rtcpu_nvcsi_intr on Jetson Xavier
Hi
I used ds90ub954. When captured the frame, xavier report thousands of errors like “rtcpu_nvcsi_intr: tstamp:4462710693 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110”,what mean is status:0x00000110?
I find the difine in camrtc-capture.h,the status is represented rxfifo full?
#define NVCSI_INTR_FLAG_CIL_INTR0_DATA_LANE_ERR0_RXFIFO_FULL
#define NVCSI_INTR_FLAG_CIL_INTR0_DATA_LANE_ERR1_RXFIFO_FULL
# tracer: nop
# entries-in-buffer/entries-written: 871177/5350242   #P:8
#                              _-----=> irqs-off
#                             / _----=> need-resched
#                            | / _---=> hardirq/softirq
#                            || / _--=> preempt-depth
#                            ||| /     delay
#           TASK-PID   CPU#  ||||    TIMESTAMP  FUNCTION
          v4l_id-7414  [002] ....    35.064306: tegra_channel_open: vi-output, ar0144at 9-0010
          v4l_id-7414  [002] ....    35.064317: tegra_channel_set_power: ar0144at 9-0010 : 0x1
          v4l_id-7414  [002] ....    35.064323: camera_common_s_power: status : 0x1
##### CPU 3 buffer started ####
          v4l_id-7414  [003] ....    35.064411: tegra_channel_set_power: 15a00000.nvcsi--1 : 0x1
          v4l_id-7414  [003] ....    35.064415: csi_s_power: enable : 0x1
          v4l_id-7414  [003] ....    35.064552: tegra_channel_close: vi-output, ar0144at 9-0010
          v4l_id-7414  [003] ....    35.064555: tegra_channel_set_power: ar0144at 9-0010 : 0x0
          v4l_id-7414  [003] ....    35.064559: camera_common_s_power: status : 0x0
##### CPU 7 buffer started ####
          v4l_id-7414  [007] ....    35.064629: tegra_channel_set_power: 15a00000.nvcsi--1 : 0x0
          v4l_id-7414  [007] ....    35.064633: csi_s_power: enable : 0x0
        v4l2-ctl-7416  [007] ....    36.084647: tegra_channel_open: vi-output, ar0144at 9-0010
        v4l2-ctl-7416  [007] ....    36.084676: tegra_channel_set_power: ar0144at 9-0010 : 0x1
        v4l2-ctl-7416  [007] ....    36.084697: camera_common_s_power: status : 0x1
        v4l2-ctl-7416  [007] ....    36.084819: tegra_channel_set_power: 15a00000.nvcsi--1 : 0x1
        v4l2-ctl-7416  [007] ....    36.084825: csi_s_power: enable : 0x1
        v4l2-ctl-7416  [007] ....    36.087921: tegra_channel_set_stream: enable : 0x1
##### CPU 0 buffer started ####
     kworker/0:1-731   [000] ....   136.345573: rtcpu_nvcsi_intr: tstamp:4462710693 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345573: rtcpu_nvcsi_intr: tstamp:4462710693 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
     kworker/0:1-731   [000] ....   136.345574: rtcpu_nvcsi_intr: tstamp:4462710693 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345574: rtcpu_nvcsi_intr: tstamp:4462711864 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
     kworker/0:1-731   [000] ....   136.345574: rtcpu_nvcsi_intr: tstamp:4462711864 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345574: rtcpu_nvcsi_intr: tstamp:4462711864 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345574: rtcpu_nvcsi_intr: tstamp:4462712815 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345574: rtcpu_nvcsi_intr: tstamp:4462712815 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345575: rtcpu_nvcsi_intr: tstamp:4462713490 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345575: rtcpu_nvcsi_intr: tstamp:4462713490 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345575: rtcpu_nvcsi_intr: tstamp:4462714163 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345575: rtcpu_nvcsi_intr: tstamp:4462714163 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345575: rtcpu_nvcsi_intr: tstamp:4462714887 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345575: rtcpu_nvcsi_intr: tstamp:4462714887 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345576: rtcpu_nvcsi_intr: tstamp:4462715578 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345576: rtcpu_nvcsi_intr: tstamp:4462715578 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345576: rtcpu_nvcsi_intr: tstamp:4462716246 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345576: rtcpu_nvcsi_intr: tstamp:4462716246 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345576: rtcpu_nvcsi_intr: tstamp:4462716919 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345577: rtcpu_nvcsi_intr: tstamp:4462716919 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345577: rtcpu_nvcsi_intr: tstamp:4462717594 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345577: rtcpu_nvcsi_intr: tstamp:4462717594 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
     kworker/0:1-731   [000] ....   136.345577: rtcpu_nvcsi_intr: tstamp:4462717594 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345577: rtcpu_nvcsi_intr: tstamp:4462718529 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
     kworker/0:1-731   [000] ....   136.345577: rtcpu_nvcsi_intr: tstamp:4462718529 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345578: rtcpu_nvcsi_intr: tstamp:4462718529 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345578: rtcpu_nvcsi_intr: tstamp:4462719455 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345578: rtcpu_nvcsi_intr: tstamp:4462719455 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345578: rtcpu_nvcsi_intr: tstamp:4462720127 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345578: rtcpu_nvcsi_intr: tstamp:4462720127 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345578: rtcpu_nvcsi_intr: tstamp:4462720822 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345579: rtcpu_nvcsi_intr: tstamp:4462720822 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345579: rtcpu_nvcsi_intr: tstamp:4462721495 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
