Sure, here’s the script and the config file, but the model i will upload it and send it hrough the inbox
#!/usr/bin/env python3
Copyright © 2020, NVIDIA CORPORATION. All rights reserved.
Permission is hereby granted, free of charge, to any person obtaining a
copy of this software and associated documentation files (the “Software”),
to deal in the Software without restriction, including without limitation
the rights to use, copy, modify, merge, publish, distribute, sublicense,
and/or sell copies of the Software, and to permit persons to whom the
Software is furnished to do so, subject to the following conditions:
The above copyright notice and this permission notice shall be included in
all copies or substantial portions of the Software.
THE SOFTWARE IS PROVIDED “AS IS”, WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL
THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
DEALINGS IN THE SOFTWARE.
import sys
sys.path.append(’…/’)
import gi
gi.require_version(‘Gst’, ‘1.0’)
from gi.repository import GObject, Gst
from common.is_aarch_64 import is_aarch64
from common.bus_call import bus_call
import pyds
PGIE_CLASS_ID_VEHICLE = 0
PGIE_CLASS_ID_BICYCLE = 1
PGIE_CLASS_ID_PERSON = 2
PGIE_CLASS_ID_ROADSIGN = 3
def osd_sink_pad_buffer_probe(pad, info, u_data):
frame_number = 0
# Intiallizing object counter with 0.
obj_counter = {
PGIE_CLASS_ID_VEHICLE: 0,
# PGIE_CLASS_ID_PERSON: 0,
# PGIE_CLASS_ID_BICYCLE: 0,
# PGIE_CLASS_ID_ROADSIGN: 0
num_rects = 0
gst_buffer = info.get_buffer()
if not gst_buffer:
print("Unable to get GstBuffer ")
return
# Retrieve batch metadata from the gst_buffer
# Note that pyds.gst_buffer_get_nvds_batch_meta() expects the
# C address of gst_buffer as input, which is obtained with hash(gst_buffer)
batch_meta = pyds.gst_buffer_get_nvds_batch_meta(hash(gst_buffer))
l_frame = batch_meta.frame_meta_list
while l_frame is not None:
print("######## frame is not None")
try:
# Note that l_frame.data needs a cast to pyds.NvDsFrameMeta
# The casting is done by pyds.glist_get_nvds_frame_meta()
# The casting also keeps ownership of the underlying memory
# in the C code, so the Python garbage collector will leave
# it alone.
# frame_meta = pyds.glist_get_nvds_frame_meta(l_frame.data)
print("##################l_frame.data", l_frame.data)
# The following is taken from C++ code
l_user = frame_meta.frame_user_meta_list
while l_user is not None:
user_meta = pyds.NvDsUserMeta(l_user.data)
print("inside luser") # it does not
# trials
# frame_meta2 = pyds.NvDsInferTensorMeta.cast(l_frame.data)
# frame_meta3 = pyds.NvDsInferTensorMeta.cast(frame_meta)
except StopIteration:
break
frame_number = frame_meta.frame_num
num_rects = frame_meta.num_obj_meta
# frame meta
# print("###### frame_meta.display_meta_list", frame_meta.display_meta_list)
# print("###### frame_meta.frame_user_meta_list ", frame_meta.frame_user_meta_list)
# print("###### frame_meta.num_obj_meta <num_rects> ", num_rects)
# print("###### frame_meta.obj_meta_list", frame_meta.obj_meta_list)
l_obj = frame_meta.obj_meta_list
# print("###### l_obj <frame_meta.obj_meta_list> is ", l_obj)
while l_obj is not None:
print("###### obj is not none")
try:
# Casting l_obj.data to pyds.NvDsObjectMeta
# obj_meta=pyds.glist_get_nvds_object_m out_buf_ptrs_deveta(l_obj.data)
obj_meta = pyds.NvDsObjectMeta.cast(l_obj.data)
# print("######## obj meta is ", obj_meta)
break
obj_counter[obj_meta.class_id] += 1
obj_meta.rect_params.border_color.set(0.0, 0.0, 1.0, 0.0)
try:
l_obj = l_obj.next
break
# Acquiring a display meta object. The memory ownership remains in
# the C code so downstream plugins can still access it. Otherwise
# the garbage collector will claim it when this probe function exits.
display_meta = pyds.nvds_acquire_display_meta_from_pool(batch_meta)
display_meta.num_labels = 1
py_nvosd_text_params = display_meta.text_params[0]
