hi nvidia:
I have a  yuv camera(ov10640+ov490+max96705), I can not get image, but from trace,
rtcpu_vinotify_event: tstamp:7011255548 cch:0 vi:0 tag:CHANSEL_SHORT_FRAME channel:0x10 frame:0 vi_tstamp:224349432704 data:0x0000200001000000
how to decode  data:0x0000200001000000 ? what is mean?
trace-20240507.txt (272.6 KB)
kernel log:
[  197.515078] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_power_on
[  197.534833] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_start_streaming: csi_pt=4, st_id=4, vc_id=0, pg_mode=0x0
[  197.534837] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_set_config: stream_id=4, csi_port=4 is_cphy=1
[  197.534840] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: cil_settingtime is pulled from device
[  197.534842] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_set_config: phy_mode=1, lane_polarity=0 4 0 4 numlanes=4 lp_bypass_mode=0
[  197.535159] senyun 3-0045: senyun_start_streaming:
[  197.539163] max96712 3-004d: max96712_start_streaming: write err:0 reg:0x8A0 val:0x84
[  197.539167] IR-Pilot180P || max96705
[  197.539169] IR-Pilot180P || max96705
[  197.539172] pegasus_cdi_event event:13 data:8 ts:4294941681 camera start streaming
[  197.583641] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, status:e err_data 131072
[  197.623688] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, status:e err_data 131072
[  197.663667] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, status:e err_data 131072
[  197.703689] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, status:e err_data 131072
[  197.743631] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, status:e err_data 131072
[  197.783642] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, status:e err_data 131072
[  197.823618] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, status:e err_data 131072
[  197.863631] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, status:e err_data 131072
[  197.903628] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, status:e err_data 131072
[  197.943631] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, status:e err_data 131072
[  202.623620] vi5_capture_dequeue: 116 callbacks suppressed
[  202.623629] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, status:e err_data 131072
[  202.663663] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, status:e err_data 131072
[  202.703659] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, status:e err_data 131072
[  202.743647] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, status:e err_data 131072
[  202.783649] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, status:e err_data 131072
[  202.823622] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, status:e err_data 131072
[  202.863647] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, status:e err_data 131072
[  202.903622] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, status:e err_data 131072
[  202.943631] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, status:e err_data 131072
[  202.983622] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, status:e err_data 131072
