My hardware is max96712 connected to xavier. Max96712 output is 1x4, muxed four cameras from four max9295. Our I2C is OK. When enter preview command, only one picture appeared on the screen and then stopped preview.
Are there any special configurations that I should pay attention to when using virtual channel and camera mux? Do you have xavier configuration file for max96712 output 1x4 csi lane? If the xavier csi clk frequency should raise up when the xavier receive 1X4 csi lane?
I would suggest consult with vendor to confirm the configure. Also current only have imx390 as virtual channel reference.
Hi, ShaneCCC
Our deser chip output 1.5Gbps/lane. Our SerDes Pixel Clock setting is 833333333, which is copied from other dtsi file. The nvidia official website says: “The SerDes pixel clock must be set based on the use case (on the number of cameras connected to SerDes). If you are not sure which use case to adopt, set it to the SerDes maximum output rate”
What is “SerDes maximum output rate” ? Where can I get “SerDes maximum output rate”?
The SerDes maximum output rate should be consult with vendor.
During bring up you can boost the NVCSI/VI/ISP clock to max to ignore the serdes_pix_clk_hz configure it have concern for it.
sudo su
echo 1 > /sys/kernel/debug/bpmp/debug/clk/vi/mrq_rate_locked
echo 1 > /sys/kernel/debug/bpmp/debug/clk/isp/mrq_rate_locked
echo 1 > /sys/kernel/debug/bpmp/debug/clk/nvcsi/mrq_rate_locked
cat /sys/kernel/debug/bpmp/debug/clk/vi/max_rate |tee /sys/kernel/debug/bpmp/debug/clk/vi/rate
cat /sys/kernel/debug/bpmp/debug/clk/isp/max_rate | tee /sys/kernel/debug/bpmp/debug/clk/isp/rate
cat /sys/kernel/debug/bpmp/debug/clk/nvcsi/max_rate | tee /sys/kernel/debug/bpmp/debug/clk/nvcsi/rate
Hi, ShaneCCC,
My log is very similar to rtcpu_nvcsi_intr on Jetson Xavier
Many “rtcpu_nvcsi_intr” log occured and no other logs.
tracer: nop
entries-in-buffer/entries-written: 3061/3061 #P:4
_-----=> irqs-off
/ _----=> need-resched
| / _—=> hardirq/softirq
|| / _–=> preempt-depth
||| / delay
TASK-PID CPU# |||| TIMESTAMP FUNCTION
v4l2-ctl-9074 [000] .... 280.310044: tegra_channel_open: vi-output, imx390 2-001b
v4l2-ctl-9074 [000] .... 280.312362: tegra_channel_set_power: imx390 2-001b : 0x1
v4l2-ctl-9074 [000] .... 280.312391: camera_common_s_power: status : 0x1
v4l2-ctl-9074 [000] .... 280.312452: tegra_channel_set_power: 15a00000.nvcsi--4 : 0x1
v4l2-ctl-9074 [000] .... 280.312456: csi_s_power: enable : 0x1
v4l2-ctl-9074 [000] .... 280.328025: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt 13
v4l2-ctl-9074 [001] .... 280.349832: tegra_channel_set_stream: enable : 0x1
v4l2-ctl-9074 [001] .... 280.357916: tegra_channel_set_stream: 15a00000.nvcsi--4 : 0x1
v4l2-ctl-9074 [001] .... 280.357922: csi_s_stream: enable : 0x1
v4l2-ctl-9074 [001] .... 280.357932: tegra_channel_set_stream: imx390 2-001b : 0x1
kworker/0:2-1187 [000] .... 280.385325: rtos_queue_peek_from_isr_failed: tstamp:9291911965 queue:0x0bcbbbb8
kworker/0:2-1187 [000] .... 280.385330: rtcpu_start: tstamp:9291915697
kworker/0:2-1187 [000] .... 280.385333: rtos_queue_send_from_isr_failed: tstamp:9292044779 queue:0x0bcb2e38
kworker/0:2-1187 [000] .... 280.385334: rtos_queue_send_from_isr_failed: tstamp:9292045001 queue:0x0bcb76a0
kworker/0:2-1187 [000] .... 280.385335: rtos_queue_send_from_isr_failed: tstamp:9292045224 queue:0x0bcb9220
kworker/0:2-1187 [000] .... 280.385336: rtos_queue_send_from_isr_failed: tstamp:9292045443 queue:0x0bcb9fe0
kworker/0:2-1187 [000] .... 280.385337: rtos_queue_send_from_isr_failed: tstamp:9292045666 queue:0x0bcbada0
kworker/0:2-1187 [000] .... 280.385339: rtcpu_string: tstamp:9292046286 id:0x04010000 str:"Configuring VI GoS.
kworker/0:2-1187 [000] … 280.385352: rtcpu_string: tstamp:9292046602 id:0x04010000 str:"VM GOS[#0 ] addr=0xc2100000
kworker/0:2-1187 [000] … 280.385396: rtcpu_string: tstamp:9292046928 id:0x04010000 str:"VM GOS[#1 ] addr=0xc2101000
kworker/0:2-1187 [000] … 280.385401: rtcpu_string: tstamp:9292047244 id:0x04010000 str:"VM GOS[#2 ] addr=0xc2102000
kworker/0:2-1187 [000] … 280.385406: rtcpu_string: tstamp:9292047550 id:0x04010000 str:"VM GOS[#3 ] addr=0xc2103000
kworker/0:2-1187 [000] … 280.385410: rtcpu_string: tstamp:9292047892 id:0x04010000 str:"VM GOS[#4 ] addr=0xc2104000
kworker/0:2-1187 [000] … 280.385415: rtcpu_string: tstamp:9292048198 id:0x04010000 str:"VM GOS[#5 ] addr=0xc2105000
kworker/0:2-1187 [000] … 280.385419: rtcpu_string: tstamp:9292056340 id:0x04010000 str:“vi5_hwinit: firmware CL2018101701 protocol vers”
kworker/0:2-1187 [000] … 280.385423: rtcpu_string: tstamp:9292056531 id:0x04010000 str:"on 2.2
kworker/0:2-1187 [000] … 280.385428: rtos_queue_send_from_isr_failed: tstamp:9292084399 queue:0x0bcb2e38
kworker/0:2-1187 [000] … 280.385428: rtos_queue_send_from_isr_failed: tstamp:9292084662 queue:0x0bcb76a0
kworker/0:2-1187 [000] … 280.385429: rtos_queue_send_from_isr_failed: tstamp:9292084890 queue:0x0bcb9220
kworker/0:2-1187 [000] … 280.385430: rtos_queue_send_from_isr_failed: tstamp:9292085110 queue:0x0bcb9fe0
kworker/0:2-1187 [000] … 280.385431: rtos_queue_send_from_isr_failed: tstamp:9292085330 queue:0x0bcbada0
kworker/0:2-1187 [000] … 280.385432: rtcpu_string: tstamp:9292086602 id:0x04010000 str:"VI GOS[#0 ] set to VM GOS[4] base 0xc2104000
kworker/0:2-1187 [000] … 280.385465: rtos_queue_send_from_isr_failed: tstamp:9292342782 queue:0x0bcb2e38
kworker/0:2-1187 [000] … 280.385466: rtos_queue_send_from_isr_failed: tstamp:9292342942 queue:0x0bcb76a0
kworker/0:2-1187 [000] … 280.385467: rtos_queue_send_from_isr_failed: tstamp:9292343106 queue:0x0bcb9220
kworker/0:2-1187 [000] … 280.385468: rtos_queue_send_from_isr_failed: tstamp:9292343263 queue:0x0bcb9fe0
kworker/0:2-1187 [000] … 280.385469: rtos_queue_send_from_isr_failed: tstamp:9292343420 queue:0x0bcbada0
kworker/0:2-1187 [000] … 280.385471: rtcpu_nvcsi_intr: tstamp:9292346012 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000001
kworker/0:2-1187 [000] … 280.385473: rtcpu_vinotify_event: tstamp:9292369076 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:9584001568 data:0x10000000
kworker/0:2-1187 [000] … 280.385474: rtcpu_vinotify_event: tstamp:9292369234 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:9584005312 data:0x31000001
kworker/0:2-1187 [000] … 280.385475: rtcpu_vinotify_event: tstamp:9292369412 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:9584006304 data:0x07020001
kworker/0:2-1187 [000] … 280.385476: rtcpu_vinotify_event: tstamp:9292369557 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:9584065280 data:0x10000000
kworker/0:2-1187 [000] … 280.385477: rtcpu_vinotify_event: tstamp:9292369727 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:9584069248 data:0x31000002
kworker/0:2-1187 [000] … 280.385477: rtcpu_nvcsi_intr: tstamp:9292398272 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
kworker/0:2-1187 [000] … 280.385478: rtcpu_nvcsi_intr: tstamp:9292398272 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
