Dear all,
We are setting up 5 OV10635 cameras that using SerDes on Xavier.
The first one is connected to MAX96705-MAX9288 SerDes and it could work as well.
The other four cameras are connected to MAX96705-MAX9286 and even one of them could not work.
I could verify that there was MIPI output from MAX9286 to Xavier but it was so difficult to confirm the correctness.
Then I tried to capture the image with simple v4l2 command and the result as below
v4l2-ctl -d /dev/video1 --stream-mmap --stream-count=1 --stream-to=test.raw
[ 744.158381] [vunguyen] ov10635_s_stream enable=1
[ 744.158506] [vunguyen] ov10635_s_stream, i2c addr: 0x6a
[ 744.293398] CPU:0, Error:RCE-NOC@0xbe00000,irq=484
[ 744.293520] **************************************
[ 744.293655] * For more Internal Decode Help
[ 744.293728] * http://nv/cbberr
[ 744.293803] * NVIDIA userID is required to access
[ 744.293883] **************************************
[ 744.293966] CPU:0, Error:RCE-NOC
[ 744.294026] Error Logger : 1
[ 744.294094] ErrLog0 : 0x80030600
[ 744.294159] Transaction Type : RD - Read, Incrementing
[ 744.294250] Error Code : TMO
[ 744.294348] Error Source : Target NIU
[ 744.294425] Error Description : Target time-out error
[ 744.294517] Packet header Lock : 0
[ 744.294581] Packet header Len1 : 3
[ 744.294646] NOC protocol version : version >= 2.7
[ 744.294730] ErrLog1 : 0x157600
[ 744.294822] ErrLog2 : 0x0
[ 744.295024] RouteId : 0x157600
[ 744.295280] InitFlow : cpu_p_i/I/0
[ 744.295594] Targflow : cbb_t/T/0
[ 744.295853] TargSubRange : 27
[ 744.296116] SeqId : 0
[ 744.296347] ErrLog3 : 0x5c01400
[ 744.296584] ErrLog4 : 0x0
[ 744.299077] Address : 0x15c01400 (unknown device)
[ 744.304158] ErrLog5 : 0x387e31
[ 744.307394] Master ID : RCE
[ 744.310543] Security Group(GRPSEC): 0x3f
[ 744.314304] Cache : 0x1 -- Device
[ 744.318075] Protection : 0x3 -- Privileged, Non-Secure, Data Access
[ 744.324984] FALCONSEC : 0x0
[ 744.328123] Virtual Queuing Channel(VQC): 0x0
[ 744.332594] **************************************
[ 744.647169] CPU:0, Error:RCE-NOC@0xbe00000,irq=484
[ 744.647295] **************************************
[ 744.647413] * For more Internal Decode Help
[ 744.647490] * http://nv/cbberr
[ 744.647550] * NVIDIA userID is required to access
[ 744.647632] **************************************
[ 744.647757] CPU:0, Error:RCE-NOC
[ 744.647825] Error Logger : 1
[ 744.647904] ErrLog0 : 0x80030600
[ 744.647974] Transaction Type : RD - Read, Incrementing
[ 744.648067] Error Code : TMO
[ 744.648135] Error Source : Target NIU
[ 744.648208] Error Description : Target time-out error
[ 744.648306] Packet header Lock : 0
[ 744.648377] Packet header Len1 : 3
[ 744.648448] NOC protocol version : version >= 2.7
[ 744.648537] ErrLog1 : 0x156e00
[ 744.648600] ErrLog2 : 0x0
[ 744.648791] RouteId : 0x156e00
[ 744.649057] InitFlow : cpu_p_i/I/0
[ 744.649345] Targflow : cbb_t/T/0
[ 744.649636] TargSubRange : 23
[ 744.649880] SeqId : 0
[ 744.650094] ErrLog3 : 0x100004
[ 744.650348] ErrLog4 : 0x0
[ 744.652822] Address : 0x100004 (unknown device)
[ 744.657658] ErrLog5 : 0x387e3f
