Overheating of 3080 Ti despite fan control settings
Hello everyone,
I’m looking for some help with an issue I’m having regarding overheating graphics cards (3080 Ti, Blower Design). I currently have three graphics cards installed in my system, and two of them are from the same manufacturers. Despite my efforts to adjust the fan control settings, the graphics cards continue to overheat.
The fan control has been changed over
DISPLAY=:0 XAUTHORITY=/run/user/125/gdm/Xauthority nvidia-settings -a '[gpu:0-2]/GPUFanControlState=1'
DISPLAY=:0 XAUTHORITY=/run/user/125/gdm/Xauthority nvidia-settings -a '[fan:0-4]/GPUTargetFanSpeed=100'
I’ve tried adjusting the fan control settings to increase the fan speed, but the settings seem to get lost every time I restart the system. I’m not sure what’s causing this issue, and I’m hoping someone can offer some advice on how to fix it. I also noticed the numbers are inconsistent …
I’ve also checked to make sure the airflow in my system is adequate. However, the cards still seem to run hot. The system runs on Ubuntu 22.04 LTS. Drivers are used by standard packaging.
If anyone has experienced a similar issue or has any suggestions on how to resolve it, I would greatly appreciate your help. Thank you in advance for your time and expertise!
Overheating before:
| NVIDIA-SMI 525.85.12    Driver Version: 525.85.12    CUDA Version: 12.0     |
| GPU  Name        Persistence-M| Bus-Id        Disp.A | Volatile Uncorr. ECC |
| Fan  Temp  Perf  Pwr:Usage/Cap|         Memory-Usage | GPU-Util  Compute M. |
|                               |                      |               MIG M. |
|   0  NVIDIA GeForce ...  Off  | 00000000:01:00.0 Off |                  N/A |
| 38%   30C    P2    344W / 350W|    3167MiB / 12288MiB |      100%   Default |
|                               |                      |                  N/A |
|   1  NVIDIA GeForce ...  Off  | 00000000:02:00.0 Off |                  N/A |
|43%   89C    P2    235W / 350W |    3342MiB / 12288MiB |      100%      Default |
|                               |                      |                  N/A |
|   2  NVIDIA GeForce ...  Off  | 00000000:03:00.0 Off |                  N/A |
|59%   75C    P2    247W / 250W |      3047MiB / 11264MiB |     100%      Default |
|                               |                      |                  N/A |
After changing the fan control:
|                               |                      |               MIG M. |
| 55%   30C    P8    37W / 350W |     38MiB / 12288MiB |      0%      Default |
|                               |                      |                  N/A |
|100%   32C    P8    42W / 350W |    214MiB / 12288MiB |      0%      Default |
|                               |                      |                  N/A |
|100%   30C    P8    10W / 250W |      6MiB / 11264MiB |      0%      Default |
|                               |                      |                  N/A |
Running them again
|                               |                      |               MIG M. |
| 30%   89C    P2    236W / 350W |     3167MiB / 12288MiB |     99%      Default |
|                               |                      |                  N/A |
|100%   80C    P2    327W / 350W |    3343MiB / 12288MiB |      100%      Default |
|                               |                      |                  N/A |
|130%   84C    P8    244W / 250W |      3047MiB / 11264MiB |      100%      Default |
|                               |                      |                  N/A |