     kworker/0:1-731   [000] ....   136.345579: rtcpu_nvcsi_intr: tstamp:4462721495 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345579: rtcpu_nvcsi_intr: tstamp:4462721495 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
     kworker/0:1-731   [000] ....   136.345579: rtcpu_nvcsi_intr: tstamp:4462721495 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345579: rtcpu_nvcsi_intr: tstamp:4462722672 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345580: rtcpu_nvcsi_intr: tstamp:4462722672 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345581: rtcpu_nvcsi_intr: tstamp:4462723370 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345581: rtcpu_nvcsi_intr: tstamp:4462723370 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345581: rtcpu_nvcsi_intr: tstamp:4462724043 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345581: rtcpu_nvcsi_intr: tstamp:4462724043 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345581: rtcpu_nvcsi_intr: tstamp:4462724718 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345581: rtcpu_nvcsi_intr: tstamp:4462724718 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345582: rtcpu_nvcsi_intr: tstamp:4462725391 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
     kworker/0:1-731   [000] ....   136.345582: rtcpu_nvcsi_intr: tstamp:4462725391 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345582: rtcpu_nvcsi_intr: tstamp:4462725391 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
     kworker/0:1-731   [000] ....   136.345582: rtcpu_nvcsi_intr: tstamp:4462725391 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345582: rtcpu_nvcsi_intr: tstamp:4462726566 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345582: rtcpu_nvcsi_intr: tstamp:4462726566 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345583: rtcpu_nvcsi_intr: tstamp:4462727245 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345583: rtcpu_nvcsi_intr: tstamp:4462727245 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345583: rtcpu_nvcsi_intr: tstamp:4462727920 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345583: rtcpu_nvcsi_intr: tstamp:4462727920 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345583: rtcpu_nvcsi_intr: tstamp:4462728612 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345583: rtcpu_nvcsi_intr: tstamp:4462728612 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345584: rtcpu_nvcsi_intr: tstamp:4462729285 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345584: rtcpu_nvcsi_intr: tstamp:4462729285 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345584: rtcpu_nvcsi_intr: tstamp:4462729958 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
     kworker/0:1-731   [000] ....   136.345584: rtcpu_nvcsi_intr: tstamp:4462729958 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345584: rtcpu_nvcsi_intr: tstamp:4462729958 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
     kworker/0:1-731   [000] ....   136.345584: rtcpu_nvcsi_intr: tstamp:4462729958 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345585: rtcpu_nvcsi_intr: tstamp:4462731143 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345585: rtcpu_nvcsi_intr: tstamp:4462731143 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345585: rtcpu_nvcsi_intr: tstamp:4462731823 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345585: rtcpu_nvcsi_intr: tstamp:4462731823 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345585: rtcpu_nvcsi_intr: tstamp:4462732493 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
     kworker/0:1-731   [000] ....   136.345585: rtcpu_nvcsi_intr: tstamp:4462732493 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345586: rtcpu_nvcsi_intr: tstamp:4462732493 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
     kworker/0:1-731   [000] ....   136.345586: rtcpu_nvcsi_intr: tstamp:4462732493 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345586: rtcpu_nvcsi_intr: tstamp:4462733682 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
     kworker/0:1-731   [000] ....   136.345586: rtcpu_nvcsi_intr: tstamp:4462733682 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345586: rtcpu_nvcsi_intr: tstamp:4462733682 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
     kworker/0:1-731   [000] ....   136.345586: rtcpu_nvcsi_intr: tstamp:4462733682 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345587: rtcpu_nvcsi_intr: tstamp:4462734856 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345587: rtcpu_nvcsi_intr: tstamp:4462734856 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345587: rtcpu_nvcsi_intr: tstamp:4462735538 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345587: rtcpu_nvcsi_intr: tstamp:4462735538 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345587: rtcpu_nvcsi_intr: tstamp:4462736233 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345587: rtcpu_nvcsi_intr: tstamp:4462736233 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345588: rtcpu_nvcsi_intr: tstamp:4462736906 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345588: rtcpu_nvcsi_intr: tstamp:4462736906 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345588: rtcpu_nvcsi_intr: tstamp:4462737580 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345588: rtcpu_nvcsi_intr: tstamp:4462737580 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345588: rtcpu_nvcsi_intr: tstamp:4462738253 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345589: rtcpu_nvcsi_intr: tstamp:4462738253 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345589: rtcpu_nvcsi_intr: tstamp:4462738948 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345589: rtcpu_nvcsi_intr: tstamp:4462738948 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345589: rtcpu_nvcsi_intr: tstamp:4462739620 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345589: rtcpu_nvcsi_intr: tstamp:4462739620 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345589: rtcpu_nvcsi_intr: tstamp:4462740294 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345590: rtcpu_nvcsi_intr: tstamp:4462740294 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345590: rtcpu_nvcsi_intr: tstamp:4462740967 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