[ 744.660647] Master ID : RCE
[ 744.663786] Security Group(GRPSEC): 0x3f
[ 744.667811] Cache : 0xf -- Cacheable
[ 744.671837] Protection : 0x3 -- Privileged, Non-Secure, Data Access
[ 744.678745] FALCONSEC : 0x0
[ 744.681893] Virtual Queuing Channel(VQC): 0x0
[ 744.686363] **************************************
[ 746.659733] tegra186-cam-rtcpu bc00000.rtcpu: command: 0x00000000: response timeout
[ 746.659969] tegra186-cam-rtcpu bc00000.rtcpu: rce full reset, retry 1/2
[ 746.668809] CPU:0, Error:RCE-NOC@0xbe00000,irq=484
[ 746.668938] **************************************
[ 746.669028] * For more Internal Decode Help
[ 746.669104] * http://nv/cbberr
[ 746.669169] * NVIDIA userID is required to access
[ 746.669251] **************************************
[ 746.669336] CPU:0, Error:RCE-NOC
[ 746.669400] Error Logger : 1
[ 746.669469] ErrLog0 : 0x80030600
[ 746.669539] Transaction Type : RD - Read, Incrementing
[ 746.669631] Error Code : TMO
[ 746.669703] Error Source : Target NIU
[ 746.669778] Error Description : Target time-out error
[ 746.669883] Packet header Lock : 0
[ 746.669948] Packet header Len1 : 3
[ 746.670014] NOC protocol version : version >= 2.7
[ 746.670099] ErrLog1 : 0x156e00
[ 746.670190] ErrLog2 : 0x0
[ 746.670388] RouteId : 0x156e00
[ 746.670662] InitFlow : cpu_p_i/I/0
[ 746.670941] Targflow : cbb_t/T/0
[ 746.671218] TargSubRange : 23
[ 746.671492] SeqId : 0
[ 746.673763] ErrLog3 : 0x100004
[ 746.676999] ErrLog4 : 0x0
[ 746.679540] Address : 0x100004 (unknown device)
[ 746.684615] ErrLog5 : 0x387e3f
[ 746.687602] Master ID : RCE
[ 746.690744] Security Group(GRPSEC): 0x3f
[ 746.691676] tegra194-vi5 15c10000.vi: no reply from camera processor
[ 746.691683] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[ 746.703652] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[ 746.703790] ------------[ cut here ]------------
[ 746.703808] WARNING: CPU: 1 PID: 6835 at /home/vu/Desktop/Projects/JetsonXavier/public_sources/kernel/nvidia/drivers/platform/tegra/rtcpu/capture-ivc.c:86 tegra_capture_ivc_tx+0x11c/0x150
[ 746.704030] ---[ end trace f99f597a44db4881 ]---
[ 746.704127] tegra194-vi5 15c10000.vi: IVC control submit failed
[ 746.704138] video4linux video1: vi capture release failed
[ 746.704142] tegra194-vi5 15c10000.vi: fatal: error recovery failed
[ 746.759959] Cache : 0xf -- Cacheable
[ 746.764436] Protection : 0x3 -- Privileged, Non-Secure, Data Access
[ 746.770821] FALCONSEC : 0x0
[ 746.774214] Virtual Queuing Channel(VQC): 0x0
[ 746.778598] **************************************
[ 748.675621] tegra186-cam-rtcpu bc00000.rtcpu: command: 0x00000000: empty mailbox timeout
[ 748.675809] tegra186-cam-rtcpu bc00000.rtcpu: rce full reset, retry 2/2
[ 748.684681] CPU:0, Error:RCE-NOC@0xbe00000,irq=484
[ 748.684851] **************************************
[ 748.684947] * For more Internal Decode Help
[ 748.685025] * http://nv/cbberr
[ 748.685088] * NVIDIA userID is required to access
[ 748.685181] **************************************
[ 748.685266] CPU:0, Error:RCE-NOC
[ 748.685330] Error Logger : 1
[ 748.685400] ErrLog0 : 0x80030600