# Setting display text to be shown on screen
# Note that the pyds module allocates a buffer for the string, and the
# memory will not be claimed by the garbage collector.
# Reading the display_text field here will return the C address of the
# allocated string. Use pyds.get_string() to get the string content.
py_nvosd_text_params.display_text = "Frame Number={} Number of Objects={} Vehicle_count={}".format(
frame_number, num_rects, obj_counter[PGIE_CLASS_ID_VEHICLE])
# Now set the offsets where the string should appear
py_nvosd_text_params.x_offset = 10
py_nvosd_text_params.y_offset = 12
# Font , font-color and font-size
py_nvosd_text_params.font_params.font_name = "Serif"
py_nvosd_text_params.font_params.font_size = 10
# set(red, green, blue, alpha); set to White
py_nvosd_text_params.font_params.font_color.set(1.0, 1.0, 1.0, 1.0)
# Text background color
py_nvosd_text_params.set_bg_clr = 1
# set(red, green, blue, alpha); set to Black
py_nvosd_text_params.text_bg_clr.set(0.0, 0.0, 0.0, 1.0)
# Using pyds.get_string() to get display_text as string
print(pyds.get_string(py_nvosd_text_params.display_text))
pyds.nvds_add_display_meta_to_frame(frame_meta, display_meta)
try:
l_frame = l_frame.next
break
return Gst.PadProbeReturn.OK
def main(args):
# Check input arguments
if len(args) != 2:
sys.stderr.write(“usage: %s \n” % args[0])
sys.exit(1)
# Standard GStreamer initialization
GObject.threads_init()
Gst.init(None)
# Create gstreamer elements
# Create Pipeline element that will form a connection of other elements
print("Creating Pipeline \n ")
pipeline = Gst.Pipeline()
if not pipeline:
sys.stderr.write(" Unable to create Pipeline \n")
# Source element for reading from the file
print("Creating Source \n ")
source = Gst.ElementFactory.make("filesrc", "file-source")
if not source:
sys.stderr.write(" Unable to create Source \n")
# Since the data format in the input file is elementary h264 stream,
# we need a h264parser
print("Creating H264Parser \n")
h264parser = Gst.ElementFactory.make("h264parse", "h264-parser")
if not h264parser:
sys.stderr.write(" Unable to create h264 parser \n")
# Use nvdec_h264 for hardware accelerated decode on GPU
print("Creating Decoder \n")
decoder = Gst.ElementFactory.make("nvv4l2decoder", "nvv4l2-decoder")
if not decoder:
sys.stderr.write(" Unable to create Nvv4l2 Decoder \n")
# Create nvstreammux instance to form batches from one or more sources.
streammux = Gst.ElementFactory.make("nvstreammux", "Stream-muxer")
if not streammux:
sys.stderr.write(" Unable to create NvStreamMux \n")
# Use nvinfer to run inferencing on decoder's output,
# behaviour of inferencing is set through config file
pgie = Gst.ElementFactory.make("nvinfer", "primary-inference")
if not pgie:
sys.stderr.write(" Unable to create pgie \n")
# Use convertor to convert from NV12 to RGBA as required by nvosd
nvvidconv = Gst.ElementFactory.make("nvvideoconvert", "convertor")
if not nvvidconv:
sys.stderr.write(" Unable to create nvvidconv \n")
# Create OSD to draw on the converted RGBA buffer
nvosd = Gst.ElementFactory.make("nvdsosd", "onscreendisplay")
if not nvosd:
sys.stderr.write(" Unable to create nvosd \n")
# Finally render the osd output
if is_aarch64():
# transform = Gst.ElementFactory.make("nvegltransform", "nvegl-transform")
transform = Gst.ElementFactory.make("queue", "queue")
print("Creating EGLSink \n")
sink = Gst.ElementFactory.make("nveglglessink", "nvvideo-renderer")
# sink = Gst.ElementFactory.make("nvoverlaysink", "nvvideo-renderer")
sink.set_property('sync', 0)
if not sink:
sys.stderr.write(" Unable to create egl sink \n")
print("Playing file %s " % args[1])
source.set_property('location', args[1])
streammux.set_property('width', 1920)
streammux.set_property('height', 1080)
streammux.set_property('batch-size', 1)
streammux.set_property('batched-push-timeout', 4000000)
