Hi, Jerry
I modified the configuration of SER DSER again. This time, when I used 32x32 to capture images, there seemed to be some differences. Please take a look at the following dmesg log and trace log.
By the way,
I flashed the RCE debug firmware of Jetpack 5.1.1.dmesg log:
sq@ubuntu:~/test$ ./v4l2-ctl -d /dev/video0 --set-fmt-video=width=32,height=32 --stream-mmap
[Wed May 22 16:15:59 2024] bwmgr API not supported
[Wed May 22 16:15:59 2024] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 256
[Wed May 22 16:15:59 2024] [RCE] VM0 deactivating.VM0 activating.NVCSILP clock rate = 408000000 Hz.
[Wed May 22 16:15:59 2024] [RCE] tegra_nvcsi_stream_set_config(vm0, stream=0, csi=0)
[Wed May 22 16:15:59 2024] [RCE] MIPI clock = 700000 kHz, tHS-SETTLE = 0, tCLK-SETTLE = 0
[Wed May 22 16:15:59 2024] [RCE] ===== NVCSI Stream Configuration =====
[Wed May 22 16:15:59 2024] [RCE] stream_id: PP 0, csi_port: PORT A
[Wed May 22 16:15:59 2024] [RCE] Brick: PHY 0, Mode: D-PHY
[Wed May 22 16:15:59 2024] [RCE] Partition: CIL A, LP bypass: Enabled, Lanes: 4
[Wed May 22 16:15:59 2024] [RCE] Clock information:
[Wed May 22 16:15:59 2024] [RCE] MIPI clock rate: 700.00 MHz
[Wed May 22 16:15:59 2024] [RCE] T_HS settle: 0, T_CLK settle: 0
[Wed May 22 16:15:59 2024] [RCE] ======================================
[Wed May 22 16:15:59 2024] [RCE] tegra_nvcsi_stream_open(vm0, stream=0, csi=0)
[Wed May 22 16:15:59 2024] [RCE] nvcsi_calc_ths_settle ths_settle 53
[Wed May 22 16:15:59 2024] [RCE] nvcsi_calc_tclk_settle tclk_settle 75
[Wed May 22 16:15:59 2024] [RCE] ISR PHY 0 CIL_A 0xe000000
[Wed May 22 16:15:59 2024] [RCE] ISR PHY 0 CIL_B 0x6000000
[Wed May 22 16:16:00 2024] [RCE] ISR PHY 0 CIL_A 0xe000000
[Wed May 22 16:16:00 2024] [RCE] ISR PHY 0 CIL_B 0x6000000
^C[Wed May 22 16:16:00 2024] bwmgr API not supported
[Wed May 22 16:16:00 2024] [RCE] tegra_nvcsi_stream_close(vm0, stream=0, csi=0)
trace log:
kworker/3:2-153 [003] .... 1106.583632: rtcpu_string: tstamp:35516939344 id:0x04010000 str:"VM0 deactivating."
v4l2-ctl-2776 [000] .... 1107.150030: tegra_channel_open: vi-output, max96724 2-0004
v4l2-ctl-2776 [000] .... 1107.150960: tegra_channel_set_power: max96724 2-0004 : 0x1
v4l2-ctl-2776 [000] .... 1107.150972: camera_common_s_power: status : 0x1
v4l2-ctl-2776 [000] .... 1107.150996: tegra_channel_set_power: 13e40000.host1x:nvcsi@15a00000- : 0x1
v4l2-ctl-2776 [000] .... 1107.151003: csi_s_power: enable : 0x1
v4l2-ctl-2776 [001] .... 1107.157457: tegra_channel_capture_setup: vnc_id 0 W 32 H 32 fmt 13
v4l2-ctl-2776 [001] .... 1107.167650: tegra_channel_set_stream: enable : 0x1
v4l2-ctl-2776 [001] .... 1107.179886: tegra_channel_set_stream: 13e40000.host1x:nvcsi@15a00000- : 0x1
v4l2-ctl-2776 [001] .... 1107.179888: csi_s_stream: enable : 0x1
v4l2-ctl-2776 [001] .... 1107.180325: tegra_channel_set_stream: max96724 2-0004 : 0x1
kworker/3:0-2716 [003] .... 1107.198800: rtcpu_string: tstamp:35535052471 id:0x04010000 str:"VM0 activating."
kworker/3:0-2716 [003] .... 1107.198802: rtcpu_string: tstamp:35535155991 id:0x04010000 str:"NVCSILP clock rate = 408000000 Hz.
kworker/3:0-2716 [003] .... 1107.209281: rtcpu_vinotify_event: tstamp:35535531305 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:1137126909632 data:0x399d580010000000
kworker/3:0-2716 [003] .... 1107.209282: rtcpu_vinotify_event: tstamp:35535531560 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:1137126916128 data:0x0000000031000001
kworker/3:0-2716 [003] .... 1107.209282: rtcpu_vinotify_event: tstamp:35535531813 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:1137126976864 data:0x399d550010000000
kworker/3:0-2716 [003] .... 1107.209282: rtcpu_vinotify_event: tstamp:35535532027 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:1137126983456 data:0x0000000031000002
kworker/3:0-2716 [003] .... 1107.209282: rtcpu_string: tstamp:35535596975 id:0x04010000 str:"tegra_nvcsi_stream_set_config(vm0, stream=0, csi"
kworker/3:0-2716 [003] .... 1107.209283: rtcpu_string: tstamp:35535597088 id:0x04010000 str:"=0)
kworker/3:0-2716 [003] .... 1107.209286: rtcpu_string: tstamp:35535597460 id:0x04010000 str:"MIPI clock = 700000 kHz, tHS-SETTLE = 0, tCLK-SE"
kworker/3:0-2716 [003] .... 1107.209286: rtcpu_string: tstamp:35535597565 id:0x04010000 str:"TTLE = 0
kworker/3:0-2716 [003] .... 1107.209288: rtcpu_string: tstamp:35535597779 id:0x04010000 str:"===== NVCSI Stream Configuration =====
kworker/3:0-2716 [003] .... 1107.209289: rtcpu_string: tstamp:35535598027 id:0x04010000 str:"stream_id: PP 0, csi_port: PORT A
kworker/3:0-2716 [003] .... 1107.209291: rtcpu_string: tstamp:35535598289 id:0x04010000 str:"Brick: PHY 0, Mode: D-PHY
kworker/3:0-2716 [003] .... 1107.209292: rtcpu_string: tstamp:35535598574 id:0x04010000 str:"Partition: CIL A, LP bypass: Enabled, Lanes: 4
kworker/3:0-2716 [003] .... 1107.209293: rtcpu_string: tstamp:35535598754 id:0x04010000 str:"Clock information:
kworker/3:0-2716 [003] .... 1107.209295: rtcpu_string: tstamp:35535599055 id:0x04010000 str:"MIPI clock rate: 700.00 MHz
kworker/3:0-2716 [003] .... 1107.209296: rtcpu_string: tstamp:35535599300 id:0x04010000 str:"T_HS settle: 0, T_CLK settle: 0
kworker/3:0-2716 [003] .... 1107.209298: rtcpu_string: tstamp:35535599526 id:0x04010000 str:"======================================
kworker/3:0-2716 [003] .... 1107.209299: rtcpu_string: tstamp:35535601082 id:0x04010000 str:"tegra_nvcsi_stream_open(vm0, stream=0, csi=0)
kworker/3:0-2716 [003] .... 1107.209301: rtcpu_string: tstamp:35535608001 id:0x04010000 str:"nvcsi_calc_ths_settle ths_settle 53
kworker/3:0-2716 [003] .... 1107.209302: rtcpu_string: tstamp:35535608264 id:0x04010000 str:"nvcsi_calc_ths_settle ths_settle 53
kworker/3:0-2716 [003] .... 1107.209303: rtcpu_string: tstamp:35535608524 id:0x04010000 str:"nvcsi_calc_ths_settle ths_settle 53
kworker/3:0-2716 [003] .... 1107.209305: rtcpu_string: tstamp:35535608783 id:0x04010000 str:"nvcsi_calc_tclk_settle tclk_settle 75
kworker/3:0-2716 [003] .... 1107.209307: rtcpu_vinotify_error: tstamp:35535610026 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1137139497504 data:0x0000000000000001
kworker/3:0-2716 [003] .... 1107.209307: rtcpu_vinotify_event: tstamp:35535869400 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1137139497504 data:0x0000000000000001
kworker/3:0-2716 [003] .... 1107.262791: rtcpu_vinotify_event: tstamp:35536207394 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1137154808704 data:0x0000000000000010
kworker/3:0-2716 [003] .... 1107.262792: rtcpu_vinotify_event: tstamp:35536207554 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:1137154808704 data:0x0000000800000000