[ 748.685477] Transaction Type : RD - Read, Incrementing
[ 748.685574] Error Code : TMO
[ 748.685640] Error Source : Target NIU
[ 748.685714] Error Description : Target time-out error
[ 748.685839] Packet header Lock : 0
[ 748.685907] Packet header Len1 : 3
[ 748.685975] NOC protocol version : version >= 2.7
[ 748.686062] ErrLog1 : 0x156e00
[ 748.686125] ErrLog2 : 0x0
[ 748.686270] RouteId : 0x156e00
[ 748.686523] InitFlow : cpu_p_i/I/0
[ 748.686802] Targflow : cbb_t/T/0
[ 748.687075] TargSubRange : 23
[ 748.687335] SeqId : 0
[ 748.689833] ErrLog3 : 0x100004
[ 748.693328] ErrLog4 : 0x0
[ 748.695876] Address : 0x100004 (unknown device)
[ 748.700695] ErrLog5 : 0x387e3f
[ 748.704194] Master ID : RCE
[ 748.707075] Security Group(GRPSEC): 0x3f
[ 748.711362] Cache : 0xf -- Cacheable
[ 748.715127] Protection : 0x3 -- Privileged, Non-Secure, Data Access
[ 748.721775] FALCONSEC : 0x0
[ 748.725187] Virtual Queuing Channel(VQC): 0x0
[ 748.729651] **************************************
[ 750.070889] Unable to handle kernel NULL pointer dereference at virtual address 00000000
[ 750.071068] Mem abort info:
[ 750.071131] ESR = 0x96000005
[ 750.071201] Exception class = DABT (current EL), IL = 32 bits
[ 750.071307] SET = 0, FnV = 0
[ 750.071367] EA = 0, S1PTW = 0
[ 750.071442] Data abort info:
[ 750.071585] ISV = 0, ISS = 0x00000005
[ 750.071670] CM = 0, WnR = 0
[ 750.071735] user pgtable: 4k pages, 39-bit VAs, pgd = ffffffc3a9ad9000
[ 750.071850] [0000000000000000] *pgd=0000000000000000, *pud=0000000000000000
[ 750.072006] Internal error: Oops: 96000005 [#1] PREEMPT SMP
[ 750.072112] Modules linked in: overlay nvs_bmi160 nvs nvgpu bluedroid_pm ip_tables x_tables
[ 750.072415] CPU: 0 PID: 6833 Comm: v4l2-ctl Tainted: G W 4.9.140-tegra #187
[ 750.072557] Hardware name: jetson-xavier (DT)
[ 750.072735] task: ffffffc3c3abf000 task.stack: ffffffc3d0040000
[ 750.073197] PC is at exit_creds+0x2c/0x78
[ 750.073518] LR is at __put_task_struct+0x4c/0x140
[ 750.073869] pc : [<ffffff80080def7c>] lr : [<ffffff80080b01ac>] pstate: 60400045
[ 750.078891] sp : ffffffc3d0043a10
[ 750.082126] x29: ffffffc3d0043a10 x28: 0000000000000008
[ 750.087932] x27: ffffff8008f52000 x26: ffffffc3d0043de8
[ 750.093254] x25: ffffffc3d2c8d468 x24: ffffffc3dabd7238
[ 750.098856] x23: 0000000000000001 x22: ffffffc3daaa5718
[ 750.104607] x21: ffffffc3d2cfc630 x20: 0000000000000000
[ 750.109708] x19: ffffffc3d2cfc600 x18: 000000000000020e
[ 750.115456] x17: 0000007faef1f698 x16: 0000000000000000
[ 750.121005] x15: 00000000000003e3 x14: 00000000000b2100
[ 750.126676] x13: 0000000000000411 x12: 0000000000000052
[ 750.132453] x11: 0000000000000052 x10: 0000000000000a20
[ 750.137959] x9 : ffffffc3d0043860 x8 : ffffffc3c3abfa80
[ 750.144003] x7 : ffffffc3ffe31b28 x6 : 0000000580bd6c89
[ 750.149248] x5 : 0000000000000400 x4 : 0000000000000000
[ 750.154834] x3 : 00000000000000b0 x2 : 0000000000000000
[ 750.160169] x1 : 0000000000000000 x0 : 00000000ffffffff
[ 750.165258]
[ 750.166925] Process v4l2-ctl (pid: 6833, stack limit = 0xffffffc3d0040000)
[ 750.173326] Call trace:
