Hi people
I cannot control ASUS NVidia 3070 OC Fan Duty, not only that, there is no data about the fans
it was working months ago
I have coolbits at 12 :: sudo tail -f /var/log/syslog | grep “error” shows 0 errors
** right now I just have limited W at 100 using GWE compiled from gitlab since I’m not using the card I prefer to keep power draw low (that’s why is showing 23w/100w)
that’s my system info >>
ferran@pop-os:~$ nvidia-smi
Sat Oct 1 13:56:43 2022
| NVIDIA-SMI 515.65.01 Driver Version: 515.65.01 CUDA Version: 11.7 |
| | | MIG M. |
| 0 NVIDIA GeForce ... Off | 00000000:01:00.0 On | N/A |
| 0% 51C P5 23W / 100W | 296MiB / 8192MiB | 2% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 1661 G /usr/lib/xorg/Xorg 116MiB |
| 0 N/A N/A 1867 G /usr/bin/gnome-shell 57MiB |
| 0 N/A N/A 13246 G firefox 116MiB |
| 0 N/A N/A 13663 G gnome-control-center 3MiB |
ferran@pop-os:~$ neofetch
///////////// ferran@pop-os
///////*767//////////////// OS: Pop!_OS 22.04 LTS x86_64
//////7676767676*////////////// Kernel: 5.19.12-xanmod1
/////76767//7676767////////////// Uptime: 56 mins
/////767676///*76767/////////////// Packages: 2465 (dpkg), 63 (flatpak)
///////767676///76767.///7676*/////// Shell: bash 5.1.16
/////////767676//76767///767676//////// Resolution: 1920x1080, 1920x1080
//////////76767676767////76767///////// DE: GNOME 42.3.1
///////////76767676//////7676////////// WM: Mutter
////////////,7676,///////767/////////// WM Theme: WhiteSur-Dark-solid-blue
/////////////*7676///////76//////////// Theme: WhiteSur-Dark-solid-blue [GTK2/3]
///////////////7676//////////////////// Icons: Vimix-dark [GTK2/3]
///////////////7676///767//////////// Terminal: gnome-terminal
//////////////////////'//////////// CPU: 11th Gen Intel i7-11700 (16) @ 4.800GHz
//////.7676767676767676767,////// GPU: Intel RocketLake-S GT1 [UHD Graphics 750]
/////767676767676767676767///// GPU: NVIDIA GeForce RTX 3070
/////////////////////////// Memory: 2921MiB / 63130MiB