kworker/3:0-2716 [003] .... 1107.262792: rtcpu_vinotify_event: tstamp:35536207687 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:1137154809376 data:0x0000000000000001
kworker/3:0-2716 [003] .... 1107.262793: rtcpu_vinotify_event: tstamp:35536207839 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:1137154814784 data:0x0000000008020001
kworker/3:0-2716 [003] .... 1107.262793: rtcpu_vinotify_event: tstamp:35536207970 cch:0 vi:0 tag:CHANSEL_FAULT channel:0x23 frame:0 vi_tstamp:1137154809440 data:0x0000000000000100
kworker/3:0-2716 [003] .... 1107.262794: rtcpu_vinotify_event: tstamp:35536208120 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:1137154824992 data:0x0000000001020001
kworker/3:0-2716 [003] .... 1107.262794: rtcpu_vinotify_event: tstamp:35536208251 cch:0 vi:0 tag:CHANSEL_FAULT channel:0x23 frame:0 vi_tstamp:1137156173344 data:0x00000000001f0182
kworker/3:0-2716 [003] .... 1107.262795: rtcpu_vinotify_event: tstamp:35536208400 cch:0 vi:0 tag:ATOMP_FRAME_DONE channel:0x23 frame:0 vi_tstamp:1137156173760 data:0x0000000000000000
kworker/3:0-2716 [003] .... 1107.262795: rtcpu_vinotify_event: tstamp:35536208530 cch:0 vi:0 tag:CHANSEL_FAULT channel:0x23 frame:0 vi_tstamp:1137156217280 data:0x00000000002001c0
kworker/3:0-2716 [003] .... 1107.262795: rtcpu_string: tstamp:35537071153 id:0x04010000 str:"ISR PHY 0 CIL_A 0xe000000
kworker/3:0-2716 [003] .... 1107.271953: rtcpu_nvcsi_intr: tstamp:35537070904 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
kworker/3:0-2716 [003] .... 1107.271953: rtcpu_string: tstamp:35537071544 id:0x04010000 str:"ISR PHY 0 CIL_B 0x6000000
kworker/3:0-2716 [003] .... 1107.271957: rtcpu_nvcsi_intr: tstamp:35537070904 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
kworker/3:0-2716 [003] .... 1107.271958: rtcpu_vinotify_error: tstamp:35537072454 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1137186268864 data:0x0000000000000001
kworker/3:0-2716 [003] .... 1107.271958: rtcpu_vinotify_event: tstamp:35537072952 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1137186265536 data:0x0000000000000020
kworker/3:0-2716 [003] .... 1107.271959: rtcpu_vinotify_event: tstamp:35537073088 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:1137186265568 data:0x0000000800000000
kworker/3:0-2716 [003] .... 1107.271959: rtcpu_vinotify_event: tstamp:35537390584 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1137186268864 data:0x0000000000000001
kworker/3:0-2716 [003] .... 1107.271960: rtcpu_vinotify_event: tstamp:35537390721 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:1137186282528 data:0x399d580010000000
kworker/3:0-2716 [003] .... 1107.271960: rtcpu_vinotify_event: tstamp:35537390877 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:1137186289056 data:0x0000000031000003
kworker/3:0-2716 [003] .... 1107.271960: rtcpu_vinotify_event: tstamp:35537391009 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1137187808224 data:0x0000000000000010
kworker/3:0-2716 [003] .... 1107.271961: rtcpu_vinotify_event: tstamp:35537391165 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:1137187808256 data:0x0000000800000000
kworker/3:0-2716 [003] .... 1107.271961: rtcpu_vinotify_event: tstamp:35537391296 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:1137187808896 data:0x0000000000000001
kworker/3:0-2716 [003] .... 1107.271961: rtcpu_vinotify_event: tstamp:35537391446 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:1137187814304 data:0x0000000008020002
kworker/3:0-2716 [003] .... 1107.271962: rtcpu_vinotify_event: tstamp:35537391579 cch:0 vi:0 tag:CHANSEL_FAULT channel:0x23 frame:0 vi_tstamp:1137187808960 data:0x0000000000000100
kworker/3:0-2716 [003] .... 1107.271962: rtcpu_vinotify_event: tstamp:35537391733 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:1137187824544 data:0x0000000001020002
kworker/3:0-2716 [003] .... 1107.271962: rtcpu_vinotify_event: tstamp:35537391865 cch:0 vi:0 tag:CHANSEL_FAULT channel:0x23 frame:0 vi_tstamp:1137189172864 data:0x00000000001f0182
kworker/3:0-2716 [003] .... 1107.271963: rtcpu_vinotify_event: tstamp:35537392017 cch:0 vi:0 tag:ATOMP_FRAME_DONE channel:0x23 frame:0 vi_tstamp:1137189173280 data:0x0000000000000000
kworker/3:0-2716 [003] .... 1107.271963: rtcpu_vinotify_event: tstamp:35537392149 cch:0 vi:0 tag:CHANSEL_FAULT channel:0x23 frame:0 vi_tstamp:1137189216832 data:0x00000000002001c0
kworker/3:0-2716 [003] .... 1107.271964: rtcpu_vinotify_error: tstamp:35538102910 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1137219268384 data:0x0000000000000001
kworker/3:0-2716 [003] .... 1107.271964: rtcpu_vinotify_event: tstamp:35538103865 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1137219265088 data:0x0000000000000020
kworker/3:0-2716 [003] .... 1107.271965: rtcpu_vinotify_event: tstamp:35538104003 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:1137219265088 data:0x0000000800000000
kworker/3:0-2716 [003] .... 1107.271965: rtcpu_vinotify_event: tstamp:35538104159 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1137219268384 data:0x0000000000000001
kworker/3:0-2716 [003] .... 1107.271965: rtcpu_vinotify_event: tstamp:35538104293 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:1137219295072 data:0x399d550010000000
kworker/3:0-2716 [003] .... 1107.326797: rtcpu_vinotify_event: tstamp:35538438539 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:1137219314944 data:0x0000000031000004
kworker/3:0-2716 [003] .... 1107.326798: rtcpu_vinotify_event: tstamp:35538438677 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1137220807776 data:0x0000000000000010
kworker/3:0-2716 [003] .... 1107.326799: rtcpu_vinotify_event: tstamp:35538438841 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:1137220807808 data:0x0000000800000000
kworker/3:0-2716 [003] .... 1107.326799: rtcpu_vinotify_event: tstamp:35538438976 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:1137220808480 data:0x0000000000000001
kworker/3:0-2716 [003] .... 1107.326799: rtcpu_vinotify_event: tstamp:35538439129 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:1137220813856 data:0x0000000008020003
kworker/3:0-2716 [003] .... 1107.326800: rtcpu_vinotify_event: tstamp:35538439263 cch:0 vi:0 tag:CHANSEL_FAULT channel:0x23 frame:0 vi_tstamp:1137220808512 data:0x0000000000000100
kworker/3:0-2716 [003] .... 1107.326800: rtcpu_vinotify_event: tstamp:35538439416 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:1137220824096 data:0x0000000001020003
kworker/3:0-2716 [003] .... 1107.326801: rtcpu_vinotify_event: tstamp:35538439548 cch:0 vi:0 tag:CHANSEL_FAULT channel:0x23 frame:0 vi_tstamp:1137222172416 data:0x00000000001f0182
