I did the steps as wiki,final step is :
sudo ./flash.sh jetson-tk1 mmcblk0p1
terminal print is :
download command failed NvErrow 0x120002
command failure/warning: bootloader download failed (bad data)
Failed flashing ardbeg;
in this case ,someone said config the board id can figure out this problem,I exec this order:
sudo ./flash.sh -B 375 jetson-tk1 mmcblk0p1
terminal print is:
Existing flashapp(/home/ubuntu/Downloads/Linux_for_Tegra/bootloader/nvflash) reused.
*** Flashing target device started. ***
./nvflash --boardid pm375 --bct PM375_Hynix_2GB_H5TC4G63AFR_H5TC4G63CFR_RDA_924MHz.cfg --setbct --configfile flash.cfg --create --bl fastboot.bin --odmdata 0x6009C000 --go
Nvflash 4.13.0000 started
BR_CID: 0x340010017410c10620000000170181c0
rcm version 0X400001
System Information:
chip name: unknown
chip id: 0x40 major: 1 minor: 1
chip sku: 0x0
chip uid: 0x000000017410c10620000000170181c0
macrovision: disabled
hdcp: disabled
jtag: disabled
sbk burned: false
board id: 0
warranty fuse: 0
dk burned: false
boot device: emmc
operating mode: 3
device config strap: 0
device config fuse: 0
sdram config strap: 0
RCM communication completed
bct file required for this command NvError 0x0
Failed flashing ardbeg.
whether my board id is wrong?how can I solve this problem?
(Sorry my English is very pool)