kworker/0:2-1187 [000] … 280.385479: rtcpu_nvcsi_intr: tstamp:9292398272 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000e00
kworker/0:2-1187 [000] … 280.385480: rtcpu_nvcsi_intr: tstamp:9292398272 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:1 st:0 vc:0 status:0x00000600
kworker/0:2-1187 [000] … 280.385481: rtcpu_nvcsi_intr: tstamp:9292482704 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
kworker/0:2-1187 [000] … 280.385482: rtcpu_nvcsi_intr: tstamp:9292482704 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
kworker/0:2-1187 [000] … 280.385483: rtcpu_nvcsi_intr: tstamp:9292482704 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000e00
kworker/0:2-1187 [000] … 280.385484: rtcpu_nvcsi_intr: tstamp:9292482704 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:1 st:0 vc:0 status:0x00000600
kworker/0:2-1187 [000] … 280.385485: rtcpu_nvcsi_intr: tstamp:9292502208 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
kworker/0:2-1187 [000] … 280.385486: rtcpu_nvcsi_intr: tstamp:9292502208 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
kworker/0:2-1187 [000] … 280.385486: rtcpu_nvcsi_intr: tstamp:9292502208 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000e00
kworker/0:2-1187 [000] … 280.385487: rtcpu_nvcsi_intr: tstamp:9292502208 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:1 st:0 vc:0 status:0x00000600
kworker/0:2-1187 [000] … 280.385488: rtcpu_nvcsi_intr: tstamp:9292550295 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
kworker/0:2-1187 [000] … 280.385489: rtcpu_nvcsi_intr: tstamp:9292550295 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
kworker/0:2-1187 [000] … 280.385490: rtcpu_nvcsi_intr: tstamp:9292550295 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000e00
kworker/0:2-1187 [000] … 280.385491: rtcpu_nvcsi_intr: tstamp:9292550295 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:1 st:0 vc:0 status:0x00000600
kworker/0:2-1187 [000] … 280.385492: rtcpu_nvcsi_intr: tstamp:9292560298 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x06000000
kworker/0:2-1187 [000] … 280.385493: rtcpu_nvcsi_intr: tstamp:9292560298 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
kworker/0:2-1187 [000] … 280.385494: rtcpu_nvcsi_intr: tstamp:9292560298 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000600
kworker/0:2-1187 [000] … 280.385495: rtcpu_nvcsi_intr: tstamp:9292560298 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:1 st:0 vc:0 status:0x00000600
kworker/0:2-1187 [000] … 280.385515: rtcpu_nvcsi_intr: tstamp:9292577888 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
kworker/0:2-1187 [000] … 280.385516: rtcpu_nvcsi_intr: tstamp:9292577888 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
kworker/0:2-1187 [000] … 280.385517: rtcpu_nvcsi_intr: tstamp:9292577888 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000e00
kworker/0:2-1187 [000] … 280.385518: rtcpu_nvcsi_intr: tstamp:9292577888 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:1 st:0 vc:0 status:0x00000600
kworker/0:2-1187 [000] … 280.385518: rtcpu_nvcsi_intr: tstamp:9292591959 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
kworker/0:2-1187 [000] … 280.385519: rtcpu_nvcsi_intr: tstamp:9292591959 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
kworker/0:2-1187 [000] … 280.385520: rtcpu_nvcsi_intr: tstamp:9292591959 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000e00
kworker/0:2-1187 [000] … 280.385521: rtcpu_nvcsi_intr: tstamp:9292591959 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:1 st:0 vc:0 status:0x00000600
kworker/0:2-1187 [000] … 280.385522: rtcpu_nvcsi_intr: tstamp:9292605663 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
kworker/0:2-1187 [000] … 280.385523: rtcpu_nvcsi_intr: tstamp:9292605663 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
kworker/0:2-1187 [000] … 280.385524: rtcpu_nvcsi_intr: tstamp:9292605663 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000e00
kworker/0:2-1187 [000] … 280.385525: rtcpu_nvcsi_intr: tstamp:9292605663 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:1 st:0 vc:0 status:0x00000600
kworker/0:2-1187 [000] … 280.385526: rtcpu_nvcsi_intr: tstamp:9292629000 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
kworker/0:2-1187 [000] … 280.385527: rtcpu_nvcsi_intr: tstamp:9292629000 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
kworker/0:2-1187 [000] … 280.385527: rtcpu_nvcsi_intr: tstamp:9292629000 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000e00
kworker/0:2-1187 [000] … 280.385528: rtcpu_nvcsi_intr: tstamp:9292629000 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:1 st:0 vc:0 status:0x00000600
kworker/0:2-1187 [000] … 280.385529: rtcpu_nvcsi_intr: tstamp:9292670661 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
kworker/0:2-1187 [000] … 280.385530: rtcpu_nvcsi_intr: tstamp:9292670661 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
kworker/0:2-1187 [000] … 280.385531: rtcpu_nvcsi_intr: tstamp:9292670661 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000e00
kworker/0:2-1187 [000] … 280.385532: rtcpu_nvcsi_intr: tstamp:9292670661 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:1 st:0 vc:0 status:0x00000600
kworker/0:2-1187 [000] … 280.385533: rtcpu_nvcsi_intr: tstamp:9292693740 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
kworker/0:2-1187 [000] … 280.385534: rtcpu_nvcsi_intr: tstamp:9292693740 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
kworker/0:2-1187 [000] … 280.385535: rtcpu_nvcsi_intr: tstamp:9292693740 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000e00
kworker/0:2-1187 [000] … 280.385536: rtcpu_nvcsi_intr: tstamp:9292693740 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:1 st:0 vc:0 status:0x00000600
After I boost the boost the NVCSI/VI/ISP clocks, the log is still filled with “rtcpu_nvcsi_intr” and no other logs.
Do you confirm the reason is rxfifo full?
ShaneCCC:
We use port A which is configured as 1 clk and 4 data lane. Should serdes_pix_clk_hz be set to 1 lane speed or 4 times 1 lane speed?
The error looks like could be HW problem. Have a check the REG NVCSI_PHY_0_CILA_INTR_0_STATUS_CILA_0 in TRM for below error.
If sensor is not sending de-skew sequence, then there should be error on the link which cause the NVCSI CIL detect a de-skew sync word (0xFF) instead of 0xB8 sync word
Hi,ShansCCC:
What kind of HW problem could result in the problem of detecting de-skew sync word (0xFF)?PCB or logic design?
Sorry for typo to confuse it. Not sure if any HW issue, however it could be the output MIPI package didn’t follow MIPI spec send 0xD8 sync word at beginning.
Hi, ShaneCCC
After fixing hardware problem, our Xavier can display one picture on the screen, but can not continue previewing. And log become like the following:
Can you help to analyze why only one picture can be displayed on the screen? Why can not continue previewing?
Thanks a lot.