kworker/3:0-2716 [003] .... 1107.326801: rtcpu_vinotify_event: tstamp:35538439700 cch:0 vi:0 tag:ATOMP_FRAME_DONE channel:0x23 frame:0 vi_tstamp:1137222172832 data:0x0000000000000000
kworker/3:0-2716 [003] .... 1107.326803: rtcpu_vinotify_event: tstamp:35538439833 cch:0 vi:0 tag:CHANSEL_FAULT channel:0x23 frame:0 vi_tstamp:1137222216352 data:0x00000000002001c0
kworker/3:0-2716 [003] .... 1107.326803: rtcpu_vinotify_error: tstamp:35539134111 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1137252267936 data:0x0000000000000001
kworker/3:0-2716 [003] .... 1107.326804: rtcpu_vinotify_event: tstamp:35539183955 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1137252264608 data:0x0000000000000020
kworker/3:0-2716 [003] .... 1107.326804: rtcpu_vinotify_event: tstamp:35539184094 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:1137252264640 data:0x0000000800000000
kworker/3:0-2716 [003] .... 1107.326805: rtcpu_vinotify_event: tstamp:35539184247 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1137252267936 data:0x0000000000000001
kworker/3:0-2716 [003] .... 1107.326805: rtcpu_vinotify_event: tstamp:35539184378 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1137253807328 data:0x0000000000000010
kworker/3:0-2716 [003] .... 1107.326806: rtcpu_vinotify_event: tstamp:35539184531 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:1137253807328 data:0x0000000800000000
kworker/3:0-2716 [003] .... 1107.326806: rtcpu_vinotify_event: tstamp:35539184662 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:1137253808000 data:0x0000000000000001
kworker/3:0-2716 [003] .... 1107.326806: rtcpu_vinotify_event: tstamp:35539486499 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:1137253814528 data:0x0000000008020004
kworker/3:0-2716 [003] .... 1107.326807: rtcpu_vinotify_event: tstamp:35539486633 cch:0 vi:0 tag:CHANSEL_FAULT channel:0x23 frame:0 vi_tstamp:1137253808064 data:0x0000000000000100
kworker/3:0-2716 [003] .... 1107.326807: rtcpu_vinotify_event: tstamp:35539486783 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:1137253825600 data:0x0000000001020004
kworker/3:0-2716 [003] .... 1107.326807: rtcpu_vinotify_event: tstamp:35539486914 cch:0 vi:0 tag:CHANSEL_FAULT channel:0x23 frame:0 vi_tstamp:1137255171968 data:0x00000000001f0182
kworker/3:0-2716 [003] .... 1107.326808: rtcpu_vinotify_event: tstamp:35539487065 cch:0 vi:0 tag:ATOMP_FRAME_DONE channel:0x23 frame:0 vi_tstamp:1137255172416 data:0x0000000000000000
kworker/3:0-2716 [003] .... 1107.326808: rtcpu_vinotify_event: tstamp:35539487196 cch:0 vi:0 tag:CHANSEL_FAULT channel:0x23 frame:0 vi_tstamp:1137255215904 data:0x00000000002001c0
kworker/3:0-2716 [003] .... 1107.326809: rtcpu_vinotify_error: tstamp:35540165351 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1137285267488 data:0x0000000000000001
kworker/3:0-2716 [003] .... 1107.382954: rtcpu_vinotify_error: tstamp:35540213491 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1137286807520 data:0x00000000000003c9
kworker/3:0-2716 [003] .... 1107.382958: rtcpu_vinotify_event: tstamp:35540500539 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1137285264160 data:0x0000000000000020
kworker/3:0-2716 [003] .... 1107.382958: rtcpu_vinotify_event: tstamp:35540500677 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:1137285264160 data:0x0000000800000000
kworker/3:0-2716 [003] .... 1107.382959: rtcpu_vinotify_event: tstamp:35540500833 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1137285267488 data:0x0000000000000001
kworker/3:0-2716 [003] .... 1107.382959: rtcpu_vinotify_event: tstamp:35540500964 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1137286806848 data:0x0000000000000010
kworker/3:0-2716 [003] .... 1107.382960: rtcpu_vinotify_event: tstamp:35540501114 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1137286807520 data:0x00000000000003c9
kworker/3:0-2716 [003] .... 1107.382961: rtcpu_string: tstamp:35541196114 id:0x04010000 str:"ISR PHY 0 CIL_A 0xe000000
kworker/3:0-2716 [003] .... 1107.382971: rtcpu_nvcsi_intr: tstamp:35541195864 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
kworker/3:0-2716 [003] .... 1107.382972: rtcpu_string: tstamp:35541196509 id:0x04010000 str:"ISR PHY 0 CIL_B 0x6000000
kworker/3:0-2716 [003] .... 1107.382977: rtcpu_nvcsi_intr: tstamp:35541195864 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
kworker/3:0-2716 [003] .... 1107.382977: rtcpu_vinotify_error: tstamp:35541197424 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1137318267008 data:0x0000000000000001
kworker/3:0-2716 [003] .... 1107.382978: rtcpu_vinotify_error: tstamp:35541244728 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1137319807104 data:0x00000000000003c9
kworker/3:0-2716 [003] .... 1107.382978: rtcpu_vinotify_event: tstamp:35541514635 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1137318263712 data:0x0000000000000020
kworker/3:0-2716 [003] .... 1107.382979: rtcpu_vinotify_event: tstamp:35541514792 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1137318267008 data:0x0000000000000001
kworker/3:0-2716 [003] .... 1107.382980: rtcpu_vinotify_event: tstamp:35541514925 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1137319806400 data:0x0000000000000010
kworker/3:0-2716 [003] .... 1107.382980: rtcpu_vinotify_event: tstamp:35541515081 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1137319807104 data:0x00000000000003c9
kworker/3:0-2716 [003] .... 1107.438803: rtcpu_vinotify_error: tstamp:35542227713 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1137351266560 data:0x0000000000000001
kworker/3:0-2716 [003] .... 1107.438807: rtcpu_vinotify_event: tstamp:35542228155 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1137351263232 data:0x0000000000000020
kworker/3:0-2716 [003] .... 1107.438808: rtcpu_vinotify_error: tstamp:35542275961 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1137352806624 data:0x00000000000003c9
kworker/3:0-2716 [003] .... 1107.438808: rtcpu_vinotify_event: tstamp:35542562586 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1137351266560 data:0x0000000000000001
kworker/3:0-2716 [003] .... 1107.438809: rtcpu_vinotify_event: tstamp:35542562717 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1137352805952 data:0x0000000000000010
kworker/3:0-2716 [003] .... 1107.438810: rtcpu_vinotify_event: tstamp:35542562866 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1137352806624 data:0x00000000000003c9
kworker/3:0-2716 [003] .... 1107.438810: rtcpu_vinotify_error: tstamp:35543258999 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1137384266112 data:0x0000000000000001
kworker/3:0-2716 [003] .... 1107.438811: rtcpu_vinotify_error: tstamp:35543307197 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1137385806144 data:0x00000000000003c9