[ 750.175936] [<ffffff80080def7c>] exit_creds+0x2c/0x78
[ 750.180486] [<ffffff80080b01ac>] __put_task_struct+0x4c/0x140
[ 750.186078] [<ffffff80080dca3c>] kthread_stop+0x1e4/0x1e8
[ 750.191157] [<ffffff8008b2ff38>] vi5_channel_stop_kthreads+0x40/0x58
[ 750.197281] [<ffffff8008b2ffdc>] vi5_channel_stop_streaming+0x8c/0xa8
[ 750.203148] [<ffffff8008b230ac>] tegra_channel_stop_streaming+0x34/0x48
[ 750.209636] [<ffffff8008b1b42c>] __vb2_queue_cancel+0x34/0x188
[ 750.215212] [<ffffff8008b1c954>] vb2_core_queue_release+0x2c/0x58
[ 750.220815] [<ffffff8008b1efd4>] _vb2_fop_release+0x84/0xa0
[ 750.226156] [<ffffff8008b252f8>] tegra_channel_close+0x58/0x130
[ 750.232107] [<ffffff8008af85e0>] v4l2_release+0x48/0xa0
[ 750.237187] [<ffffff800825e518>] __fput+0x90/0x1d0
[ 750.241731] [<ffffff800825e6d0>] ____fput+0x20/0x30
[ 750.246573] [<ffffff80080d9bf4>] task_work_run+0xbc/0xd8
[ 750.252318] [<ffffff80080b9674>] do_exit+0x2c4/0xa08
[ 750.256957] [<ffffff80080b9e48>] do_group_exit+0x40/0xa8
[ 750.262559] [<ffffff80080c7744>] get_signal+0x26c/0x578
[ 750.267466] [<ffffff800808b150>] do_signal+0x130/0x500
[ 750.272729] [<ffffff800808b698>] do_notify_resume+0x90/0xb0
[ 750.278309] [<ffffff8008083754>] work_pending+0x8/0x10
[ 750.283391] ---[ end trace f99f597a44db4882 ]---
[ 750.303608] Fixing recursive fault but reboot is needed!
[ 750.691567] tegra186-cam-rtcpu bc00000.rtcpu: command: 0x00000000: empty mailbox timeout
[ 750.692389] tegra186-cam-rtcpu bc00000.rtcpu: Alert: Camera RTCPU gone bad! restoring it immediately!!
[ 750.702290] CPU:0, Error:RCE-NOC@0xbe00000,irq=484
[ 750.702417] **************************************
[ 750.702516] * For more Internal Decode Help
[ 750.702595] * http://nv/cbberr
[ 750.702660] * NVIDIA userID is required to access
[ 750.702744] **************************************
[ 750.702829] CPU:0, Error:RCE-NOC
[ 750.702906] Error Logger : 1
[ 750.702998] ErrLog0 : 0x80030600
[ 750.703068] Transaction Type : RD - Read, Incrementing
[ 750.703160] Error Code : TMO
[ 750.703220] Error Source : Target NIU
[ 750.703335] Error Description : Target time-out error
[ 750.703429] Packet header Lock : 0
[ 750.703496] Packet header Len1 : 3
[ 750.703561] NOC protocol version : version >= 2.7
[ 750.703648] ErrLog1 : 0x156e00
[ 750.703713] ErrLog2 : 0x0
[ 750.703877] RouteId : 0x156e00
[ 750.704134] InitFlow : cpu_p_i/I/0
[ 750.704437] Targflow : cbb_t/T/0
[ 750.704689] TargSubRange : 23
[ 750.705602] SeqId : 0
[ 750.708765] ErrLog3 : 0x100004
[ 750.711990] ErrLog4 : 0x0
[ 750.714498] Address : 0x100004 (unknown device)
[ 750.719619] ErrLog5 : 0x387e3f
[ 750.722584] Master ID : RCE
[ 750.725735] Security Group(GRPSEC): 0x3f
[ 750.730017] Cache : 0xf -- Cacheable
[ 750.734041] Protection : 0x3 -- Privileged, Non-Secure, Data Access
[ 750.740689] FALCONSEC : 0x0
[ 750.743579] Virtual Queuing Channel(VQC): 0x0
[ 750.748566] **************************************
[ 752.707479] tegra186-cam-rtcpu bc00000.rtcpu: command: 0x00000000: empty mailbox timeout
[ 752.707658] tegra186-cam-rtcpu bc00000.rtcpu: rce full reset, retry 1/2
[ 752.716559] CPU:0, Error:RCE-NOC@0xbe00000,irq=484