Summary
entries-in-buffer/entries-written: 678/678 #P:4
_-----=> irqs-off
||| / delay
v4l2-ctl-11320 [002] .... 550.996228: tegra_channel_open: vi-output, imx390 2-001b
v4l2-ctl-11320 [001] .... 550.999096: tegra_channel_set_power: imx390 2-001b : 0x1
v4l2-ctl-11320 [001] .... 550.999112: camera_common_s_power: status : 0x1
v4l2-ctl-11320 [001] .... 550.999177: tegra_channel_set_power: 15a00000.nvcsi--4 : 0x1
v4l2-ctl-11320 [001] .... 550.999181: csi_s_power: enable : 0x1
v4l2-ctl-11320 [000] .... 551.016577: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt 13
v4l2-ctl-11320 [002] .... 551.043574: tegra_channel_set_stream: enable : 0x1
v4l2-ctl-11320 [000] .... 551.063174: tegra_channel_set_stream: 15a00000.nvcsi--4 : 0x1
v4l2-ctl-11320 [000] .... 551.063181: csi_s_stream: enable : 0x1
v4l2-ctl-11320 [000] .... 551.063190: tegra_channel_set_stream: imx390 2-001b : 0x1
kworker/0:3-1803 [000] .... 551.090034: rtos_queue_peek_from_isr_failed: tstamp:17944717325 queue:0x0bcbbbb8
kworker/0:3-1803 [000] .... 551.090038: rtcpu_start: tstamp:17944720332
kworker/0:3-1803 [000] .... 551.090041: rtos_queue_send_from_isr_failed: tstamp:17944853045 queue:0x0bcb2e38
kworker/0:3-1803 [000] .... 551.090043: rtos_queue_send_from_isr_failed: tstamp:17944853269 queue:0x0bcb76a0
kworker/0:3-1803 [000] .... 551.090044: rtos_queue_send_from_isr_failed: tstamp:17944853497 queue:0x0bcb9220
kworker/0:3-1803 [000] .... 551.090045: rtos_queue_send_from_isr_failed: tstamp:17944853716 queue:0x0bcb9fe0
kworker/0:3-1803 [000] .... 551.090046: rtos_queue_send_from_isr_failed: tstamp:17944853936 queue:0x0bcbada0
kworker/0:3-1803 [000] .... 551.090048: rtcpu_string: tstamp:17944854570 id:0x04010000 str:"Configuring VI GoS.
kworker/0:3-1803 [000] … 551.090090: rtcpu_string: tstamp:17944854887 id:0x04010000 str:"VM GOS[#0 ] addr=0xc2100000
kworker/0:3-1803 [000] … 551.090106: rtcpu_string: tstamp:17944855214 id:0x04010000 str:"VM GOS[#1 ] addr=0xc2101000
kworker/0:3-1803 [000] … 551.090120: rtcpu_string: tstamp:17944855537 id:0x04010000 str:"VM GOS[#2 ] addr=0xc2102000
kworker/0:3-1803 [000] … 551.090131: rtcpu_string: tstamp:17944855844 id:0x04010000 str:"VM GOS[#3 ] addr=0xc2103000
kworker/0:3-1803 [000] … 551.090147: rtcpu_string: tstamp:17944856189 id:0x04010000 str:"VM GOS[#4 ] addr=0xc2104000
kworker/0:3-1803 [000] … 551.090158: rtcpu_string: tstamp:17944856497 id:0x04010000 str:"VM GOS[#5 ] addr=0xc2105000
kworker/0:3-1803 [000] … 551.090168: rtcpu_string: tstamp:17944864622 id:0x04010000 str:“vi5_hwinit: firmware CL2018101701 protocol vers”
kworker/0:3-1803 [000] … 551.090170: rtcpu_string: tstamp:17944864825 id:0x04010000 str:"on 2.2
kworker/0:3-1803 [000] … 551.090181: rtos_queue_send_from_isr_failed: tstamp:17944893327 queue:0x0bcb2e38
kworker/0:3-1803 [000] … 551.090183: rtos_queue_send_from_isr_failed: tstamp:17944893588 queue:0x0bcb76a0
kworker/0:3-1803 [000] … 551.090184: rtos_queue_send_from_isr_failed: tstamp:17944893812 queue:0x0bcb9220
kworker/0:3-1803 [000] … 551.090185: rtos_queue_send_from_isr_failed: tstamp:17944894034 queue:0x0bcb9fe0
kworker/0:3-1803 [000] … 551.090186: rtos_queue_send_from_isr_failed: tstamp:17944894252 queue:0x0bcbada0
kworker/0:3-1803 [000] … 551.090187: rtcpu_string: tstamp:17944895514 id:0x04010000 str:"VI GOS[#0 ] set to VM GOS[4] base 0xc2104000
kworker/0:3-1803 [000] … 551.090202: rtcpu_vinotify_event: tstamp:17945225877 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:15890945920 data:0x10000000
kworker/0:3-1803 [000] … 551.090204: rtcpu_vinotify_event: tstamp:17945226093 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:15890949696 data:0x31000001
kworker/0:3-1803 [000] … 551.090205: rtcpu_vinotify_event: tstamp:17945226346 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:15890950688 data:0x07020001
kworker/0:3-1803 [000] … 551.090206: rtcpu_vinotify_event: tstamp:17945226552 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:15891010080 data:0x10000000
kworker/0:3-1803 [000] … 551.090207: rtcpu_vinotify_event: tstamp:17945226800 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:15891013888 data:0x31000002
kworker/0:3-1803 [000] … 551.090208: rtos_queue_send_from_isr_failed: tstamp:17945507250 queue:0x0bcb2e38
kworker/0:3-1803 [000] … 551.090209: rtos_queue_send_from_isr_failed: tstamp:17945507411 queue:0x0bcb76a0
kworker/0:3-1803 [000] … 551.090210: rtos_queue_send_from_isr_failed: tstamp:17945507574 queue:0x0bcb9220
kworker/0:3-1803 [000] … 551.090211: rtos_queue_send_from_isr_failed: tstamp:17945507731 queue:0x0bcb9fe0
kworker/0:3-1803 [000] … 551.090212: rtos_queue_send_from_isr_failed: tstamp:17945507892 queue:0x0bcbada0
kworker/0:3-1803 [000] … 551.090214: rtcpu_nvcsi_intr: tstamp:17945510485 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000089
kworker/0:3-1803 [000] … 551.090216: rtcpu_nvcsi_intr: tstamp:17945510485 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000088
kworker/0:3-1803 [000] … 551.090217: rtcpu_nvcsi_intr: tstamp:17945514417 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000010
kworker/0:3-1803 [000] … 551.090218: rtcpu_nvcsi_intr: tstamp:17945514417 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000010
kworker/0:3-1803 [000] … 551.090219: rtcpu_nvcsi_intr: tstamp:17945515139 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:1 status:0x00000002
kworker/0:3-1803 [000] … 551.090220: rtcpu_nvcsi_intr: tstamp:17945515139 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000010
kworker/0:3-1803 [000] … 551.090221: rtcpu_nvcsi_intr: tstamp:17945515139 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:1 status:0x00000006
kworker/0:3-1803 [000] … 551.090222: rtcpu_nvcsi_intr: tstamp:17945515139 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000010
kworker/0:3-1803 [000] … 551.090224: rtcpu_nvcsi_intr: tstamp:17945516161 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:1 status:0x00000004
kworker/0:3-1803 [000] … 551.090226: rtcpu_vinotify_error: tstamp:17945518807 tag:CSIMUX_STREAM channel:0x00 frame:1 vi_tstamp:17945515092 data:0x00000001
kworker/0:3-1803 [000] … 551.090227: rtcpu_vinotify_error: tstamp:17945519584 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:17945515270 data:0x00000001