kworker/3:0-2716 [003] .... 1107.438812: rtcpu_vinotify_event: tstamp:35543576838 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1137384262784 data:0x0000000000000020
kworker/3:0-2716 [003] .... 1107.438813: rtcpu_vinotify_event: tstamp:35543576997 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1137384266112 data:0x0000000000000001
kworker/3:0-2716 [003] .... 1107.438814: rtcpu_vinotify_event: tstamp:35543577128 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1137385805472 data:0x0000000000000010
kworker/3:0-2716 [003] .... 1107.438815: rtcpu_vinotify_event: tstamp:35543577278 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1137385806144 data:0x00000000000003c9
kworker/3:0-2716 [003] .... 1107.494952: rtcpu_vinotify_error: tstamp:35544290235 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1137417265632 data:0x0000000000000001
kworker/3:0-2716 [003] .... 1107.494955: rtcpu_vinotify_error: tstamp:35544338437 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1137418805696 data:0x00000000000003c9
kworker/3:0-2716 [003] .... 1107.494957: rtcpu_vinotify_event: tstamp:35544590942 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1137417262336 data:0x0000000000000020
kworker/3:0-2716 [003] .... 1107.494957: rtcpu_vinotify_event: tstamp:35544591095 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1137417265632 data:0x0000000000000001
kworker/3:0-2716 [003] .... 1107.494958: rtcpu_vinotify_event: tstamp:35544591225 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1137418805024 data:0x0000000000000010
kworker/3:0-2716 [003] .... 1107.494958: rtcpu_vinotify_event: tstamp:35544591401 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1137418805696 data:0x00000000000003c9
kworker/3:0-2716 [003] .... 1107.494959: rtcpu_string: tstamp:35545321039 id:0x04010000 str:"ISR PHY 0 CIL_A 0xe000000
kworker/3:0-2716 [003] .... 1107.494970: rtcpu_nvcsi_intr: tstamp:35545320790 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
kworker/3:0-2716 [003] .... 1107.494971: rtcpu_string: tstamp:35545321429 id:0x04010000 str:"ISR PHY 0 CIL_B 0x6000000
kworker/3:0-2716 [003] .... 1107.494975: rtcpu_nvcsi_intr: tstamp:35545320790 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
kworker/3:0-2716 [003] .... 1107.494975: rtcpu_vinotify_error: tstamp:35545322363 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1137450265184 data:0x0000000000000001
kworker/3:0-2716 [003] .... 1107.494976: rtcpu_vinotify_error: tstamp:35545369672 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1137451805248 data:0x00000000000003c9
kworker/3:0-2716 [003] .... 1107.550801: rtcpu_vinotify_event: tstamp:35545605043 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1137450261856 data:0x0000000000000020
kworker/3:0-2716 [003] .... 1107.550803: rtcpu_vinotify_event: tstamp:35545605204 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1137450265184 data:0x0000000000000001
kworker/3:0-2716 [003] .... 1107.550804: rtcpu_vinotify_event: tstamp:35545605334 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1137451804576 data:0x0000000000000010
kworker/3:0-2716 [003] .... 1107.550804: rtcpu_vinotify_event: tstamp:35545605483 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1137451805248 data:0x00000000000003c9
kworker/3:0-2716 [003] .... 1107.550806: rtcpu_vinotify_error: tstamp:35546352679 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1137483264704 data:0x0000000000000001
kworker/3:0-2716 [003] .... 1107.550806: rtcpu_vinotify_event: tstamp:35546353120 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1137483261408 data:0x0000000000000020
kworker/3:0-2716 [003] .... 1107.550807: rtcpu_vinotify_error: tstamp:35546400907 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1137484804768 data:0x00000000000003c9
kworker/3:0-2716 [003] .... 1107.550808: rtcpu_vinotify_event: tstamp:35546686780 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1137483264704 data:0x0000000000000001
kworker/3:0-2716 [003] .... 1107.550809: rtcpu_vinotify_event: tstamp:35546686913 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1137484804096 data:0x0000000000000010
kworker/3:0-2716 [003] .... 1107.550809: rtcpu_vinotify_event: tstamp:35546687066 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1137484804768 data:0x00000000000003c9
kworker/3:0-2716 [003] .... 1107.606954: rtcpu_vinotify_error: tstamp:35547383942 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1137516264288 data:0x0000000000000001
kworker/3:0-2716 [003] .... 1107.606957: rtcpu_vinotify_error: tstamp:35547432140 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1137517804320 data:0x00000000000003c9
kworker/3:0-2716 [003] .... 1107.606958: rtcpu_vinotify_event: tstamp:35547700885 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1137516260928 data:0x0000000000000020
kworker/3:0-2716 [003] .... 1107.606959: rtcpu_vinotify_event: tstamp:35547701037 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1137516264288 data:0x0000000000000001
kworker/3:0-2716 [003] .... 1107.606960: rtcpu_vinotify_event: tstamp:35547701169 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1137517803648 data:0x0000000000000010
kworker/3:0-2716 [003] .... 1107.606960: rtcpu_vinotify_event: tstamp:35547701315 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1137517804320 data:0x00000000000003c9
kworker/3:0-2716 [003] .... 1107.606960: rtcpu_vinotify_error: tstamp:35548415179 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1137549263808 data:0x0000000000000001
kworker/3:0-2716 [003] .... 1107.606961: rtcpu_vinotify_error: tstamp:35548463376 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1137550803872 data:0x00000000000003c9
kworker/3:0-2716 [003] .... 1107.606961: rtcpu_vinotify_event: tstamp:35548714985 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1137549260512 data:0x0000000000000020
kworker/3:0-2716 [003] .... 1107.606962: rtcpu_vinotify_event: tstamp:35548715135 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1137549263808 data:0x0000000000000001
kworker/3:0-2716 [003] .... 1107.606963: rtcpu_vinotify_event: tstamp:35548715266 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1137550803168 data:0x0000000000000010
kworker/3:0-2716 [003] .... 1107.606963: rtcpu_vinotify_event: tstamp:35548715414 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1137550803872 data:0x00000000000003c9
kworker/3:0-2716 [003] .... 1107.662954: rtcpu_string: tstamp:35549445981 id:0x04010000 str:"ISR PHY 0 CIL_A 0xe000000
kworker/3:0-2716 [003] .... 1107.662968: rtcpu_nvcsi_intr: tstamp:35549445733 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