streammux.set_property('live-source', 1)
pgie.set_property('config-file-path', "dstest1_pgie_config.txt")
print("Adding elements to Pipeline \n")
pipeline.add(source)
pipeline.add(h264parser)
pipeline.add(decoder)
pipeline.add(streammux)
pipeline.add(pgie)
pipeline.add(nvvidconv)
pipeline.add(nvosd)
pipeline.add(sink)
if is_aarch64():
pipeline.add(transform)
# we link the elements together
# file-source -> h264-parser -> nvh264-decoder ->
# nvinfer -> nvvidconv -> nvosd -> video-renderer
print("Linking elements in the Pipeline \n")
source.link(h264parser)
h264parser.link(decoder)
sinkpad = streammux.get_request_pad("sink_0")
if not sinkpad:
sys.stderr.write(" Unable to get the sink pad of streammux \n")
srcpad = decoder.get_static_pad("src")
if not srcpad:
sys.stderr.write(" Unable to get source pad of decoder \n")
srcpad.link(sinkpad)
streammux.link(pgie)
pgie.link(nvvidconv)
nvvidconv.link(nvosd)
if is_aarch64():
nvosd.link(transform)
transform.link(sink)
else:
nvosd.link(sink)
# create an event loop and feed gstreamer bus mesages to it
loop = GObject.MainLoop()
bus = pipeline.get_bus()
bus.add_signal_watch()
bus.connect("message", bus_call, loop)
# Lets add probe to get informed of the meta data generated, we add probe to
# the sink pad of the osd element, since by that time, the buffer would have
# had got all the metadata.
osdsinkpad = nvosd.get_static_pad("sink")
if not osdsinkpad:
sys.stderr.write(" Unable to get sink pad of nvosd \n")
osdsinkpad.add_probe(Gst.PadProbeType.BUFFER, osd_sink_pad_buffer_probe, 0)
# start play back and listen to events
print("Starting pipeline \n")
pipeline.set_state(Gst.State.PLAYING)
try:
loop.run()
except:
pass
# cleanup
pipeline.set_state(Gst.State.NULL)
if name == ‘main’:
sys.exit(main(sys.argv))
Config file
Copyright © 2018-2020, NVIDIA CORPORATION. All rights reserved.
Following properties are mandatory when engine files are not specified:
int8-calib-file(Only in INT8)
Caffemodel mandatory properties: model-file, proto-file, output-blob-names
UFF: uff-file, input-dims, uff-input-blob-name, output-blob-names
ONNX: onnx-file
Mandatory properties for detectors:
num-detected-classes
Optional properties for detectors:
cluster-mode(Default=Group Rectangles), interval(Primary mode only, Default=0)
custom-lib-path,
parse-bbox-func-name
Mandatory properties for classifiers:
classifier-threshold, is-classifier
Optional properties for classifiers:
classifier-async-mode(Secondary mode only, Default=false)
Optional properties in secondary mode:
operate-on-gie-id(Default=0), operate-on-class-ids(Defaults to all classes),
input-object-min-width, input-object-min-height, input-object-max-width,
input-object-max-height
Following properties are always recommended:
batch-size(Default=1)
Other optional properties:
net-scale-factor(Default=1), network-mode(Default=0 i.e FP32),
model-color-format(Default=0 i.e. RGB) model-engine-file, labelfile-path,
mean-file, gie-unique-id(Default=0), offsets, process-mode (Default=1 i.e. primary),
custom-lib-path, network-mode(Default=0 i.e FP32)
The values in the config file are overridden by values set through GObject
properties.
[property]
gpu-id=0
#is-classifier=1 #use this only when network-ype=1
net-scale-factor=0.0039215697906911373
model-engine-file=./models/crowd_count_model.engine
labelfile-path=label_map.txt
force-implicit-batch-dim=1
batch-size=1
network-mode=1
network-type=100
output-tensor-meta=1
num-detected-classes=1
interval=0
#output-tensor-meta=TRUE
gie-unique-id=1
output-blob-names=output
#scaling-filter=0
#scaling-compute-hw=0
#parse-classifier-func-name=NvDsInferClassiferParseCustomSoftmax
#custom-lib-path=/opt/nvidia/deepstream/deepstream-5.0/sources/libs/nvdsinfer_customparser_crowd_count/libnvds_infercustomparser.so
[class-attrs-all]
pre-cluster-threshold=0.2
eps=0.2
group-threshold=1