     kworker/0:1-731   [000] ....   136.345590: rtcpu_nvcsi_intr: tstamp:4462740967 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345590: rtcpu_nvcsi_intr: tstamp:4462740967 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
     kworker/0:1-731   [000] ....   136.345590: rtcpu_nvcsi_intr: tstamp:4462740967 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345590: rtcpu_nvcsi_intr: tstamp:4462742155 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
     kworker/0:1-731   [000] ....   136.345591: rtcpu_nvcsi_intr: tstamp:4462742155 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345591: rtcpu_nvcsi_intr: tstamp:4462742155 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
     kworker/0:1-731   [000] ....   136.345591: rtcpu_nvcsi_intr: tstamp:4462742155 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345591: rtcpu_nvcsi_intr: tstamp:4462743328 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345591: rtcpu_nvcsi_intr: tstamp:4462743328 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345591: rtcpu_nvcsi_intr: tstamp:4462744023 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345592: rtcpu_nvcsi_intr: tstamp:4462744023 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345592: rtcpu_nvcsi_intr: tstamp:4462744696 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
     kworker/0:1-731   [000] ....   136.345592: rtcpu_nvcsi_intr: tstamp:4462744696 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345592: rtcpu_nvcsi_intr: tstamp:4462744696 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
     kworker/0:1-731   [000] ....   136.345592: rtcpu_nvcsi_intr: tstamp:4462744696 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345592: rtcpu_nvcsi_intr: tstamp:4462745911 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345593: rtcpu_nvcsi_intr: tstamp:4462745911 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345593: rtcpu_nvcsi_intr: tstamp:4462746604 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345593: rtcpu_nvcsi_intr: tstamp:4462746604 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345593: rtcpu_nvcsi_intr: tstamp:4462747279 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345593: rtcpu_nvcsi_intr: tstamp:4462747279 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345594: rtcpu_nvcsi_intr: tstamp:4462747952 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345594: rtcpu_nvcsi_intr: tstamp:4462747952 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345594: rtcpu_nvcsi_intr: tstamp:4462748625 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345594: rtcpu_nvcsi_intr: tstamp:4462748625 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345594: rtcpu_nvcsi_intr: tstamp:4462749315 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345594: rtcpu_nvcsi_intr: tstamp:4462749315 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345595: rtcpu_nvcsi_intr: tstamp:4462749987 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345595: rtcpu_nvcsi_intr: tstamp:4462749987 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345595: rtcpu_nvcsi_intr: tstamp:4462750662 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345595: rtcpu_nvcsi_intr: tstamp:4462750662 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345595: rtcpu_nvcsi_intr: tstamp:4462751335 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345595: rtcpu_nvcsi_intr: tstamp:4462751335 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345596: rtcpu_nvcsi_intr: tstamp:4462752021 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345596: rtcpu_nvcsi_intr: tstamp:4462752021 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345596: rtcpu_nvcsi_intr: tstamp:4462752693 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345596: rtcpu_nvcsi_intr: tstamp:4462752693 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345596: rtcpu_nvcsi_intr: tstamp:4462753366 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
     kworker/0:1-731   [000] ....   136.345597: rtcpu_nvcsi_intr: tstamp:4462753366 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345597: rtcpu_nvcsi_intr: tstamp:4462753366 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
     kworker/0:1-731   [000] ....   136.345597: rtcpu_nvcsi_intr: tstamp:4462753366 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345597: rtcpu_nvcsi_intr: tstamp:4462754552 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345597: rtcpu_nvcsi_intr: tstamp:4462754552 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345597: rtcpu_nvcsi_intr: tstamp:4462755229 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345597: rtcpu_nvcsi_intr: tstamp:4462755229 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