kworker/0:3-1803 [000] … 551.090228: rtcpu_vinotify_error: tstamp:17945576840 tag:CHANSEL_NOMATCH channel:0x41 frame:0 vi_tstamp:17945574260 data:0x000003c9
kworker/0:3-1803 [000] … 551.090232: rtcpu_vinotify_event: tstamp:17945713727 tag:CSIMUX_STREAM channel:0x00 frame:1 vi_tstamp:17945515092 data:0x00000001
kworker/0:3-1803 [000] … 551.090233: rtcpu_vinotify_event: tstamp:17945713907 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:17945515270 data:0x00000001
kworker/0:3-1803 [000] … 551.090234: rtcpu_vinotify_event: tstamp:17945714069 tag:FS channel:0x01 frame:0 vi_tstamp:17945559081 data:0x00000010
kworker/0:3-1803 [000] … 551.090235: rtcpu_vinotify_event: tstamp:17945714239 tag:CHANSEL_NOMATCH channel:0x41 frame:0 vi_tstamp:17945574260 data:0x000003c9
kworker/0:3-1803 [000] … 551.090236: rtcpu_vinotify_event: tstamp:17945714384 tag:FS channel:0x00 frame:0 vi_tstamp:17945691584 data:0x00000010
kworker/0:3-1803 [000] … 551.090237: rtcpu_vinotify_event: tstamp:17945714555 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:17945691586 data:0x00000000
kworker/0:3-1803 [000] … 551.090238: rtcpu_vinotify_event: tstamp:17945714707 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:17945706841 data:0x00000001
kworker/0:3-1803 [000] … 551.090239: rtcpu_vinotify_event: tstamp:17945714881 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:15916874240 data:0x08020001
kworker/0:3-1803 [000] … 551.146052: rtcpu_vinotify_error: tstamp:17946618570 tag:CHANSEL_NOMATCH channel:0x41 frame:0 vi_tstamp:17946615787 data:0x000003c9
kworker/0:3-1803 [000] … 551.146057: rtcpu_vinotify_event: tstamp:17946618977 tag:FE channel:0x01 frame:0 vi_tstamp:17946573642 data:0x00000020
kworker/0:3-1803 [000] … 551.146058: rtcpu_vinotify_event: tstamp:17946619150 tag:FS channel:0x01 frame:0 vi_tstamp:17946600607 data:0x00000010
kworker/0:3-1803 [000] … 551.146059: rtcpu_vinotify_event: tstamp:17946619296 tag:CHANSEL_NOMATCH channel:0x41 frame:0 vi_tstamp:17946615787 data:0x000003c9
kworker/0:3-1803 [000] … 551.146060: rtcpu_vinotify_event: tstamp:17947081507 tag:CHANSEL_PXL_EOF channel:0x23 frame:0 vi_tstamp:17946705953 data:0x04370002
kworker/0:3-1803 [000] … 551.146061: rtcpu_vinotify_event: tstamp:17947081656 tag:FE channel:0x00 frame:0 vi_tstamp:17946705970 data:0x00000020
kworker/0:3-1803 [000] … 551.146062: rtcpu_vinotify_event: tstamp:17947081830 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:17946705973 data:0x00000000
kworker/0:3-1803 [000] … 551.146063: rtcpu_vinotify_event: tstamp:17947081978 tag:ATOMP_FRAME_DONE channel:0x23 frame:0 vi_tstamp:17946705982 data:0x00000000
kworker/0:3-1803 [000] … 551.146064: rtcpu_vinotify_event: tstamp:17947082150 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:15948860992 data:0x02020001
kworker/0:3-1803 [000] … 551.146065: rtcpu_vinotify_event: tstamp:17947082294 tag:FS channel:0x00 frame:0 vi_tstamp:17946733112 data:0x00000010
kworker/0:3-1803 [000] … 551.146067: rtcpu_vinotify_event: tstamp:17947082468 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:17946733115 data:0x00000000
kworker/0:3-1803 [000] … 551.146068: rtcpu_vinotify_event: tstamp:17947082613 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:17946748370 data:0x00000001
kworker/0:3-1803 [000] … 551.146069: rtcpu_vinotify_event: tstamp:17947082784 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:15950203168 data:0x08020001
kworker/0:3-1803 [000] … 551.146105: rtcpu_vinotify_error: tstamp:17947659899 tag:CHANSEL_NOMATCH channel:0x41 frame:0 vi_tstamp:17947657317 data:0x000003c9
kworker/0:3-1803 [000] … 551.146106: rtcpu_vinotify_event: tstamp:17947750568 tag:FE channel:0x01 frame:0 vi_tstamp:17947615172 data:0x00000020
kworker/0:3-1803 [000] … 551.146107: rtcpu_vinotify_event: tstamp:17947750739 tag:FS channel:0x01 frame:0 vi_tstamp:17947642136 data:0x00000010
kworker/0:3-1803 [000] … 551.146108: rtcpu_vinotify_event: tstamp:17947750887 tag:CHANSEL_NOMATCH channel:0x41 frame:0 vi_tstamp:17947657317 data:0x000003c9
kworker/0:3-1803 [000] … 551.146109: rtcpu_vinotify_event: tstamp:17947751059 tag:CHANSEL_PXL_EOF channel:0x23 frame:0 vi_tstamp:17947747476 data:0x04370002
kworker/0:3-1803 [000] … 551.146110: rtcpu_vinotify_event: tstamp:17947751209 tag:FE channel:0x00 frame:0 vi_tstamp:17947747494 data:0x00000020
kworker/0:3-1803 [000] … 551.146111: rtcpu_vinotify_event: tstamp:17947751381 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:17947747496 data:0x00000000
kworker/0:3-1803 [000] … 551.146113: rtcpu_vinotify_event: tstamp:17947751530 tag:ATOMP_FRAME_DONE channel:0x23 frame:0 vi_tstamp:17947747503 data:0x00000000
kworker/0:3-1803 [000] … 551.146114: rtcpu_vinotify_error: tstamp:17947792474 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:17947789897 data:0x000003c9
kworker/0:3-1803 [000] … 551.202062: rtcpu_vinotify_event: tstamp:17948203977 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:15982195040 data:0x02020001
kworker/0:3-1803 [000] … 551.202065: rtcpu_vinotify_event: tstamp:17948204128 tag:FS channel:0x00 frame:0 vi_tstamp:17947774640 data:0x00000010
kworker/0:3-1803 [000] … 551.202066: rtcpu_vinotify_event: tstamp:17948204300 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:17947789897 data:0x000003c9
kworker/0:3-1803 [000] … 551.202067: rtcpu_vinotify_event: tstamp:17948692214 tag:FE channel:0x01 frame:0 vi_tstamp:17948656702 data:0x00000020
kworker/0:3-1803 [000] … 551.202068: rtcpu_vinotify_event: tstamp:17948692386 tag:FS channel:0x01 frame:0 vi_tstamp:17948683666 data:0x00000010
kworker/0:3-1803 [000] … 551.202070: rtcpu_vinotify_error: tstamp:17948701411 tag:CHANSEL_NOMATCH channel:0x41 frame:0 vi_tstamp:17948698847 data:0x000003c9
kworker/0:3-1803 [000] … 551.202071: rtcpu_vinotify_error: tstamp:17948834002 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:17948831425 data:0x000003c9
kworker/0:3-1803 [000] … 551.202072: rtcpu_vinotify_event: tstamp:17949180751 tag:CHANSEL_NOMATCH channel:0x41 frame:0 vi_tstamp:17948698847 data:0x000003c9
kworker/0:3-1803 [000] … 551.202073: rtcpu_vinotify_event: tstamp:17949180922 tag:FE channel:0x00 frame:0 vi_tstamp:17948789024 data:0x00000020