[ 752.716686] **************************************
[ 752.716776] * For more Internal Decode Help
[ 752.716853] * http://nv/cbberr
[ 752.716919] * NVIDIA userID is required to access
[ 752.717000] **************************************
[ 752.717085] CPU:0, Error:RCE-NOC
[ 752.717148] Error Logger : 1
[ 752.717217] ErrLog0 : 0x80030600
[ 752.717285] Transaction Type : RD - Read, Incrementing
[ 752.717384] Error Code : TMO
[ 752.717446] Error Source : Target NIU
[ 752.717532] Error Description : Target time-out error
[ 752.717626] Packet header Lock : 0
[ 752.717695] Packet header Len1 : 3
[ 752.717761] NOC protocol version : version >= 2.7
[ 752.717845] ErrLog1 : 0x156e00
[ 752.717942] ErrLog2 : 0x0
[ 752.718145] RouteId : 0x156e00
[ 752.718389] InitFlow : cpu_p_i/I/0
[ 752.718687] Targflow : cbb_t/T/0
[ 752.718978] TargSubRange : 23
[ 752.719239] SeqId : 0
[ 752.721949] ErrLog3 : 0x100004
[ 752.725186] ErrLog4 : 0x0
[ 752.727955] Address : 0x100004 (unknown device)
[ 752.732542] ErrLog5 : 0x387e3f
[ 752.736038] Master ID : RCE
[ 752.739186] Security Group(GRPSEC): 0x3f
[ 752.743222] Cache : 0xf -- Cacheable
[ 752.747238] Protection : 0x3 -- Privileged, Non-Secure, Data Access
[ 752.753889] FALCONSEC : 0x0
[ 752.756777] Virtual Queuing Channel(VQC): 0x0
[ 752.761764] **************************************
[ 754.723423] tegra186-cam-rtcpu bc00000.rtcpu: command: 0x00000000: empty mailbox timeout
[ 754.723604] tegra186-cam-rtcpu bc00000.rtcpu: rce full reset, retry 2/2
[ 754.732480] CPU:0, Error:RCE-NOC@0xbe00000,irq=484
[ 754.732601] **************************************
[ 754.732691] * For more Internal Decode Help
[ 754.732766] * http://nv/cbberr
[ 754.732831] * NVIDIA userID is required to access
[ 754.732924] **************************************
[ 754.733013] CPU:0, Error:RCE-NOC
[ 754.733101] Error Logger : 1
[ 754.733178] ErrLog0 : 0x80030600
[ 754.733246] Transaction Type : RD - Read, Incrementing
[ 754.733342] Error Code : TMO
[ 754.733449] Error Source : Target NIU
[ 754.733524] Error Description : Target time-out error
[ 754.733625] Packet header Lock : 0
[ 754.733690] Packet header Len1 : 3
[ 754.733781] NOC protocol version : version >= 2.7
[ 754.733867] ErrLog1 : 0x156e00
[ 754.733932] ErrLog2 : 0x0
[ 754.734056] RouteId : 0x156e00
[ 754.734322] InitFlow : cpu_p_i/I/0
[ 754.734620] Targflow : cbb_t/T/0
[ 754.734898] TargSubRange : 23
[ 754.735153] SeqId : 0
[ 754.737907] ErrLog3 : 0x100004
[ 754.741135] ErrLog4 : 0x0
[ 754.743658] Address : 0x100004 (unknown device)
[ 754.748747] ErrLog5 : 0x387e3f
[ 754.751738] Master ID : RCE
[ 754.754877] Security Group(GRPSEC): 0x3f
[ 754.758900] Cache : 0xf -- Cacheable
[ 754.763187] Protection : 0x3 -- Privileged, Non-Secure, Data Access
[ 754.769834] FALCONSEC : 0x0
[ 754.772982] Virtual Queuing Channel(VQC): 0x0
[ 754.777709] **************************************
[ 756.739358] tegra186-cam-rtcpu bc00000.rtcpu: command: 0x00000000: empty mailbox timeout
[ 756.740023] tegra186-cam-rtcpu bc00000.rtcpu: Alert: Camera RTCPU gone bad! restoring it immediately!!
