Overlayroot jetpack5.1.2 jetson orin NX
is there a way how can protect the filesystem from the unproper shutdown i did itbefore on jetpack4.6 with overlayroot but it fails with the jetpack 5.1.2
is here any other way to protect the filesystem
Thanks for visiting the NVIDIA Developer forums! Your topic will be best served in the Jetson category.
I will move this post over for visibility.
Cheers,
Tom
Hi deepleap,
Are you using the devkit or custom board for Orin NX?
It seems you are asking about Overlayfs on Root File System. Could you simply update to JP6.2(r36.4.3) for this feature?
customer board
okay, that instruction should also work for your custom carrier board in JP6.2.