kworker/0:3-1803 [000] … 551.202074: rtcpu_vinotify_event: tstamp:17949181070 tag:FS channel:0x00 frame:0 vi_tstamp:17948816168 data:0x00000010
kworker/0:3-1803 [000] … 551.202075: rtcpu_vinotify_event: tstamp:17949181274 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:17948831425 data:0x000003c9
kworker/0:3-1803 [000] … 551.202078: rtos_queue_peek_from_isr_failed: tstamp:17949717718 queue:0x0bcbbbb8
kworker/0:3-1803 [000] … 551.202079: rtcpu_vinotify_error: tstamp:17949742941 tag:CHANSEL_NOMATCH channel:0x41 frame:0 vi_tstamp:17949740377 data:0x000003c9
kworker/0:3-1803 [000] … 551.258013: rtcpu_vinotify_error: tstamp:17949875532 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:17949872955 data:0x000003c9
kworker/0:3-1803 [000] … 551.258016: rtcpu_vinotify_event: tstamp:17950157520 tag:FE channel:0x01 frame:0 vi_tstamp:17949698231 data:0x00000020
kworker/0:3-1803 [000] … 551.258018: rtcpu_vinotify_event: tstamp:17950157693 tag:FS channel:0x01 frame:0 vi_tstamp:17949725195 data:0x00000010
kworker/0:3-1803 [000] … 551.258020: rtcpu_vinotify_event: tstamp:17950157843 tag:CHANSEL_NOMATCH channel:0x41 frame:0 vi_tstamp:17949740377 data:0x000003c9
kworker/0:3-1803 [000] … 551.258021: rtcpu_vinotify_event: tstamp:17950158011 tag:FE channel:0x00 frame:0 vi_tstamp:17949830549 data:0x00000020
kworker/0:3-1803 [000] … 551.258022: rtcpu_vinotify_event: tstamp:17950158155 tag:FS channel:0x00 frame:0 vi_tstamp:17949857695 data:0x00000010
kworker/0:3-1803 [000] … 551.258023: rtcpu_vinotify_event: tstamp:17950158322 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:17949872955 data:0x000003c9
kworker/0:3-1803 [000] … 551.258024: rtcpu_vinotify_event: tstamp:17950742040 tag:FE channel:0x01 frame:0 vi_tstamp:17950739758 data:0x00000020
kworker/0:3-1803 [000] .... 552.994056: rtcpu_vinotify_event: tstamp:18004406224 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:18004032443 data:0x000003c9
kworker/0:3-1803 [000] .... 552.994059: rtos_queue_peek_from_isr_failed: tstamp:18004717721 queue:0x0bcbbbb8
kworker/0:3-1803 [000] .... 552.994061: rtcpu_vinotify_error: tstamp:18004943964 tag:CHANSEL_NOMATCH channel:0x41 frame:0 vi_tstamp:18004941393 data:0x000003c9
kworker/0:3-1803 [000] .... 552.994062: rtcpu_vinotify_error: tstamp:18005076550 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:18005073972 data:0x000003c9
kworker/0:3-1803 [000] .... 552.994064: rtcpu_vinotify_event: tstamp:18005382677 tag:FE channel:0x01 frame:0 vi_tstamp:18004899248 data:0x00000020
kworker/0:3-1803 [000] .... 552.994065: rtcpu_vinotify_event: tstamp:18005382850 tag:FS channel:0x01 frame:0 vi_tstamp:18004926212 data:0x00000010
kworker/0:3-1803 [000] .... 552.994066: rtcpu_vinotify_event: tstamp:18005382998 tag:CHANSEL_NOMATCH channel:0x41 frame:0 vi_tstamp:18004941393 data:0x000003c9
kworker/0:3-1803 [000] .... 552.994067: rtcpu_vinotify_event: tstamp:18005383168 tag:FE channel:0x00 frame:0 vi_tstamp:18005031559 data:0x00000020
kworker/0:3-1803 [000] .... 552.994068: rtcpu_vinotify_event: tstamp:18005383313 tag:FS channel:0x00 frame:0 vi_tstamp:18005058679 data:0x00000010
kworker/0:3-1803 [000] .... 552.994069: rtcpu_vinotify_event: tstamp:18005383483 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:18005073972 data:0x000003c9
kworker/0:3-1803 [000] .... 553.050072: rtcpu_vinotify_error: tstamp:18005985699 tag:CHANSEL_NOMATCH channel:0x41 frame:0 vi_tstamp:18005982923 data:0x000003c9
kworker/0:3-1803 [000] .... 553.050075: rtcpu_vinotify_event: tstamp:18005986066 tag:FE channel:0x01 frame:0 vi_tstamp:18005940778 data:0x00000020
kworker/0:3-1803 [000] .... 553.050077: rtcpu_vinotify_event: tstamp:18005986237 tag:FS channel:0x01 frame:0 vi_tstamp:18005967742 data:0x00000010
kworker/0:3-1803 [000] .... 553.050078: rtcpu_vinotify_event: tstamp:18005986385 tag:CHANSEL_NOMATCH channel:0x41 frame:0 vi_tstamp:18005982923 data:0x000003c9
kworker/0:3-1803 [000] .... 553.050079: rtcpu_vinotify_error: tstamp:18006118079 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:18006115501 data:0x000003c9
kworker/0:3-1803 [000] .... 553.050080: rtcpu_vinotify_event: tstamp:18006456748 tag:FE channel:0x00 frame:0 vi_tstamp:18006073088 data:0x00000020
kworker/0:3-1803 [000] .... 553.050081: rtcpu_vinotify_event: tstamp:18006456893 tag:FS channel:0x00 frame:0 vi_tstamp:18006100207 data:0x00000010
kworker/0:3-1803 [000] .... 553.050082: rtcpu_vinotify_event: tstamp:18006457063 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:18006115501 data:0x000003c9
kworker/0:3-1803 [000] .... 553.050084: rtcpu_vinotify_error: tstamp:18007027030 tag:CHANSEL_NOMATCH channel:0x41 frame:0 vi_tstamp:18007024450 data:0x000003c9
kworker/0:3-1803 [000] .... 553.050085: rtcpu_vinotify_error: tstamp:18007159607 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:18007157031 data:0x000003c9
kworker/0:3-1803 [000] .... 553.050086: rtcpu_vinotify_event: tstamp:18007433526 tag:FE channel:0x01 frame:0 vi_tstamp:18006982307 data:0x00000020
kworker/0:3-1803 [000] .... 553.050087: rtcpu_vinotify_event: tstamp:18007433697 tag:FS channel:0x01 frame:0 vi_tstamp:18007009272 data:0x00000010
kworker/0:3-1803 [000] .... 553.050088: rtcpu_vinotify_event: tstamp:18007433844 tag:CHANSEL_NOMATCH channel:0x41 frame:0 vi_tstamp:18007024450 data:0x000003c9
kworker/0:3-1803 [000] .... 553.050089: rtcpu_vinotify_event: tstamp:18007434015 tag:FE channel:0x00 frame:0 vi_tstamp:18007114618 data:0x00000020
kworker/0:3-1803 [000] .... 553.050090: rtcpu_vinotify_event: tstamp:18007434160 tag:FS channel:0x00 frame:0 vi_tstamp:18007141734 data:0x00000010
kworker/0:3-1803 [000] .... 553.050091: rtcpu_vinotify_event: tstamp:18007434330 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:18007157031 data:0x000003c9
kworker/0:3-1803 [000] .... 553.106064: rtcpu_vinotify_error: tstamp:18008068553 tag:CHANSEL_NOMATCH channel:0x41 frame:0 vi_tstamp:18008065978 data:0x000003c9
kworker/0:3-1803 [000] .... 553.106066: rtcpu_vinotify_error: tstamp:18008201132 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:18008198558 data:0x000003c9
kworker/0:3-1803 [000] .... 553.106068: rtcpu_vinotify_event: tstamp:18008409602 tag:FE channel:0x01 frame:0 vi_tstamp:18008023835 data:0x00000020