     kworker/0:1-731   [000] ....   136.345598: rtcpu_nvcsi_intr: tstamp:4462755229 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345598: rtcpu_nvcsi_intr: tstamp:4462756143 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
     kworker/0:1-731   [000] ....   136.345598: rtcpu_nvcsi_intr: tstamp:4462756143 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345598: rtcpu_nvcsi_intr: tstamp:4462756143 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345598: rtcpu_nvcsi_intr: tstamp:4462757091 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
     kworker/0:1-731   [000] ....   136.345598: rtcpu_nvcsi_intr: tstamp:4462757091 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345599: rtcpu_nvcsi_intr: tstamp:4462757091 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
     kworker/0:1-731   [000] ....   136.345599: rtcpu_nvcsi_intr: tstamp:4462757091 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345599: rtcpu_nvcsi_intr: tstamp:4462758265 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345599: rtcpu_nvcsi_intr: tstamp:4462758265 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345599: rtcpu_nvcsi_intr: tstamp:4462758947 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345599: rtcpu_nvcsi_intr: tstamp:4462758947 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345600: rtcpu_nvcsi_intr: tstamp:4462759639 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345600: rtcpu_nvcsi_intr: tstamp:4462759639 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345600: rtcpu_nvcsi_intr: tstamp:4462760311 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345600: rtcpu_nvcsi_intr: tstamp:4462760311 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345600: rtcpu_nvcsi_intr: tstamp:4462760984 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345601: rtcpu_nvcsi_intr: tstamp:4462760984 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345601: rtcpu_nvcsi_intr: tstamp:4462761657 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345601: rtcpu_nvcsi_intr: tstamp:4462761657 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345601: rtcpu_nvcsi_intr: tstamp:4462762344 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345601: rtcpu_nvcsi_intr: tstamp:4462762344 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345601: rtcpu_nvcsi_intr: tstamp:4462763016 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345602: rtcpu_nvcsi_intr: tstamp:4462763016 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345602: rtcpu_nvcsi_intr: tstamp:4462763690 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
     kworker/0:1-731   [000] ....   136.345602: rtcpu_nvcsi_intr: tstamp:4462763690 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345602: rtcpu_nvcsi_intr: tstamp:4462763690 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
     kworker/0:1-731   [000] ....   136.345602: rtcpu_nvcsi_intr: tstamp:4462763690 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345602: rtcpu_nvcsi_intr: tstamp:4462764878 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345603: rtcpu_nvcsi_intr: tstamp:4462764878 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345603: rtcpu_nvcsi_intr: tstamp:4462765553 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345603: rtcpu_nvcsi_intr: tstamp:4462765553 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345603: rtcpu_nvcsi_intr: tstamp:4462766226 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345603: rtcpu_nvcsi_intr: tstamp:4462766226 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345603: rtcpu_nvcsi_intr: tstamp:4462766903 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345604: rtcpu_nvcsi_intr: tstamp:4462766903 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
     kworker/0:1-731   [000] ....   136.345604: rtcpu_nvcsi_intr: tstamp:4462766903 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345604: rtcpu_nvcsi_intr: tstamp:4462767837 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
     kworker/0:1-731   [000] ....   136.345604: rtcpu_nvcsi_intr: tstamp:4462767837 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345604: rtcpu_nvcsi_intr: tstamp:4462767837 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345604: rtcpu_nvcsi_intr: tstamp:4462768765 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345605: rtcpu_nvcsi_intr: tstamp:4462768765 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345605: rtcpu_nvcsi_intr: tstamp:4462769434 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345605: rtcpu_nvcsi_intr: tstamp:4462769434 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345605: rtcpu_nvcsi_intr: tstamp:4462770120 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345605: rtcpu_nvcsi_intr: tstamp:4462770120 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345605: rtcpu_nvcsi_intr: tstamp:4462770793 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
     kworker/0:1-731   [000] ....   136.345606: rtcpu_nvcsi_intr: tstamp:4462770793 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345606: rtcpu_nvcsi_intr: tstamp:4462770793 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