kworker/3:0-2716 [003] .... 1107.662969: rtcpu_string: tstamp:35549446367 id:0x04010000 str:"ISR PHY 0 CIL_B 0x6000000
kworker/3:0-2716 [003] .... 1107.662973: rtcpu_nvcsi_intr: tstamp:35549445733 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
kworker/3:0-2716 [003] .... 1107.662975: rtcpu_vinotify_error: tstamp:35549447302 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1137582263360 data:0x0000000000000001
kworker/3:0-2716 [003] .... 1107.662976: rtcpu_vinotify_error: tstamp:35549494614 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1137583803424 data:0x00000000000003c9
kworker/3:0-2716 [003] .... 1107.662977: rtcpu_vinotify_event: tstamp:35549729238 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1137582260032 data:0x0000000000000020
kworker/3:0-2716 [003] .... 1107.662977: rtcpu_vinotify_event: tstamp:35549729391 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1137582263360 data:0x0000000000000001
kworker/3:0-2716 [003] .... 1107.662978: rtcpu_vinotify_event: tstamp:35549729522 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1137583802720 data:0x0000000000000010
kworker/3:0-2716 [003] .... 1107.662979: rtcpu_vinotify_event: tstamp:35549729671 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1137583803424 data:0x00000000000003c9
kworker/3:0-2716 [003] .... 1107.662979: rtcpu_vinotify_error: tstamp:35550477622 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1137615262912 data:0x0000000000000001
kworker/3:0-2716 [003] .... 1107.662980: rtcpu_vinotify_event: tstamp:35550478068 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1137615259552 data:0x0000000000000020
kworker/3:0-2716 [003] .... 1107.662980: rtcpu_vinotify_error: tstamp:35550525847 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1137616802944 data:0x00000000000003c9
kworker/3:0-2716 [003] .... 1107.718951: rtcpu_vinotify_event: tstamp:35550810978 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1137615262912 data:0x0000000000000001
kworker/3:0-2716 [003] .... 1107.718954: rtcpu_vinotify_event: tstamp:35550811112 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1137616802272 data:0x0000000000000010
kworker/3:0-2716 [003] .... 1107.718954: rtcpu_vinotify_event: tstamp:35550811262 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1137616802944 data:0x00000000000003c9
kworker/3:0-2716 [003] .... 1107.718956: rtcpu_vinotify_error: tstamp:35551508911 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1137648262432 data:0x0000000000000001
kworker/3:0-2716 [003] .... 1107.718956: rtcpu_vinotify_error: tstamp:35551557084 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1137649802496 data:0x00000000000003c9
kworker/3:0-2716 [003] .... 1107.718956: rtcpu_vinotify_event: tstamp:35551825090 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1137648259136 data:0x0000000000000020
kworker/3:0-2716 [003] .... 1107.718957: rtcpu_vinotify_event: tstamp:35551825249 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1137648262432 data:0x0000000000000001
kworker/3:0-2716 [003] .... 1107.718957: rtcpu_vinotify_event: tstamp:35551825379 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1137649801792 data:0x0000000000000010
kworker/3:0-2716 [003] .... 1107.718958: rtcpu_vinotify_event: tstamp:35551825528 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1137649802496 data:0x00000000000003c9
kworker/3:0-2716 [003] .... 1107.774954: rtcpu_vinotify_error: tstamp:35552540147 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1137681261984 data:0x0000000000000001
kworker/3:0-2716 [003] .... 1107.774957: rtcpu_vinotify_error: tstamp:35552588316 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1137682802048 data:0x00000000000003c9
kworker/3:0-2716 [003] .... 1107.774959: rtcpu_vinotify_event: tstamp:35552839207 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1137681258656 data:0x0000000000000020
kworker/3:0-2716 [003] .... 1107.774960: rtcpu_vinotify_event: tstamp:35552839360 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1137681261984 data:0x0000000000000001
kworker/3:0-2716 [003] .... 1107.774960: rtcpu_vinotify_event: tstamp:35552839491 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1137682801344 data:0x0000000000000010
kworker/3:0-2716 [003] .... 1107.774961: rtcpu_vinotify_event: tstamp:35552839644 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1137682802048 data:0x00000000000003c9
kworker/3:0-2716 [003] .... 1107.774962: rtcpu_string: tstamp:35553570922 id:0x04010000 str:"ISR PHY 0 CIL_A 0xe000000
kworker/3:0-2716 [003] .... 1107.774973: rtcpu_nvcsi_intr: tstamp:35553570676 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
kworker/3:0-2716 [003] .... 1107.774974: rtcpu_string: tstamp:35553571310 id:0x04010000 str:"ISR PHY 0 CIL_B 0x6000000
kworker/3:0-2716 [003] .... 1107.774978: rtcpu_nvcsi_intr: tstamp:35553570676 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
kworker/3:0-2716 [003] .... 1107.774979: rtcpu_vinotify_error: tstamp:35553572237 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1137714261504 data:0x0000000000000001
kworker/3:0-2716 [003] .... 1107.774979: rtcpu_vinotify_error: tstamp:35553619553 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1137715801568 data:0x00000000000003c9
kworker/3:0-2716 [003] .... 1107.774980: rtcpu_vinotify_event: tstamp:35553853307 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1137714258176 data:0x0000000000000020
kworker/3:0-2716 [003] .... 1107.774981: rtcpu_vinotify_event: tstamp:35553853477 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1137714261504 data:0x0000000000000001
kworker/3:0-2716 [003] .... 1107.774982: rtcpu_vinotify_event: tstamp:35553853607 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1137715800896 data:0x0000000000000010
kworker/3:0-2716 [003] .... 1107.774982: rtcpu_vinotify_event: tstamp:35553853757 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1137715801568 data:0x00000000000003c9
kworker/3:0-2716 [003] .... 1107.830950: rtcpu_vinotify_error: tstamp:35554602587 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1137747261056 data:0x0000000000000001
kworker/3:0-2716 [003] .... 1107.830953: rtcpu_vinotify_event: tstamp:35554603028 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1137747257728 data:0x0000000000000020
kworker/3:0-2716 [003] .... 1107.830954: rtcpu_vinotify_error: tstamp:35554650814 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1137748801120 data:0x00000000000003c9
kworker/3:0-2716 [003] .... 1107.830954: rtcpu_vinotify_event: tstamp:35554935068 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1137747261056 data:0x0000000000000001