kworker/0:3-1803 [000] .... 553.106069: rtcpu_vinotify_event: tstamp:18008409776 tag:FS channel:0x01 frame:0 vi_tstamp:18008050802 data:0x00000010
kworker/0:3-1803 [000] .... 553.106070: rtcpu_vinotify_event: tstamp:18008409926 tag:CHANSEL_NOMATCH channel:0x41 frame:0 vi_tstamp:18008065978 data:0x000003c9
kworker/0:3-1803 [000] .... 553.106071: rtcpu_vinotify_event: tstamp:18008410099 tag:FE channel:0x00 frame:0 vi_tstamp:18008156148 data:0x00000020
kworker/0:3-1803 [000] .... 553.106072: rtcpu_vinotify_event: tstamp:18008410244 tag:FS channel:0x00 frame:0 vi_tstamp:18008183263 data:0x00000010
kworker/0:3-1803 [000] .... 553.106073: rtcpu_vinotify_event: tstamp:18008410414 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:18008198558 data:0x000003c9
kworker/0:3-1803 [000] .... 553.106074: rtcpu_vinotify_event: tstamp:18009067626 tag:FE channel:0x01 frame:0 vi_tstamp:18009065362 data:0x00000020
kworker/0:3-1803 [000] .... 553.106075: rtcpu_vinotify_error: tstamp:18009110077 tag:CHANSEL_NOMATCH channel:0x41 frame:0 vi_tstamp:18009107508 data:0x000003c9
kworker/0:3-1803 [000] .... 553.106113: rtcpu_vinotify_error: tstamp:18009242657 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:18009240088 data:0x000003c9
kworker/0:3-1803 [000] .... 553.162076: rtcpu_vinotify_event: tstamp:18009533303 tag:FS channel:0x01 frame:0 vi_tstamp:18009092327 data:0x00000010
kworker/0:3-1803 [000] .... 553.162078: rtcpu_vinotify_event: tstamp:18009533455 tag:CHANSEL_NOMATCH channel:0x41 frame:0 vi_tstamp:18009107508 data:0x000003c9
kworker/0:3-1803 [000] .... 553.162080: rtcpu_vinotify_event: tstamp:18009533628 tag:FE channel:0x00 frame:0 vi_tstamp:18009197674 data:0x00000020
kworker/0:3-1803 [000] .... 553.162081: rtcpu_vinotify_event: tstamp:18009533772 tag:FS channel:0x00 frame:0 vi_tstamp:18009224790 data:0x00000010
kworker/0:3-1803 [000] .... 553.162082: rtcpu_vinotify_event: tstamp:18009533941 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:18009240088 data:0x000003c9
kworker/0:3-1803 [000] .... 553.162084: rtos_queue_peek_from_isr_failed: tstamp:18009717714 queue:0x0bcbbbb8
kworker/0:3-1803 [000] .... 553.162085: rtcpu_vinotify_error: tstamp:18010151669 tag:CHANSEL_NOMATCH channel:0x41 frame:0 vi_tstamp:18010149038 data:0x000003c9
kworker/0:3-1803 [000] .... 553.162087: rtcpu_vinotify_error: tstamp:18010284187 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:18010281616 data:0x000003c9
kworker/0:3-1803 [000] .... 553.162088: rtcpu_vinotify_event: tstamp:18010509375 tag:FE channel:0x01 frame:0 vi_tstamp:18010106892 data:0x00000020
kworker/0:3-1803 [000] .... 553.162089: rtcpu_vinotify_event: tstamp:18010509548 tag:FS channel:0x01 frame:0 vi_tstamp:18010133857 data:0x00000010
kworker/0:3-1803 [000] .... 553.162090: rtcpu_vinotify_event: tstamp:18010509697 tag:CHANSEL_NOMATCH channel:0x41 frame:0 vi_tstamp:18010149038 data:0x000003c9
kworker/0:3-1803 [000] .... 553.162120: rtcpu_vinotify_event: tstamp:18010509865 tag:FE channel:0x00 frame:0 vi_tstamp:18010239203 data:0x00000020
kworker/0:3-1803 [000] .... 553.162121: rtcpu_vinotify_event: tstamp:18010510009 tag:FS channel:0x00 frame:0 vi_tstamp:18010266318 data:0x00000010
kworker/0:3-1803 [000] .... 553.162122: rtcpu_vinotify_event: tstamp:18010510177 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:18010281616 data:0x000003c9
kworker/0:3-1803 [000] .... 553.218060: rtcpu_vinotify_error: tstamp:18011193146 tag:CHANSEL_NOMATCH channel:0x41 frame:0 vi_tstamp:18011190567 data:0x000003c9
kworker/0:3-1803 [000] .... 553.218062: rtcpu_vinotify_event: tstamp:18011310065 tag:FE channel:0x01 frame:0 vi_tstamp:18011148422 data:0x00000020
kworker/0:3-1803 [000] .... 553.218091: rtcpu_vinotify_event: tstamp:18011310236 tag:FS channel:0x01 frame:0 vi_tstamp:18011175386 data:0x00000010
kworker/0:3-1803 [000] .... 553.218092: rtcpu_vinotify_event: tstamp:18011310385 tag:CHANSEL_NOMATCH channel:0x41 frame:0 vi_tstamp:18011190567 data:0x000003c9
kworker/0:3-1803 [000] .... 553.218093: rtcpu_vinotify_event: tstamp:18011310555 tag:FE channel:0x00 frame:0 vi_tstamp:18011280733 data:0x00000020
kworker/0:3-1803 [000] .... 553.218094: rtcpu_vinotify_event: tstamp:18011310699 tag:FS channel:0x00 frame:0 vi_tstamp:18011307846 data:0x00000010
kworker/0:3-1803 [000] .... 553.218095: rtcpu_vinotify_error: tstamp:18011325711 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:18011323146 data:0x000003c9
kworker/0:3-1803 [000] .... 553.218097: rtcpu_vinotify_event: tstamp:18011778866 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:18011323146 data:0x000003c9
kworker/0:3-1803 [000] .... 553.218098: rtcpu_vinotify_error: tstamp:18012234673 tag:CHANSEL_NOMATCH channel:0x41 frame:0 vi_tstamp:18012232095 data:0x000003c9
kworker/0:3-1803 [000] .... 553.218099: rtcpu_vinotify_event: tstamp:18012267250 tag:FE channel:0x01 frame:0 vi_tstamp:18012189953 data:0x00000020
kworker/0:3-1803 [000] .... 553.218100: rtcpu_vinotify_event: tstamp:18012267417 tag:FS channel:0x01 frame:0 vi_tstamp:18012216917 data:0x00000010
kworker/0:3-1803 [000] .... 553.218101: rtcpu_vinotify_event: tstamp:18012267565 tag:CHANSEL_NOMATCH channel:0x41 frame:0 vi_tstamp:18012232095 data:0x000003c9
kworker/0:3-1803 [000] .... 553.218102: rtcpu_vinotify_error: tstamp:18012367247 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:18012364675 data:0x000003c9
kworker/0:3-1803 [000] .... 553.218103: rtcpu_vinotify_event: tstamp:18012755643 tag:FE channel:0x00 frame:0 vi_tstamp:18012322262 data:0x00000020
kworker/0:3-1803 [000] .... 553.218125: rtcpu_vinotify_event: tstamp:18012755790 tag:FS channel:0x00 frame:0 vi_tstamp:18012349374 data:0x00000010
kworker/0:3-1803 [000] .... 553.218126: rtcpu_vinotify_event: tstamp:18012755958 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:18012364675 data:0x000003c9
kworker/0:3-1803 [000] .... 553.274097: rtcpu_vinotify_event: tstamp:18013243828 tag:FE channel:0x01 frame:0 vi_tstamp:18013231477 data:0x00000020
kworker/0:3-1803 [000] .... 553.274101: rtcpu_vinotify_error: tstamp:18013276242 tag:CHANSEL_NOMATCH channel:0x41 frame:0 vi_tstamp:18013273622 data:0x000003c9