     kworker/0:1-731   [000] ....   136.345606: rtcpu_nvcsi_intr: tstamp:4462770793 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345606: rtcpu_nvcsi_intr: tstamp:4462771965 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345606: rtcpu_nvcsi_intr: tstamp:4462771965 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345606: rtcpu_nvcsi_intr: tstamp:4462772658 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345607: rtcpu_nvcsi_intr: tstamp:4462772658 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345607: rtcpu_nvcsi_intr: tstamp:4462773335 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345607: rtcpu_nvcsi_intr: tstamp:4462773335 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345607: rtcpu_nvcsi_intr: tstamp:4462774009 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345607: rtcpu_nvcsi_intr: tstamp:4462774009 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345607: rtcpu_nvcsi_intr: tstamp:4462774682 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345608: rtcpu_nvcsi_intr: tstamp:4462774682 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345608: rtcpu_nvcsi_intr: tstamp:4462775369 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345608: rtcpu_nvcsi_intr: tstamp:4462775369 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
     kworker/0:1-731   [000] ....   136.345608: rtcpu_nvcsi_intr: tstamp:4462775369 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345608: rtcpu_nvcsi_intr: tstamp:4462776281 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
     kworker/0:1-731   [000] ....   136.345608: rtcpu_nvcsi_intr: tstamp:4462776281 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345609: rtcpu_nvcsi_intr: tstamp:4462776281 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345609: rtcpu_nvcsi_intr: tstamp:4462777265 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345609: rtcpu_nvcsi_intr: tstamp:4462777265 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345609: rtcpu_nvcsi_intr: tstamp:4462777948 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345609: rtcpu_nvcsi_intr: tstamp:4462777948 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
     kworker/0:1-731   [000] ....   136.345609: rtcpu_nvcsi_intr: tstamp:4462777948 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345610: rtcpu_nvcsi_intr: tstamp:4462778839 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
     kworker/0:1-731   [000] ....   136.345610: rtcpu_nvcsi_intr: tstamp:4462778839 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345610: rtcpu_nvcsi_intr: tstamp:4462778839 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
     kworker/0:1-731   [000] ....   136.345610: rtcpu_nvcsi_intr: tstamp:4462778839 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345610: rtcpu_nvcsi_intr: tstamp:4462780005 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
     kworker/0:1-731   [000] ....   136.345610: rtcpu_nvcsi_intr: tstamp:4462780005 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345611: rtcpu_nvcsi_intr: tstamp:4462780005 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345611: rtcpu_nvcsi_intr: tstamp:4462780936 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345611: rtcpu_nvcsi_intr: tstamp:4462780936 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345611: rtcpu_nvcsi_intr: tstamp:4462781609 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345611: rtcpu_nvcsi_intr: tstamp:4462781609 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345611: rtcpu_nvcsi_intr: tstamp:4462782273 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345612: rtcpu_nvcsi_intr: tstamp:4462782273 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345612: rtcpu_nvcsi_intr: tstamp:4462782968 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345612: rtcpu_nvcsi_intr: tstamp:4462782968 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345612: rtcpu_nvcsi_intr: tstamp:4462783642 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345612: rtcpu_nvcsi_intr: tstamp:4462783642 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345613: rtcpu_nvcsi_intr: tstamp:4462784316 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345613: rtcpu_nvcsi_intr: tstamp:4462784316 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345614: rtcpu_nvcsi_intr: tstamp:4462784989 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345614: rtcpu_nvcsi_intr: tstamp:4462784989 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345614: rtcpu_nvcsi_intr: tstamp:4462785683 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345614: rtcpu_nvcsi_intr: tstamp:4462785683 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345614: rtcpu_nvcsi_intr: tstamp:4462786352 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345614: rtcpu_nvcsi_intr: tstamp:4462786352 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
     kworker/0:1-731   [000] ....   136.345615: rtcpu_nvcsi_intr: tstamp:4462786352 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345615: rtcpu_nvcsi_intr: tstamp:4462787266 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
     kworker/0:1-731   [000] ....   136.345615: rtcpu_nvcsi_intr: tstamp:4462787266 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345615: rtcpu_nvcsi_intr: tstamp:4462787266 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
     kworker/0:1-731   [000] ....   136.345615: rtcpu_nvcsi_intr: tstamp:4462787266 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345615: rtcpu_nvcsi_intr: tstamp:4462788454 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
     kworker/0:1-731   [000] ....   136.345616: rtcpu_nvcsi_intr: tstamp:4462788454 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345616: rtcpu_nvcsi_intr: tstamp:4462788454 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345616: rtcpu_nvcsi_intr: tstamp:4462789384 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345616: rtcpu_nvcsi_intr: tstamp:4462789384 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345616: rtcpu_nvcsi_intr: tstamp:4462790058 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345617: rtcpu_nvcsi_intr: tstamp:4462790058 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