kworker/3:0-2716 [003] .... 1107.830954: rtcpu_vinotify_event: tstamp:35554935200 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1137748800416 data:0x0000000000000010
kworker/3:0-2716 [003] .... 1107.830955: rtcpu_vinotify_event: tstamp:35554935380 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1137748801120 data:0x00000000000003c9
kworker/3:0-2716 [003] .... 1107.830955: rtcpu_vinotify_error: tstamp:35555633880 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1137780260608 data:0x0000000000000001
kworker/3:0-2716 [003] .... 1107.830956: rtcpu_vinotify_error: tstamp:35555682049 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1137781800672 data:0x00000000000003c9
kworker/3:0-2716 [003] .... 1107.886952: rtcpu_vinotify_event: tstamp:35555949158 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1137780257280 data:0x0000000000000020
kworker/3:0-2716 [003] .... 1107.886955: rtcpu_vinotify_event: tstamp:35555949312 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1137780260608 data:0x0000000000000001
kworker/3:0-2716 [003] .... 1107.886956: rtcpu_vinotify_event: tstamp:35555949440 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1137781799968 data:0x0000000000000010
kworker/3:0-2716 [003] .... 1107.886956: rtcpu_vinotify_event: tstamp:35555949588 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1137781800672 data:0x00000000000003c9
kworker/3:0-2716 [003] .... 1107.886957: rtcpu_vinotify_error: tstamp:35556665116 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1137813260128 data:0x0000000000000001
kworker/3:0-2716 [003] .... 1107.886958: rtcpu_vinotify_error: tstamp:35556713286 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1137814800192 data:0x00000000000003c9
kworker/3:0-2716 [003] .... 1107.886958: rtcpu_vinotify_event: tstamp:35556963295 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1137813256800 data:0x0000000000000020
kworker/3:0-2716 [003] .... 1107.886959: rtcpu_vinotify_event: tstamp:35556963450 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1137813260128 data:0x0000000000000001
kworker/3:0-2716 [003] .... 1107.886959: rtcpu_vinotify_event: tstamp:35556963579 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1137814799520 data:0x0000000000000010
kworker/3:0-2716 [003] .... 1107.886960: rtcpu_vinotify_event: tstamp:35556963727 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1137814800192 data:0x00000000000003c9
kworker/3:0-2716 [003] .... 1107.942954: rtcpu_string: tstamp:35557695891 id:0x04010000 str:"ISR PHY 0 CIL_A 0xe000000
kworker/3:0-2716 [003] .... 1107.942968: rtcpu_nvcsi_intr: tstamp:35557695620 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
kworker/3:0-2716 [003] .... 1107.942968: rtcpu_string: tstamp:35557696280 id:0x04010000 str:"ISR PHY 0 CIL_B 0x6000000
kworker/3:0-2716 [003] .... 1107.942973: rtcpu_nvcsi_intr: tstamp:35557695620 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
kworker/3:0-2716 [003] .... 1107.942975: rtcpu_vinotify_error: tstamp:35557697240 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1137846259680 data:0x0000000000000001
kworker/3:0-2716 [003] .... 1107.942975: rtcpu_vinotify_error: tstamp:35557744522 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1137847799744 data:0x00000000000003c9
kworker/3:0-2716 [003] .... 1107.942977: rtcpu_vinotify_event: tstamp:35557977585 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1137846256352 data:0x0000000000000020
kworker/3:0-2716 [003] .... 1107.942977: rtcpu_vinotify_event: tstamp:35557977737 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1137846259680 data:0x0000000000000001
kworker/3:0-2716 [003] .... 1107.942978: rtcpu_vinotify_event: tstamp:35557977866 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1137847799040 data:0x0000000000000010
kworker/3:0-2716 [003] .... 1107.942979: rtcpu_vinotify_event: tstamp:35557978014 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1137847799744 data:0x00000000000003c9
kworker/3:0-2716 [003] .... 1107.942979: rtcpu_vinotify_error: tstamp:35558727530 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1137879259232 data:0x0000000000000001
kworker/3:0-2716 [003] .... 1107.942980: rtcpu_vinotify_event: tstamp:35558728005 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1137879255904 data:0x0000000000000020
kworker/3:0-2716 [003] .... 1107.942980: rtcpu_vinotify_error: tstamp:35558775755 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1137880799264 data:0x00000000000003c9
kworker/3:0-2716 [003] .... 1107.942981: rtcpu_vinotify_event: tstamp:35559059151 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1137879259232 data:0x0000000000000001
kworker/3:0-2716 [003] .... 1107.942982: rtcpu_vinotify_event: tstamp:35559059286 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1137880798592 data:0x0000000000000010
kworker/3:0-2716 [003] .... 1107.942982: rtcpu_vinotify_event: tstamp:35559059438 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1137880799264 data:0x00000000000003c9
kworker/3:0-2716 [003] .... 1107.998789: rtcpu_vinotify_error: tstamp:35559758821 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1137912258752 data:0x0000000000000001
kworker/3:0-2716 [003] .... 1107.998790: rtcpu_vinotify_error: tstamp:35559806992 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1137913798816 data:0x00000000000003c9
kworker/3:0-2716 [003] .... 1107.998791: rtcpu_vinotify_event: tstamp:35560073412 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1137912255456 data:0x0000000000000020
kworker/3:0-2716 [003] .... 1107.998792: rtcpu_vinotify_event: tstamp:35560073598 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1137912258752 data:0x0000000000000001
kworker/3:0-2716 [003] .... 1107.998792: rtcpu_vinotify_event: tstamp:35560073730 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1137913798144 data:0x0000000000000010
kworker/3:0-2716 [003] .... 1107.998794: rtcpu_vinotify_event: tstamp:35560073879 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1137913798816 data:0x00000000000003c9
kworker/3:0-2716 [003] .... 1107.998795: rtcpu_vinotify_error: tstamp:35560790060 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1137945258272 data:0x0000000000000001
kworker/3:0-2716 [003] .... 1107.998795: rtcpu_vinotify_error: tstamp:35560838225 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1137946798368 data:0x00000000000003c9
kworker/3:0-2716 [003] .... 1107.998796: rtcpu_vinotify_event: tstamp:35561087526 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1137945254976 data:0x0000000000000020
kworker/3:0-2716 [003] .... 1107.998797: rtcpu_vinotify_event: tstamp:35561087679 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1137945258272 data:0x0000000000000001