kworker/0:3-1803 [000] .... 553.274102: rtcpu_vinotify_error: tstamp:18013408777 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:18013406203 data:0x000003c9
kworker/0:3-1803 [000] .... 553.274103: rtcpu_vinotify_event: tstamp:18013732428 tag:FS channel:0x01 frame:0 vi_tstamp:18013258442 data:0x00000010
kworker/0:3-1803 [000] .... 553.274105: rtcpu_vinotify_event: tstamp:18013732575 tag:CHANSEL_NOMATCH channel:0x41 frame:0 vi_tstamp:18013273622 data:0x000003c9
kworker/0:3-1803 [000] .... 553.274106: rtcpu_vinotify_event: tstamp:18013732745 tag:FE channel:0x00 frame:0 vi_tstamp:18013363787 data:0x00000020
kworker/0:3-1803 [000] .... 553.274107: rtcpu_vinotify_event: tstamp:18013732889 tag:FS channel:0x00 frame:0 vi_tstamp:18013390902 data:0x00000010
kworker/0:3-1803 [000] .... 553.274108: rtcpu_vinotify_event: tstamp:18013733058 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:18013406203 data:0x000003c9
kworker/0:3-1803 [000] .... 553.274109: rtcpu_vinotify_error: tstamp:18014317951 tag:CHANSEL_NOMATCH channel:0x41 frame:0 vi_tstamp:18014315152 data:0x000003c9
kworker/0:3-1803 [000] .... 553.274110: rtcpu_vinotify_event: tstamp:18014318312 tag:FE channel:0x01 frame:0 vi_tstamp:18014273006 data:0x00000020
kworker/0:3-1803 [000] .... 553.274146: rtcpu_vinotify_event: tstamp:18014318482 tag:FS channel:0x01 frame:0 vi_tstamp:18014299971 data:0x00000010
kworker/0:3-1803 [000] .... 553.274147: rtcpu_vinotify_event: tstamp:18014318627 tag:CHANSEL_NOMATCH channel:0x41 frame:0 vi_tstamp:18014315152 data:0x000003c9
kworker/0:3-1803 [000] .... 553.274148: rtcpu_vinotify_error: tstamp:18014450306 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:18014447730 data:0x000003c9
kworker/0:3-1803 [000] .... 553.330075: rtos_queue_peek_from_isr_failed: tstamp:18014717719 queue:0x0bcbbbb8
kworker/0:3-1803 [000] .... 553.330079: rtcpu_vinotify_event: tstamp:18014757631 tag:FE channel:0x00 frame:0 vi_tstamp:18014405317 data:0x00000020
kworker/0:3-1803 [000] .... 553.330080: rtcpu_vinotify_event: tstamp:18014757780 tag:FS channel:0x00 frame:0 vi_tstamp:18014432429 data:0x00000010
kworker/0:3-1803 [000] .... 553.330082: rtcpu_vinotify_event: tstamp:18014757954 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:18014447730 data:0x000003c9
kworker/0:3-1803 [000] .... 553.330083: rtcpu_vinotify_error: tstamp:18015359253 tag:CHANSEL_NOMATCH channel:0x41 frame:0 vi_tstamp:18015356682 data:0x000003c9
kworker/0:3-1803 [000] .... 553.330084: rtcpu_vinotify_error: tstamp:18015491831 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:18015489260 data:0x000003c9
kworker/0:3-1803 [000] .... 553.330085: rtcpu_vinotify_event: tstamp:18015734405 tag:FE channel:0x01 frame:0 vi_tstamp:18015314536 data:0x00000020
kworker/0:3-1803 [000] .... 553.330086: rtcpu_vinotify_event: tstamp:18015734576 tag:FS channel:0x01 frame:0 vi_tstamp:18015341501 data:0x00000010
kworker/0:3-1803 [000] .... 553.330088: rtcpu_vinotify_event: tstamp:18015734725 tag:CHANSEL_NOMATCH channel:0x41 frame:0 vi_tstamp:18015356682 data:0x000003c9
kworker/0:3-1803 [000] .... 553.330089: rtcpu_vinotify_event: tstamp:18015734894 tag:FE channel:0x00 frame:0 vi_tstamp:18015446847 data:0x00000020
kworker/0:3-1803 [000] .... 553.330090: rtcpu_vinotify_event: tstamp:18015735039 tag:FS channel:0x00 frame:0 vi_tstamp:18015473958 data:0x00000010
kworker/0:3-1803 [000] .... 553.330091: rtcpu_vinotify_event: tstamp:18015735208 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:18015489260 data:0x000003c9
kworker/0:3-1803 [000] .... 553.386114: rtcpu_vinotify_error: tstamp:18016400825 tag:CHANSEL_NOMATCH channel:0x41 frame:0 vi_tstamp:18016398207 data:0x000003c9
kworker/0:3-1803 [000] .... 553.386118: rtcpu_vinotify_error: tstamp:18016533366 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:18016530790 data:0x000003c9
kworker/0:3-1803 [000] .... 553.386147: rtcpu_vinotify_event: tstamp:18016710476 tag:FE channel:0x01 frame:0 vi_tstamp:18016356063 data:0x00000020
kworker/0:3-1803 [000] .... 553.386149: rtcpu_vinotify_event: tstamp:18016710649 tag:FS channel:0x01 frame:0 vi_tstamp:18016383031 data:0x00000010
kworker/0:3-1803 [000] .... 553.386150: rtcpu_vinotify_event: tstamp:18016710799 tag:CHANSEL_NOMATCH channel:0x41 frame:0 vi_tstamp:18016398207 data:0x000003c9
kworker/0:3-1803 [000] .... 553.386151: rtcpu_vinotify_event: tstamp:18016710968 tag:FE channel:0x00 frame:0 vi_tstamp:18016488376 data:0x00000020
kworker/0:3-1803 [000] .... 553.386152: rtcpu_vinotify_event: tstamp:18016711114 tag:FS channel:0x00 frame:0 vi_tstamp:18016515486 data:0x00000010
kworker/0:3-1803 [000] .... 553.386153: rtcpu_vinotify_event: tstamp:18016711283 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:18016530790 data:0x000003c9
kworker/0:3-1803 [000] .... 553.386154: rtcpu_vinotify_event: tstamp:18017399811 tag:FE channel:0x01 frame:0 vi_tstamp:18017397591 data:0x00000020
kworker/0:3-1803 [000] .... 553.386155: rtcpu_vinotify_error: tstamp:18017442365 tag:CHANSEL_NOMATCH channel:0x41 frame:0 vi_tstamp:18017439737 data:0x000003c9
kworker/0:3-1803 [000] .... 553.386156: rtcpu_vinotify_error: tstamp:18017574891 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:18017572320 data:0x000003c9
kworker/0:3-1803 [000] .... 553.386157: rtcpu_vinotify_event: tstamp:18017882998 tag:FS channel:0x01 frame:0 vi_tstamp:18017424557 data:0x00000010
kworker/0:3-1803 [000] .... 553.386158: rtcpu_vinotify_event: tstamp:18017883145 tag:CHANSEL_NOMATCH channel:0x41 frame:0 vi_tstamp:18017439737 data:0x000003c9
kworker/0:3-1803 [000] .... 553.386160: rtcpu_vinotify_event: tstamp:18017883317 tag:FE channel:0x00 frame:0 vi_tstamp:18017529907 data:0x00000020
kworker/0:3-1803 [000] .... 553.386183: rtcpu_vinotify_event: tstamp:18017883461 tag:FS channel:0x00 frame:0 vi_tstamp:18017557013 data:0x00000010
kworker/0:3-1803 [000] .... 553.386184: rtcpu_vinotify_event: tstamp:18017883630 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:18017572320 data:0x000003c9
kworker/0:3-1803 [000] .... 553.442113: rtcpu_vinotify_error: tstamp:18018483845 tag:CHANSEL_NOMATCH channel:0x41 frame:0 vi_tstamp:18018481266 data:0x000003c9
kworker/0:3-1803 [000] .... 553.442116: rtcpu_vinotify_error: tstamp:18018616416 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:18018613845 data:0x000003c9