     kworker/0:1-731   [000] ....   136.345617: rtcpu_nvcsi_intr: tstamp:4462790058 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345617: rtcpu_nvcsi_intr: tstamp:4462790981 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
     kworker/0:1-731   [000] ....   136.345617: rtcpu_nvcsi_intr: tstamp:4462790981 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345617: rtcpu_nvcsi_intr: tstamp:4462790981 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345617: rtcpu_nvcsi_intr: tstamp:4462791915 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345618: rtcpu_nvcsi_intr: tstamp:4462791915 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345618: rtcpu_nvcsi_intr: tstamp:4462792588 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345618: rtcpu_nvcsi_intr: tstamp:4462792588 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345618: rtcpu_nvcsi_intr: tstamp:4462793280 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345618: rtcpu_nvcsi_intr: tstamp:4462793280 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345618: rtcpu_nvcsi_intr: tstamp:4462793953 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345619: rtcpu_nvcsi_intr: tstamp:4462793953 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345619: rtcpu_nvcsi_intr: tstamp:4462794626 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345619: rtcpu_nvcsi_intr: tstamp:4462794626 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345619: rtcpu_nvcsi_intr: tstamp:4462795299 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345619: rtcpu_nvcsi_intr: tstamp:4462795299 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345619: rtcpu_nvcsi_intr: tstamp:4462795990 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345620: rtcpu_nvcsi_intr: tstamp:4462795990 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345620: rtcpu_nvcsi_intr: tstamp:4462796661 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345620: rtcpu_nvcsi_intr: tstamp:4462796661 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345620: rtcpu_nvcsi_intr: tstamp:4462797336 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345620: rtcpu_nvcsi_intr: tstamp:4462797336 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345620: rtcpu_nvcsi_intr: tstamp:4462798009 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345621: rtcpu_nvcsi_intr: tstamp:4462798009 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345621: rtcpu_nvcsi_intr: tstamp:4462798698 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
     kworker/0:1-731   [000] ....   136.345621: rtcpu_nvcsi_intr: tstamp:4462798698 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345621: rtcpu_nvcsi_intr: tstamp:4462798698 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
     kworker/0:1-731   [000] ....   136.345621: rtcpu_nvcsi_intr: tstamp:4462798698 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345622: rtcpu_nvcsi_intr: tstamp:4462799869 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345622: rtcpu_nvcsi_intr: tstamp:4462799869 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345622: rtcpu_nvcsi_intr: tstamp:4462800551 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345622: rtcpu_nvcsi_intr: tstamp:4462800551 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345622: rtcpu_nvcsi_intr: tstamp:4462801246 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
     kworker/0:1-731   [000] ....   136.345622: rtcpu_nvcsi_intr: tstamp:4462801246 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345623: rtcpu_nvcsi_intr: tstamp:4462801246 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
     kworker/0:1-731   [000] ....   136.345623: rtcpu_nvcsi_intr: tstamp:4462801246 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345623: rtcpu_nvcsi_intr: tstamp:4462802419 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
     kworker/0:1-731   [000] ....   136.345623: rtcpu_nvcsi_intr: tstamp:4462802419 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345623: rtcpu_nvcsi_intr: tstamp:4462802419 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
     kworker/0:1-731   [000] ....   136.345623: rtcpu_nvcsi_intr: tstamp:4462802419 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345623: rtcpu_nvcsi_intr: tstamp:4462803608 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345624: rtcpu_nvcsi_intr: tstamp:4462803608 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345624: rtcpu_nvcsi_intr: tstamp:4462804285 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345624: rtcpu_nvcsi_intr: tstamp:4462804285 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345624: rtcpu_nvcsi_intr: tstamp:4462804961 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345624: rtcpu_nvcsi_intr: tstamp:4462804961 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345625: rtcpu_nvcsi_intr: tstamp:4462805634 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345625: rtcpu_nvcsi_intr: tstamp:4462805634 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345625: rtcpu_nvcsi_intr: tstamp:4462806335 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345625: rtcpu_nvcsi_intr: tstamp:4462806335 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345625: rtcpu_nvcsi_intr: tstamp:4462807015 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345625: rtcpu_nvcsi_intr: tstamp:4462807015 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345626: rtcpu_nvcsi_intr: tstamp:4462807693 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345626: rtcpu_nvcsi_intr: tstamp:4462807693 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345626: rtcpu_nvcsi_intr: tstamp:4462808418 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345626: rtcpu_nvcsi_intr: tstamp:4462808418 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345626: rtcpu_nvcsi_intr: tstamp:4462809119 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