[ 756.749937] CPU:0, Error:RCE-NOC@0xbe00000,irq=484
[ 756.750057] **************************************
[ 756.750144] * For more Internal Decode Help
[ 756.750219] * http://nv/cbberr
[ 756.750283] * NVIDIA userID is required to access
[ 756.750383] **************************************
[ 756.750476] CPU:0, Error:RCE-NOC
[ 756.750543] Error Logger : 1
[ 756.750615] ErrLog0 : 0x80030600
[ 756.750686] Transaction Type : RD - Read, Incrementing
[ 756.750784] Error Code : TMO
[ 756.750848] Error Source : Target NIU
[ 756.750924] Error Description : Target time-out error
[ 756.751018] Packet header Lock : 0
[ 756.751087] Packet header Len1 : 3
[ 756.751155] NOC protocol version : version >= 2.7
[ 756.751242] ErrLog1 : 0x156e00
[ 756.751306] ErrLog2 : 0x0
[ 756.751520] RouteId : 0x156e00
[ 756.751776] InitFlow : cpu_p_i/I/0
[ 756.752088] Targflow : cbb_t/T/0
[ 756.752347] TargSubRange : 23
[ 756.753665] SeqId : 0
[ 756.756294] ErrLog3 : 0x100004
[ 756.759811] ErrLog4 : 0x0
[ 756.762579] Address : 0x100004 (unknown device)
[ 756.767143] ErrLog5 : 0x387e3f
[ 756.770641] Master ID : RCE
[ 756.773789] Security Group(GRPSEC): 0x3f
[ 756.777815] Cache : 0xf -- Cacheable
[ 756.781857] Protection : 0x3 -- Privileged, Non-Secure, Data Access
[ 756.788493] FALCONSEC : 0x0
[ 756.791381] Virtual Queuing Channel(VQC): 0x0
[ 756.796367] **************************************
[ 758.755238] tegra186-cam-rtcpu bc00000.rtcpu: command: 0x00000000: empty mailbox timeout
[ 758.755414] tegra186-cam-rtcpu bc00000.rtcpu: rce full reset, retry 1/2
[ 758.765278] CPU:0, Error:RCE-NOC@0xbe00000,irq=484
[ 758.765396] **************************************
[ 758.765504] * For more Internal Decode Help
[ 758.765586] * http://nv/cbberr
[ 758.765648] * NVIDIA userID is required to access
[ 758.765727] **************************************
[ 758.765808] CPU:0, Error:RCE-NOC
[ 758.765872] Error Logger : 1
[ 758.765965] ErrLog0 : 0x80030600
[ 758.766052] Transaction Type : RD - Read, Incrementing
[ 758.766149] Error Code : TMO
[ 758.766215] Error Source : Target NIU
[ 758.766291] Error Description : Target time-out error
[ 758.766384] Packet header Lock : 0
[ 758.766454] Packet header Len1 : 3
[ 758.766523] NOC protocol version : version >= 2.7
[ 758.766610] ErrLog1 : 0x156e00
[ 758.766674] ErrLog2 : 0x0
[ 758.766869] RouteId : 0x156e00
[ 758.767128] InitFlow : cpu_p_i/I/0
[ 758.767419] Targflow : cbb_t/T/0
[ 758.767678] TargSubRange : 23
[ 758.767950] SeqId : 0
[ 758.769714] ErrLog3 : 0x100004
[ 758.772943] ErrLog4 : 0x0
[ 758.775734] Address : 0x100004 (unknown device)
[ 758.780556] ErrLog5 : 0x387e3f
[ 758.783536] Master ID : RCE
[ 758.786684] Security Group(GRPSEC): 0x3f
[ 758.790965] Cache : 0xf -- Cacheable
[ 758.794992] Protection : 0x3 -- Privileged, Non-Secure, Data Access
[ 758.801386] FALCONSEC : 0x0
[ 758.804533] Virtual Queuing Channel(VQC): 0x0
[ 758.809259] **************************************
I’m wondering is there any way to check the correctness of MIPI data on Xavier side?
Any suggestion would be very appreciated.
Thanks and Best Regards,
Vu Nguyen