kworker/0:3-1803 [000] .... 553.442117: rtcpu_vinotify_event: tstamp:18018859069 tag:FE channel:0x01 frame:0 vi_tstamp:18018439121 data:0x00000020
kworker/0:3-1803 [000] .... 553.442119: rtcpu_vinotify_event: tstamp:18018859243 tag:FS channel:0x01 frame:0 vi_tstamp:18018466085 data:0x00000010
kworker/0:3-1803 [000] .... 553.442120: rtcpu_vinotify_event: tstamp:18018859392 tag:CHANSEL_NOMATCH channel:0x41 frame:0 vi_tstamp:18018481266 data:0x000003c9
kworker/0:3-1803 [000] .... 553.442121: rtcpu_vinotify_event: tstamp:18018859559 tag:FE channel:0x00 frame:0 vi_tstamp:18018571431 data:0x00000020
kworker/0:3-1803 [000] .... 553.442122: rtcpu_vinotify_event: tstamp:18018859705 tag:FS channel:0x00 frame:0 vi_tstamp:18018598541 data:0x00000010
kworker/0:3-1803 [000] .... 553.442123: rtcpu_vinotify_event: tstamp:18018859876 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:18018613845 data:0x000003c9
kworker/0:3-1803 [000] .... 553.442124: rtcpu_vinotify_error: tstamp:18019525416 tag:CHANSEL_NOMATCH channel:0x41 frame:0 vi_tstamp:18019522797 data:0x000003c9
kworker/0:3-1803 [000] .... 553.442125: rtcpu_vinotify_event: tstamp:18019642285 tag:FE channel:0x01 frame:0 vi_tstamp:18019480650 data:0x00000020
kworker/0:3-1803 [000] .... 553.442126: rtcpu_vinotify_event: tstamp:18019642456 tag:FS channel:0x01 frame:0 vi_tstamp:18019507615 data:0x00000010
kworker/0:3-1803 [000] .... 553.442127: rtcpu_vinotify_event: tstamp:18019642604 tag:CHANSEL_NOMATCH channel:0x41 frame:0 vi_tstamp:18019522797 data:0x000003c9
kworker/0:3-1803 [000] .... 553.442128: rtcpu_vinotify_event: tstamp:18019642771 tag:FE channel:0x00 frame:0 vi_tstamp:18019612961 data:0x00000020
kworker/0:3-1803 [000] .... 553.442129: rtcpu_vinotify_event: tstamp:18019642915 tag:FS channel:0x00 frame:0 vi_tstamp:18019640069 data:0x00000010
kworker/0:3-1803 [000] .... 553.442166: rtcpu_vinotify_error: tstamp:18019657950 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:18019655374 data:0x000003c9
kworker/0:3-1803 [000] .... 553.442168: rtos_queue_peek_from_isr_failed: tstamp:18019717717 queue:0x0bcbbbb8
kworker/0:3-1803 [000] .... 553.498099: rtcpu_vinotify_event: tstamp:18020128566 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:18019655374 data:0x000003c9
kworker/0:3-1803 [000] .... 553.498101: rtcpu_vinotify_error: tstamp:18020566897 tag:CHANSEL_NOMATCH channel:0x41 frame:0 vi_tstamp:18020564326 data:0x000003c9
kworker/0:3-1803 [000] .... 553.498103: rtcpu_vinotify_event: tstamp:18020616953 tag:FE channel:0x01 frame:0 vi_tstamp:18020522178 data:0x00000020
kworker/0:3-1803 [000] .... 553.498104: rtcpu_vinotify_event: tstamp:18020617124 tag:FS channel:0x01 frame:0 vi_tstamp:18020549146 data:0x00000010
kworker/0:3-1803 [000] .... 553.498105: rtcpu_vinotify_event: tstamp:18020617273 tag:CHANSEL_NOMATCH channel:0x41 frame:0 vi_tstamp:18020564326 data:0x000003c9
kworker/0:3-1803 [000] .... 553.498107: rtcpu_vinotify_error: tstamp:18020699478 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:18020696904 data:0x000003c9
kworker/0:3-1803 [000] .... 553.498108: rtcpu_vinotify_event: tstamp:18021105349 tag:FE channel:0x00 frame:0 vi_tstamp:18020654490 data:0x00000020
kworker/0:3-1803 [000] .... 553.498109: rtcpu_vinotify_event: tstamp:18021105494 tag:FS channel:0x00 frame:0 vi_tstamp:18020681598 data:0x00000010
kworker/0:3-1803 [000] .... 553.498110: rtcpu_vinotify_event: tstamp:18021105664 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:18020696904 data:0x000003c9
kworker/0:3-1803 [000] .... 553.498111: rtcpu_vinotify_event: tstamp:18021593583 tag:FE channel:0x01 frame:0 vi_tstamp:18021563708 data:0x00000020
kworker/0:3-1803 [000] .... 553.498112: rtcpu_vinotify_event: tstamp:18021593750 tag:FS channel:0x01 frame:0 vi_tstamp:18021590672 data:0x00000010
kworker/0:3-1803 [000] .... 553.554118: rtcpu_vinotify_error: tstamp:18021608416 tag:CHANSEL_NOMATCH channel:0x41 frame:0 vi_tstamp:18021605852 data:0x000003c9
kworker/0:3-1803 [000] .... 553.554121: rtcpu_vinotify_error: tstamp:18021741004 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:18021738431 data:0x000003c9
kworker/0:3-1803 [000] .... 553.554122: rtcpu_vinotify_event: tstamp:18022082132 tag:CHANSEL_NOMATCH channel:0x41 frame:0 vi_tstamp:18021605852 data:0x000003c9
kworker/0:3-1803 [000] .... 553.554124: rtcpu_vinotify_event: tstamp:18022082302 tag:FE channel:0x00 frame:0 vi_tstamp:18021696017 data:0x00000020
kworker/0:3-1803 [000] .... 553.554125: rtcpu_vinotify_event: tstamp:18022082448 tag:FS channel:0x00 frame:0 vi_tstamp:18021723125 data:0x00000010
kworker/0:3-1803 [000] .... 553.554126: rtcpu_vinotify_event: tstamp:18022082619 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:18021738431 data:0x000003c9
kworker/0:3-1803 [000] .... 553.554127: rtcpu_vinotify_error: tstamp:18022650201 tag:CHANSEL_NOMATCH channel:0x41 frame:0 vi_tstamp:18022647381 data:0x000003c9
kworker/0:3-1803 [000] .... 553.554128: rtcpu_vinotify_event: tstamp:18022650560 tag:FE channel:0x01 frame:0 vi_tstamp:18022605235 data:0x00000020
kworker/0:3-1803 [000] .... 553.554129: rtcpu_vinotify_event: tstamp:18022650732 tag:FS channel:0x01 frame:0 vi_tstamp:18022632200 data:0x00000010
kworker/0:3-1803 [000] .... 553.554130: rtcpu_vinotify_event: tstamp:18022650879 tag:CHANSEL_NOMATCH channel:0x41 frame:0 vi_tstamp:18022647381 data:0x000003c9
kworker/0:3-1803 [000] .... 553.554131: rtcpu_vinotify_error: tstamp:18022782531 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:18022779959 data:0x000003c9
kworker/0:3-1803 [000] .... 553.554132: rtcpu_vinotify_event: tstamp:18023107373 tag:FE channel:0x00 frame:0 vi_tstamp:18022737546 data:0x00000020
kworker/0:3-1803 [000] .... 553.554133: rtcpu_vinotify_event: tstamp:18023107518 tag:FS channel:0x00 frame:0 vi_tstamp:18022764653 data:0x00000010
kworker/0:3-1803 [000] .... 553.554163: rtcpu_vinotify_event: tstamp:18023107688 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:18022779959 data:0x000003c9
Check if any embedded data output from the sensor(Maxim) to define the correct value of embedded_metadata_height in device tree.
Hi, ShaneCCC
It works.
Thank you very much.
system
Closed
February 9, 2022, 6:29am
15
