Package error when installing CUDA and NVIDIA drivers - Ubuntu 22.04
I am following the instructions to install the CUDA toolkit and the driver from here.
$ lsb_release -a
No LSB modules are available.
Distributor ID:	Ubuntu
Description:	Ubuntu 22.04.5 LTS
Release:	22.04
Codename:	jammy
$ lspci | grep -i nvidia
01:00.0 VGA compatible controller: NVIDIA Corporation GA106 [GeForce RTX 3060 Lite Hash Rate] (rev a1)
01:00.1 Audio device: NVIDIA Corporation Device 228e (rev a1)
$ nvidia-detector
nvidia-driver-575
But apt, apt-get, and aptitude all give errors like these when I try to install GPU or CUDA drivers, such as nvidia-open, nvidia-driver-575, or cuda-drivers.
dpkg: error processing package nvidia-dkms-575 (--configure):
 installed nvidia-dkms-575 package post-installation script subprocess returned error exit status 10
dpkg: dependency problems prevent configuration of nvidia-driver-575:
 nvidia-driver-575 depends on nvidia-dkms-575 (= 575.57.08-0ubuntu1); however:
  Package nvidia-dkms-575 is not configured yet.
dpkg: error processing package nvidia-driver-575 (--configure):
 dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of cuda-drivers-575:
 cuda-drivers-575 depends on nvidia-driver-575 (>= 575.57.08) | nvidia-driver-575-open (>= 575.57.08) | nvidia-driver-575-server (>= 575.57.08) | nvidia-driver-575-server-open (>= 575.57.08); however:
  Package nvidia-driver-575 is not configured yet.
  Package nvidia-driver-575-open is not installed.
  Package nvidia-driver-575-server is not installed.
  Package nvidia-driver-575-server-open is not installed.
dpkg: error processing package cuda-drivers-575 (--configure):
dpkg: dependency problems prevent configuration of cuda-drivers:
 cuda-drivers depends on cuda-drivers-575 (= 575.57.08-0ubuntu1); however:
  Package cuda-drivers-575 is not configured yet.
dpkg: error processing package cuda-drivers (--configure):
Processing triggers for initramfs-tools (0.140ubuntu13.5) ...
update-initramfs: Generating /boot/initrd.img-6.8.0-60-generic
Errors were encountered while processing:
 nvidia-dkms-575
 nvidia-driver-575
 cuda-drivers-575
 cuda-drivers
I have run these commands to try to fix the errors, but to no avail:
apt-get remove --purge nvidia-open
apt-get remove --purge nvidia-driver-*
apt-get remove --purge cuda*
dpkg --configure -a
apt install -f
apt autoremove
apt clean
Has anyone else seen this post yet? Maybe I put it in the wrong forum? I had expected a reply before now, but so far nothing.
I see this in the logs in /var/crash:
/var/crash/nvidia-dkms-575.0.crash
  cc: error: unrecognized command-line option ‘-ftrivial-auto-var-init=zero’
   CC [M]  /var/lib/dkms/nvidia/575.57.08/build/nvidia/nv-pci.o
 make[3]: *** [scripts/Makefile.build:243: /var/lib/dkms/nvidia/575.57.08/build/nvidia/nv-bpmp.o] Error 1
 make[3]: *** Waiting for unfinished jobs....
 make[3]: *** [scripts/Makefile.build:243: /var/lib/dkms/nvidia/575.57.08/build/nvidia/nv-platform.o] Error 1
 make[3]: *** [scripts/Makefile.build:243: /var/lib/dkms/nvidia/575.57.08/build/nvidia/nv-gpio.o] Error 1
 make[3]: *** [scripts/Makefile.build:243: /var/lib/dkms/nvidia/575.57.08/build/nvidia/nv-dsi-parse-panel-props.o] Error 1
 make[3]: *** [scripts/Makefile.build:243: /var/lib/dkms/nvidia/575.57.08/build/nvidia/nv-backlight.o] Error 1
 make[3]: *** [scripts/Makefile.build:243: /var/lib/dkms/nvidia/575.57.08/build/nvidia/nv-platform-pm.o] Error 1
 make[3]: *** [scripts/Makefile.build:243: /var/lib/dkms/nvidia/575.57.08/build/nvidia/nv-imp.o] Error 1
 make[3]: *** [scripts/Makefile.build:243: /var/lib/dkms/nvidia/575.57.08/build/nvidia/nv-ipc-soc.o] Error 1
 make[3]: *** [scripts/Makefile.build:243: /var/lib/dkms/nvidia/575.57.08/build/nvidia/nv-pci.o] Error 1
 make[3]: *** [scripts/Makefile.build:243: /var/lib/dkms/nvidia/575.57.08/build/nvidia/nv.o] Error 1
 make[2]: *** [/usr/src/linux-headers-6.8.0-60-generic/Makefile:1925: /var/lib/dkms/nvidia/575.57.08/build] Error 2
 make[1]: *** [Makefile:240: __sub-make] Error 2
 make[1]: Leaving directory '/usr/src/linux-headers-6.8.0-60-generic'
 make: *** [Makefile:140: modules] Error 2
 # exit code: 2
 # elapsed time: 00:00:19
DKMSKernelVersion: 6.8.0-60-generic
Date: Mon Jul 28 10:40:45 2025
DuplicateSignature: dkms:nvidia-dkms-575:575.57.08-0ubuntu1:cc: error: unrecognized command-line option ‘-ftrivial-auto-var-init=zero’
Package: nvidia-dkms-575 575.57.08-0ubuntu1
PackageVersion: 575.57.08-0ubuntu1
SourcePackage: nvidia-graphics-drivers-575
Title: nvidia-dkms-575 575.57.08-0ubuntu1: nvidia kernel module failed to build
I have tried other drivers, like 570, but that does not make any difference; I still never get the driver installed.
Few other ppl reported Ubuntu repos to be broken recently (for example here), but so far nobody bothered enough to call Scaronni (I’m on Debian and last time i attempted to help with Ubuntu problems, the complaining folks just ghosted me, so this time please do it yourself ;-] ).
@tandrew what compiler are you using and what version?
Your current compiler doesn’t recognize the flag trivial-auto-var-init=zero and fails to build the driver.
Please post gcc --version or clang --version
Thank you for mentioning clang. I had forgotten about it, and I just installed it a few minutes ago. After I rebooted, I still get similar dependency errors as I originally got.
Here are gcc and clang versions:
Also, the cuda-toolkit-12-9 package does install successfully, just not the drivers.