     kworker/0:1-731   [000] ....   136.345626: rtcpu_nvcsi_intr: tstamp:4462809119 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345627: rtcpu_nvcsi_intr: tstamp:4462809119 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
     kworker/0:1-731   [000] ....   136.345627: rtcpu_nvcsi_intr: tstamp:4462809119 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345627: rtcpu_nvcsi_intr: tstamp:4462810293 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345627: rtcpu_nvcsi_intr: tstamp:4462810293 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345627: rtcpu_nvcsi_intr: tstamp:4462810972 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345627: rtcpu_nvcsi_intr: tstamp:4462810972 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345628: rtcpu_nvcsi_intr: tstamp:4462811671 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345628: rtcpu_nvcsi_intr: tstamp:4462811671 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345628: rtcpu_nvcsi_intr: tstamp:4462812349 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345628: rtcpu_nvcsi_intr: tstamp:4462812349 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
     kworker/0:1-731   [000] ....   136.345628: rtcpu_nvcsi_intr: tstamp:4462812349 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345628: rtcpu_nvcsi_intr: tstamp:4462813271 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
     kworker/0:1-731   [000] ....   136.345629: rtcpu_nvcsi_intr: tstamp:4462813271 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345629: rtcpu_nvcsi_intr: tstamp:4462813271 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345629: rtcpu_nvcsi_intr: tstamp:4462814227 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345629: rtcpu_nvcsi_intr: tstamp:4462814227 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345629: rtcpu_nvcsi_intr: tstamp:4462814905 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345629: rtcpu_nvcsi_intr: tstamp:4462814905 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345630: rtcpu_nvcsi_intr: tstamp:4462815582 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345630: rtcpu_nvcsi_intr: tstamp:4462815582 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345630: rtcpu_nvcsi_intr: tstamp:4462816260 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
     kworker/0:1-731   [000] ....   136.345630: rtcpu_nvcsi_intr: tstamp:4462816260 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345630: rtcpu_nvcsi_intr: tstamp:4462816260 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
     kworker/0:1-731   [000] ....   136.345630: rtcpu_nvcsi_intr: tstamp:4462816260 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345631: rtcpu_nvcsi_intr: tstamp:4462817432 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345631: rtcpu_nvcsi_intr: tstamp:4462817432 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345631: rtcpu_nvcsi_intr: tstamp:4462818112 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345631: rtcpu_nvcsi_intr: tstamp:4462818112 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345631: rtcpu_nvcsi_intr: tstamp:4462818795 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345631: rtcpu_nvcsi_intr: tstamp:4462818795 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345632: rtcpu_nvcsi_intr: tstamp:4462819495 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345632: rtcpu_nvcsi_intr: tstamp:4462819495 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345632: rtcpu_nvcsi_intr: tstamp:4462820171 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345632: rtcpu_nvcsi_intr: tstamp:4462820171 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345632: rtcpu_nvcsi_intr: tstamp:4462820848 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345633: rtcpu_nvcsi_intr: tstamp:4462820848 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
     kworker/0:1-731   [000] ....   136.345633: rtcpu_nvcsi_intr: tstamp:4462820848 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345634: rtcpu_nvcsi_intr: tstamp:4462821772 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
     kworker/0:1-731   [000] ....   136.345634: rtcpu_nvcsi_intr: tstamp:4462821772 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345634: rtcpu_nvcsi_intr: tstamp:4462821772 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345634: rtcpu_nvcsi_intr: tstamp:4462822703 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345634: rtcpu_nvcsi_intr: tstamp:4462822703 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345634: rtcpu_nvcsi_intr: tstamp:4462823383 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345635: rtcpu_nvcsi_intr: tstamp:4462823383 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
     kworker/0:1-731   [000] ....   136.345635: rtcpu_nvcsi_intr: tstamp:4462823383 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345635: rtcpu_nvcsi_intr: tstamp:4462824307 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
     kworker/0:1-731   [000] ....   136.345635: rtcpu_nvcsi_intr: tstamp:4462824307 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345635: rtcpu_nvcsi_intr: tstamp:4462824307 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
     kworker/0:1-731   [000] ....   136.345635: rtcpu_nvcsi_intr: tstamp:4462824307 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345636: rtcpu_nvcsi_intr: tstamp:4462825507 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
