OV9281 streaming
I am currently working on OV9281 camera sensor and I am able to capture raw img from the sensor, however I am trying to stream camera on nvidia jetson xavier nx som using nvarguscamerasrc but seems like its not streaming. Could you please help me how come I able to stream this camera.
I am using kernel version 5.10 and also is there any camera_override.isp file for the same. If so, kindly share any link if someone has used.
Thanks…
What’s the error log?
I mean what’t the gstreamer log?
And what’s the daemon log.
journalctl -u nvargus-daemon -f
Add below parameter to /var/nvidia/nvcam/settings/camera_overrides.isp
Need change the file to 664 to apply the isp overrides
demosaic.v5.family.use=CCCC
defaults.yuvMatrix[0] = {0.3333, 0.3333, 0.3333, 0}
defaults.yuvMatrix[1] = {0, 0, 0, 0}
defaults.yuvMatrix[2] = {0, 0, 0, 0}
defaults.yuvMatrix[3] = {0, 0, 0, 1}
could you please share any source of camera_overrides.isp file on nvidia forums
Actually it’s text file only you can create it by yourself.
What’s the BSP version?
cat /etc/nv_tegra_release
R35 (release), REVISION: 6.1, GCID: 39721438, BOARD: t186ref, EABI: aarch64, DATE: Tue Mar 4 10:13:09 UTC 2025
Apply the solution form below to verify.
[camera stability][t234]
https://forums.developer.nvidia.com/t/306195/9
Please attached the picture to show the problem to understand the problem.
Can you tell what exactly the problem?
Sorry to tell. We don’t support monochrome sensor tuning.
mode_type = “grey”;
pixel_phase = “y”;
Is this mode format is supported for monochrome sensor ov9281 I am using or do I need to forcefully use bayer format rg10 ?
Argus only support Bayer format.
For grey format you can use v4l2 app like v4l2src …