kworker/3:0-2716 [003] .... 1107.998797: rtcpu_vinotify_event: tstamp:35561087809 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1137946797664 data:0x0000000000000010
kworker/3:0-2716 [003] .... 1107.998798: rtcpu_vinotify_event: tstamp:35561087989 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1137946798368 data:0x00000000000003c9
kworker/3:0-2716 [003] .... 1108.054953: rtcpu_string: tstamp:35561820832 id:0x04010000 str:"ISR PHY 0 CIL_A 0xe000000
kworker/3:0-2716 [003] .... 1108.054965: rtcpu_nvcsi_intr: tstamp:35561820562 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
kworker/3:0-2716 [003] .... 1108.054966: rtcpu_string: tstamp:35561821222 id:0x04010000 str:"ISR PHY 0 CIL_B 0x6000000
kworker/3:0-2716 [003] .... 1108.054970: rtcpu_nvcsi_intr: tstamp:35561820562 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
kworker/3:0-2716 [003] .... 1108.054972: rtcpu_vinotify_error: tstamp:35561822152 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1137978257856 data:0x0000000000000001
kworker/3:0-2716 [003] .... 1108.054972: rtcpu_vinotify_error: tstamp:35561869466 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1137979797888 data:0x00000000000003c9
kworker/3:0-2716 [003] .... 1108.054973: rtcpu_vinotify_event: tstamp:35562101607 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1137978254496 data:0x0000000000000020
kworker/3:0-2716 [003] .... 1108.054974: rtcpu_vinotify_event: tstamp:35562101790 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1137978257856 data:0x0000000000000001
kworker/3:0-2716 [003] .... 1108.054974: rtcpu_vinotify_event: tstamp:35562101922 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1137979797216 data:0x0000000000000010
kworker/3:0-2716 [003] .... 1108.054975: rtcpu_vinotify_event: tstamp:35562102102 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1137979797888 data:0x00000000000003c9
kworker/3:0-2716 [003] .... 1108.054975: rtcpu_vinotify_error: tstamp:35562852469 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1138011257376 data:0x0000000000000001
kworker/3:0-2716 [003] .... 1108.054976: rtcpu_vinotify_event: tstamp:35562852909 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1138011254080 data:0x0000000000000020
kworker/3:0-2716 [003] .... 1108.054977: rtcpu_vinotify_error: tstamp:35562900698 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1138012797440 data:0x00000000000003c9
kworker/3:0-2716 [003] .... 1108.110950: rtcpu_vinotify_event: tstamp:35563183365 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1138011257376 data:0x0000000000000001
kworker/3:0-2716 [003] .... 1108.110952: rtcpu_vinotify_event: tstamp:35563183499 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1138012796736 data:0x0000000000000010
kworker/3:0-2716 [003] .... 1108.110953: rtcpu_vinotify_event: tstamp:35563183697 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1138012797440 data:0x00000000000003c9
kworker/3:0-2716 [003] .... 1108.110954: rtcpu_vinotify_error: tstamp:35563883763 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1138044256928 data:0x0000000000000001
kworker/3:0-2716 [003] .... 1108.110954: rtcpu_vinotify_error: tstamp:35563931935 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1138045796992 data:0x00000000000003c9
kworker/3:0-2716 [003] .... 1108.110955: rtcpu_vinotify_event: tstamp:35564197484 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1138044253600 data:0x0000000000000020
kworker/3:0-2716 [003] .... 1108.110955: rtcpu_vinotify_event: tstamp:35564197643 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1138044256928 data:0x0000000000000001
kworker/3:0-2716 [003] .... 1108.110956: rtcpu_vinotify_event: tstamp:35564197777 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1138045796320 data:0x0000000000000010
kworker/3:0-2716 [003] .... 1108.110956: rtcpu_vinotify_event: tstamp:35564197927 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1138045796992 data:0x00000000000003c9
kworker/3:0-2716 [003] .... 1108.166954: rtcpu_vinotify_error: tstamp:35564914998 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1138077256480 data:0x0000000000000001
kworker/3:0-2716 [003] .... 1108.166957: rtcpu_vinotify_error: tstamp:35564963171 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1138078796512 data:0x00000000000003c9
kworker/3:0-2716 [003] .... 1108.166959: rtcpu_vinotify_event: tstamp:35565211599 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1138077253152 data:0x0000000000000020
kworker/3:0-2716 [003] .... 1108.166959: rtcpu_vinotify_event: tstamp:35565211756 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1138077256480 data:0x0000000000000001
kworker/3:0-2716 [003] .... 1108.166960: rtcpu_vinotify_event: tstamp:35565211891 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1138078795840 data:0x0000000000000010
kworker/3:0-2716 [003] .... 1108.166960: rtcpu_vinotify_event: tstamp:35565212040 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1138078796512 data:0x00000000000003c9
kworker/3:0-2716 [003] .... 1108.166961: rtcpu_string: tstamp:35565945777 id:0x04010000 str:"ISR PHY 0 CIL_A 0xe000000
kworker/3:0-2716 [003] .... 1108.166972: rtcpu_nvcsi_intr: tstamp:35565945505 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
kworker/3:0-2716 [003] .... 1108.166972: rtcpu_string: tstamp:35565946171 id:0x04010000 str:"ISR PHY 0 CIL_B 0x6000000
kworker/3:0-2716 [003] .... 1108.166977: rtcpu_nvcsi_intr: tstamp:35565945505 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
kworker/3:0-2716 [003] .... 1108.166977: rtcpu_vinotify_error: tstamp:35565947144 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1138110256000 data:0x0000000000000001
kworker/3:0-2716 [003] .... 1108.166978: rtcpu_vinotify_error: tstamp:35565994407 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1138111796032 data:0x00000000000003c9
kworker/3:0-2716 [003] .... 1108.166979: rtcpu_vinotify_event: tstamp:35566225697 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1138110252672 data:0x0000000000000020
kworker/3:0-2716 [003] .... 1108.166979: rtcpu_vinotify_event: tstamp:35566225851 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1138110256000 data:0x0000000000000001
kworker/3:0-2716 [003] .... 1108.166980: rtcpu_vinotify_event: tstamp:35566225982 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1138111795360 data:0x0000000000000010
kworker/3:0-2716 [003] .... 1108.166981: rtcpu_vinotify_event: tstamp:35566226135 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1138111796032 data:0x00000000000003c9
kworker/3:0-2716 [003] .... 1108.222948: rtcpu_vinotify_error: tstamp:35566977415 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1138143255552 data:0x0000000000000001