     kworker/0:1-731   [000] ....   136.345636: rtcpu_nvcsi_intr: tstamp:4462825507 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345636: rtcpu_nvcsi_intr: tstamp:4462825507 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345636: rtcpu_nvcsi_intr: tstamp:4462826444 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345636: rtcpu_nvcsi_intr: tstamp:4462826444 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345637: rtcpu_nvcsi_intr: tstamp:4462827146 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345637: rtcpu_nvcsi_intr: tstamp:4462827146 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345637: rtcpu_nvcsi_intr: tstamp:4462827824 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345637: rtcpu_nvcsi_intr: tstamp:4462827824 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345637: rtcpu_nvcsi_intr: tstamp:4462828502 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345637: rtcpu_nvcsi_intr: tstamp:4462828502 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345638: rtcpu_nvcsi_intr: tstamp:4462829175 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345638: rtcpu_nvcsi_intr: tstamp:4462829175 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345638: rtcpu_nvcsi_intr: tstamp:4462829875 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345638: rtcpu_nvcsi_intr: tstamp:4462829875 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345638: rtcpu_nvcsi_intr: tstamp:4462830551 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345638: rtcpu_nvcsi_intr: tstamp:4462830551 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345639: rtcpu_nvcsi_intr: tstamp:4462831226 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345639: rtcpu_nvcsi_intr: tstamp:4462831226 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345639: rtcpu_nvcsi_intr: tstamp:4462831906 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345639: rtcpu_nvcsi_intr: tstamp:4462831906 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
     kworker/0:1-731   [000] ....   136.345639: rtcpu_nvcsi_intr: tstamp:4462831906 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345639: rtcpu_nvcsi_intr: tstamp:4462832847 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
     kworker/0:1-731   [000] ....   136.345640: rtcpu_nvcsi_intr: tstamp:4462832847 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345640: rtcpu_nvcsi_intr: tstamp:4462832847 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
     kworker/0:1-731   [000] ....   136.345640: rtcpu_nvcsi_intr: tstamp:4462832847 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   136.345640: rtcpu_nvcsi_intr: tstamp:4462834014 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
     kworker/0:1-731   [000] ....   136.345640: rtcpu_nvcsi_intr: tstamp:4462834014 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   138.081537: rtcpu_vinotify_error: tstamp:4516879875 tag:CSIMUX_FRAME channel:0x00 frame:2 vi_tstamp:4516389992 data:0x000004a0
     kworker/0:1-731   [000] ....   138.081538: rtcpu_vinotify_error: tstamp:4516880727 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4516390550 data:0x00000569
     kworker/0:1-731   [000] ....   138.081538: rtcpu_vinotify_event: tstamp:4516881512 tag:CSIMUX_FRAME channel:0x00 frame:2 vi_tstamp:4516389992 data:0x000004a0
     kworker/0:1-731   [000] ....   138.081538: rtcpu_vinotify_event: tstamp:4516881668 tag:FS channel:0x00 frame:1 vi_tstamp:4516389992 data:0x00000010
     kworker/0:1-731   [000] ....   138.081539: rtcpu_vinotify_event: tstamp:4516881829 tag:CHANSEL_NOMATCH channel:0x01 frame:1 vi_tstamp:4516390550 data:0x00000569
     kworker/0:1-731   [000] ....   138.081539: rtcpu_nvcsi_intr: tstamp:4516896593 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000008
     kworker/0:1-731   [000] ....   138.081539: rtcpu_nvcsi_intr: tstamp:4516896593 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   138.081539: rtcpu_nvcsi_intr: tstamp:4516896593 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000008
     kworker/0:1-731   [000] ....   138.081540: rtcpu_nvcsi_intr: tstamp:4516896593 class:CORRECTABLE_ERR type:PHY_INTR phy:0 cil:0 st:0 vc:0 status:0x00000110
     kworker/0:1-731   [000] ....   138.081540: rtos_queue_send_from_isr_failed: tstamp:4516897812 queue:0x0bcb41f8
     kworker/0:1-731   [000] ....   138.081540: rtos_queue_send_from_isr_failed: tstamp:4516897952 queue:0x0bcb8a60
     kworker/0:1-731   [000] ....   138.081541: rtos_queue_send_from_isr_failed: tstamp:4516898092 queue:0x0bcba5e0
     kworker/0:1-731   [000] ....   138.081541: rtos_queue_send_from_isr_failed: tstamp:4516898227 queue:0x0bcbb3a0
     kworker/0:1-731   [000] ....   138.081541: rtos_queue_send_from_isr_failed: tstamp:4516898377 queue:0x0bcbc160
hello purehearted,
it’s rxfifo full for lane-0 and lane-1, which usually means the clock is too slow for the receiving module.
please adjust the clock settings to have verification,
thanks
hello JerryChang,
I have try to boost the clock,
echo 998400000 > /sys/kernel/debug/bpmp/debug/clk/vi/rate
echo 1190400000 > /sys/kernel/debug/bpmp/debug/clk/isp/rate
echo 400000000 > /sys/kernel/debug/bpmp/debug/clk/nvcsi/rate
ub954 set to 800Mpbs and 2lanes, v4l2-ctl cmd is
v4l2-ctl --set-fmt-video=width=1280,height=720,pixelformat=RG12 --stream-mmap --set-ctrl bypass_mode=0 --stream-count=1 -d /dev/video0
,the dmesg and trace have no changes.
thanks
hello purehearted,
please refer to SerDes Pixel Clock session, and review your serdes_pix_clk_hz device tree settings.
thanks
It works,thanks
