"Pageflip timed out! This is a bug in the nvidia-drm kernel driver" on external display, internal display doing fine
What happened ?
I just dragged a window to my second monitor, release the mouse and reclicked to click on a link. The second monitor froze instantly, with the logs in journalctl asking me to report this with two logs (provided). My internal monitor was still working fine.
I didn’t managed to get the external monitor to unfreeze by switch to another user using Ctrl + Alt + F4 (i think F3 and higher works, but not F2 and F1). Now it works correctly, even though i will reboot just as a security precaution.
Logs:
journalctl.log (41.1 KB)
dmesg :
[   90.248098] Lockdown: systemd-logind: hibernation is restricted; see man kernel_lockdown.7
[   90.248232] Lockdown: systemd-logind: hibernation is restricted; see man kernel_lockdown.7
[   90.248242] Lockdown: systemd-logind: hibernation is restricted; see man kernel_lockdown.7
[   90.466380] Lockdown: systemd-logind: hibernation is restricted; see man kernel_lockdown.7
[   90.478939] Lockdown: systemd-logind: hibernation is restricted; see man kernel_lockdown.7
[   90.479087] Lockdown: systemd-logind: hibernation is restricted; see man kernel_lockdown.7
[   90.479232] Lockdown: systemd-logind: hibernation is restricted; see man kernel_lockdown.7
[   90.479242] Lockdown: systemd-logind: hibernation is restricted; see man kernel_lockdown.7
[  188.950142] NVRM: nvAssertFailedNoLog: Assertion failed: CliGetEventInfo(rpc_params->hClient, rpc_params->hEvent, &pEvent) @ kernel_gsp.c:466
[  188.950149] NVRM: _kgspProcessRpcEvent: Failed to process received event 0x1003 (POST_EVENT) from GPU0: status=0x57
Computer information :
Operating System: Fedora Linux 42
KDE Plasma Version: 6.3.4
KDE Frameworks Version: 6.13.0
Qt Version: 6.8.2
Kernel Version: 6.14.2-300.fc42.x86_64 (64-bit)
Graphics Platform: Wayland
Processors: 12 × Intel® Core™ i7-10750H CPU @ 2.60GHz
Memory: 31.2 GiB of RAM
Graphics Processor: NVIDIA GeForce RTX 2080 Super with Max-Q Design/PCIe/SSE2
Manufacturer: Acer
Product Name: Predator PT515-52
System Version: V1.10
You forgot to mention the driver version you are using. This should be fixed in the latest beta driver 575.51.02.
I have been having blank display issues since the 5/19/2025 latest driver. I experienced this problem in Windows 11 after installing new driver from NVIDIA app. I thought I had really messed up somehow so I began a fresh windows 11 install and during windows update the display failed again. I had removed the device driver from device manager. That didn’t work. I think started a fresh Fedora 42 KDE install (no VM). It is causing the error you describe in my journalctrl. I am rolling back driver to march.