kworker/3:0-2716 [003] .... 1108.222951: rtcpu_vinotify_event: tstamp:35566977886 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1138143252224 data:0x0000000000000020
kworker/3:0-2716 [003] .... 1108.222951: rtcpu_vinotify_error: tstamp:35567025641 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1138144795616 data:0x00000000000003c9
kworker/3:0-2716 [003] .... 1108.222952: rtcpu_vinotify_event: tstamp:35567307576 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1138143255552 data:0x0000000000000001
kworker/3:0-2716 [003] .... 1108.222952: rtcpu_vinotify_event: tstamp:35567307707 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1138144794912 data:0x0000000000000010
kworker/3:0-2716 [003] .... 1108.222953: rtcpu_vinotify_event: tstamp:35567307857 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1138144795616 data:0x00000000000003c9
kworker/3:0-2716 [003] .... 1108.222953: rtcpu_vinotify_error: tstamp:35568008679 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1138176255072 data:0x0000000000000001
kworker/3:0-2716 [003] .... 1108.222954: rtcpu_vinotify_error: tstamp:35568056878 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1138177795136 data:0x00000000000003c9
kworker/3:0-2716 [003] .... 1108.278954: rtcpu_vinotify_event: tstamp:35568321677 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1138176251776 data:0x0000000000000020
kworker/3:0-2716 [003] .... 1108.278957: rtcpu_vinotify_event: tstamp:35568321834 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1138176255072 data:0x0000000000000001
kworker/3:0-2716 [003] .... 1108.278958: rtcpu_vinotify_event: tstamp:35568321965 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1138177794464 data:0x0000000000000010
kworker/3:0-2716 [003] .... 1108.278958: rtcpu_vinotify_event: tstamp:35568322114 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1138177795136 data:0x00000000000003c9
kworker/3:0-2716 [003] .... 1108.278959: rtcpu_vinotify_error: tstamp:35569039916 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1138209254624 data:0x0000000000000001
kworker/3:0-2716 [003] .... 1108.278960: rtcpu_vinotify_error: tstamp:35569088084 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1138210794688 data:0x00000000000003c9
kworker/3:0-2716 [003] .... 1108.278960: rtcpu_vinotify_event: tstamp:35569335749 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1138209251296 data:0x0000000000000020
kworker/3:0-2716 [003] .... 1108.278961: rtcpu_vinotify_event: tstamp:35569335904 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1138209254624 data:0x0000000000000001
kworker/3:0-2716 [003] .... 1108.278961: rtcpu_vinotify_event: tstamp:35569336039 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1138210793984 data:0x0000000000000010
kworker/3:0-2716 [003] .... 1108.278962: rtcpu_vinotify_event: tstamp:35569336219 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1138210794688 data:0x00000000000003c9
v4l2-ctl-2776 [001] .... 1108.326619: tegra_channel_close: vi-output, max96724 2-0004
v4l2-ctl-2776 [001] .... 1108.327157: tegra_channel_set_stream: enable : 0x0
v4l2-ctl-2776 [001] .... 1108.327158: tegra_channel_set_stream: max96724 2-0004 : 0x0
v4l2-ctl-2776 [001] .... 1108.327168: tegra_channel_set_stream: 13e40000.host1x:nvcsi@15a00000- : 0x0
v4l2-ctl-2776 [001] .... 1108.327169: csi_s_stream: enable : 0x0
kworker/3:0-2716 [003] .... 1108.334811: rtcpu_string: tstamp:35570070720 id:0x04010000 str:"ISR PHY 0 CIL_A 0xe000000
kworker/3:0-2716 [003] .... 1108.338428: rtcpu_nvcsi_intr: tstamp:35570070448 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x0e000000
kworker/3:0-2716 [003] .... 1108.338429: rtcpu_string: tstamp:35570071114 id:0x04010000 str:"ISR PHY 0 CIL_B 0x6000000
kworker/3:0-2716 [003] .... 1108.338433: rtcpu_nvcsi_intr: tstamp:35570070448 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x06000000
kworker/3:0-2716 [003] .... 1108.338439: rtcpu_vinotify_error: tstamp:35570072051 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1138242254176 data:0x0000000000000001
kworker/3:0-2716 [003] .... 1108.338439: rtcpu_vinotify_error: tstamp:35570119352 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1138243794240 data:0x00000000000003c9
kworker/3:0-2716 [003] .... 1108.338443: rtcpu_vinotify_event: tstamp:35570349889 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1138242250848 data:0x0000000000000020
kworker/3:0-2716 [003] .... 1108.338444: rtcpu_vinotify_event: tstamp:35570350077 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1138242254176 data:0x0000000000000001
kworker/3:0-2716 [003] .... 1108.338444: rtcpu_vinotify_event: tstamp:35570350211 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1138243793536 data:0x0000000000000010
kworker/3:0-2716 [003] .... 1108.338445: rtcpu_vinotify_event: tstamp:35570350361 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1138243794240 data:0x00000000000003c9
kworker/3:0-2716 [003] .... 1108.338445: rtcpu_vinotify_error: tstamp:35571102359 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1138275253696 data:0x0000000000000001
kworker/3:0-2716 [003] .... 1108.338446: rtcpu_vinotify_event: tstamp:35571102800 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1138275250400 data:0x0000000000000020
kworker/3:0-2716 [003] .... 1108.338446: rtcpu_vinotify_error: tstamp:35571150584 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1138276793760 data:0x00000000000003c9
kworker/3:0-2716 [003] .... 1108.338446: rtcpu_vinotify_event: tstamp:35571431577 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:1138275253696 data:0x0000000000000001
kworker/3:0-2716 [003] .... 1108.338450: rtcpu_vinotify_event: tstamp:35571431708 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1138276793088 data:0x0000000000000010
kworker/3:0-2716 [003] .... 1108.338450: rtcpu_vinotify_event: tstamp:35571431857 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1138276793760 data:0x00000000000003c9
kworker/3:0-2716 [003] .... 1108.338451: rtcpu_string: tstamp:35571449637 id:0x04010000 str:"tegra_nvcsi_stream_close(vm0, stream=0, csi=0)
v4l2-ctl-2776 [001] .... 1108.340237: tegra_channel_set_power: max96724 2-0004 : 0x0
v4l2-ctl-2776 [001] .... 1108.340255: camera_common_s_power: status : 0x0
v4l2-ctl-2776 [001] .... 1108.340269: tegra_channel_set_power: 13e40000.host1x:nvcsi@15a00000- : 0x0
v4l2-ctl-2776 [001] .... 1108.340272: csi_s_power: enable : 0x0
kworker/3:0-2716 [003] .... 1108.390817: rtcpu_vinotify_event: tstamp:35572111349 cch:-1 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1138298743936 data:0x0000000000000020
