelfile-path=../../models/Primary_Detector/labels.txt
int8-calib-file=../../models/Primary_Detector/cal_trt.bin
batch-size=30
process-mode=1
model-color-format=0
## 0=FP32, 1=INT8, 2=FP16 mode
network-mode=1
num-detected-classes=4
interval=0
gie-unique-id=1
#output-blob-names=conv2d_bbox;conv2d_cov/Sigmoid
output-blob-names=conv2d_cov/Sigmoid
force-implicit-batch-dim=1
#parse-bbox-func-name=NvDsInferParseCustomResnet
#custom-lib-path=/path/to/libnvdsparsebbox.so
## 0=Group Rectangles, 1=DBSCAN, 2=NMS, 3= DBSCAN+NMS Hybrid, 4 = None(No clustering)
#cluster-mode=1
#scaling-filter=0
#scaling-compute-hw=0
#Use these config params for group rectangles clustering mode
[class-attrs-all]
pre-cluster-threshold=0.2
group-threshold=1
eps=0.2
roi-top-offset=0
roi-bottom-offset=0
detected-min-w=0
detected-min-h=0
detected-max-w=0
detected-max-h=0
#Use the config params below for dbscan clustering mode
#[class-attrs-all]
#detected-min-w=4
#detected-min-h=4
#minBoxes=3
## Per class configurations
#[class-attrs-0]
#pre-cluster-threshold=0.05
#eps=0.7
#dbscan-min-score=0.95
#[class-attrs-1]
#eps=0.7
#dbscan-min-score=0.5
#[class-attrs-2]
#pre-cluster-threshold=0.1
#eps=0.6
#[class-attrs-3]
#eps=0.7
[application]
enable-perf-measurement=1
perf-measurement-interval-sec=5
#gie-kitti-output-dir=streamscl
[tiled-display]
enable=1
rows=1
columns=1
width=1280
height=720
[source0]
enable=1
#Type - 1=CameraV4L2 2=URI 3=MultiURI 4=RTSP 5=CSI
type=5
camera-width=1920
camera-height=1080
camera-fps-n=30
camera-fps-d=1
[sink1]
enable=1
#Type - 1=FakeSink 2=EglSink 3=File 4=RTSPStreaming 5=Overlay
type=5
sync=0
display-id=0
offset-x=0
offset-y=0
width=0
height=0
overlay-id=1
source-id=0
[sink0]
enable=1
type=3
#1=mp4 2=mkv
container=1
#1=h264 2=h265 3=mpeg4
codec=1
#encoder type 0=Hardware 1=Software
enc-type=0
sync=0
bitrate=2000000
#H264 Profile - 0=Baseline 2=Main 4=High
#H265 Profile - 0=Main 1=Main10
profile=0
output-file=/home/out_heute.mp4
source-id=0
[sink2]
enable=0
type=2
#1=h264 2=h265
codec=1
enc-type=0
sync=0
bitrate=4000000
profile=0
# set below properties in case of RTSPStreaming
#rtsp-port=8554
#udp-port=5400
[osd]
enable=0
border-width=2
text-size=15
text-color=1;1;1;1;
text-bg-color=0.3;0.3;0.3;1
font=Serif
show-clock=0
clock-x-offset=800
clock-y-offset=820
clock-text-size=12
clock-color=1;0;0;0
[streammux]
##Boolean property to inform muxer that sources are live
live-source=1
batch-size=1
##time out in usec, to wait after the first buffer is available
##to push the batch even if the complete batch is not formed
batched-push-timeout=40000
## Set muxer output width and height
width=1920
height=1080
## If set to TRUE, system timestamp will be attached as ntp timestamp
## If set to FALSE, ntp timestamp from rtspsrc, if available, will be attached
# attach-sys-ts-as-ntp=1
# config-file property is mandatory for any gie section.
# Other properties are optional and if set will override the properties set in
# the infer config file.
[primary-gie]
enable=1
model-engine-file=../../models/Primary_Detector/resnet10.caffemodel_b1_gpu0_fp16.engine
#Required to display the PGIE labels, should be added even when using config-file
#property
batch-size=1
bbox-border-color0=1;0;0;1
bbox-border-color1=0;1;1;1
bbox-border-color2=0;0;1;1
bbox-border-color3=0;1;0;1
infer-raw-output-dir=/home/raw_inference_buffer
interval=0
#Required by the app for SGIE, when used along with config-file property
gie-unique-id=1
config-file=config_infer_primary.txt
[tests]
file-loop=0
I ran the following command:
sudo deepstream-app -c source1_csi_dec_infer_resnet_int8_edit.txt
The option infer-raw-output-dir=/home/raw_inference_buffer does save something, but I was not able to read it. In my case the batch size is 1 and we have 4 classes, but the network’s output is a file e.g. “conv2d_cov_Sigmoid_batch0000000500_batchsize01.bin” with 14720 bytes, which is pretty huge for only 4 classification outputs…
Is this option intended to be used in production? If not, what is the alternative? I need to make the outputs accessible by another process.
Thank you and Best Regards!
About file 's content, please refer to write_infer_output_to_file, the path is:
/opt/nvidia/deepstream/deepstream-6.0/sources/apps/apps-common/src/deepstream_primary_gie_bin.c
Is there no further documentation? Without deeper knowledge of the C-API it’s not understandable.
write_infer_output_to_file is a gst_nvinfer_raw_output_generated_callback callback function, it will set to nvinfer plugin’s raw-output-generated-callback.
pelease refer to Gst-nvinfer — DeepStream 6.1.1 Release documentation , you can find raw-output-generated-callback’s description.
please refer to /opt/nvidia/deepstream/deepstream/sources/includes/gstnvdsinfer.h, you can find gst_nvinfer_raw_output_generated_callback 's description.
nvinfer plugin is open source, in write_infer_output_to_file, you can see how to save raw output.
