Hi there,
I am running pbrun
with an A100 on a supernode, and I am getting the following error. How do we solve this case?
# pbrun germline \
--ref /workspace/datasets/ref/Homo_sapiens_assembly38.fasta \
--in-fq \
/workspace/datasets/germline/sample_1.fq.gz \
/workspace/datasets/germline/sample_2.fq.gz \
--knownSites /workspace/datasets/ref/Homo_sapiens_assembly38.known_indels.vcf.gz \
--out-bam output/output.bam \
--out-variants output/output.vcf \
--out-recal-file output/report.txt
Please visit https://docs.nvidia.com/clara/#parabricks for detailed documentation
[Parabricks Options Mesg]: Automatically generating ID prefix
[Parabricks Options Mesg]: Read group created for /workspace/datasets/germline/sample_1.fq.gz and
[Parabricks Options Mesg]: @RG\tID:HK3TJBCX2.1\tLB:lib1\tPL:bar\tSM:sample\tPU:HK3TJBCX2.1
[Parabricks Options Mesg]: Checking argument compatibility
[PB Info 2022-May-04 16:38:19] Logger not initialized!
[PB Info 2022-May-04 16:38:19] ------------------------------------------------------------------------------
[PB Info 2022-May-04 16:38:19] || Parabricks accelerated Genomics Pipeline ||
[PB Info 2022-May-04 16:38:19] || Version 3.7.0-1 ||
[PB Info 2022-May-04 16:38:19] || GPU-BWA mem, Sorting Phase-I ||
[PB Info 2022-May-04 16:38:19] || Contact: Parabricks-Support@nvidia.com ||
[PB Info 2022-May-04 16:38:20] Logger already initialized, continuing with current settings.
[M::bwa_idx_load_from_disk] read 0 ALT contigs
[PB Info 2022-May-04 16:38:25] GPU-BWA mem
[PB Info 2022-May-04 16:38:25] ProgressMeter Reads Base Pairs Aligned
[PB Warning 2022-May-04 16:38:28][ParaBricks/src/check_error.cu:41] cudaSafeCall() failed at ParaBricks/src/mem_chain_kernel.cu/136: invalid device symbol
[PB Error 2022-May-04 16:38:28][ParaBricks/src/check_error.cu:44] No GPUs active, shutting down due to previous error., exiting.
For technical support visit https://docs.nvidia.com/clara/parabricks/3.7.0/index.html#how-to-get-help
Exiting...
Could not run fq2bam as part of germline pipeline
Exiting pbrun ...
The error is:
OS
base on the docker image nvidia/cuda:11.2.0-cudnn8-devel-ubuntu18.04
Hardware
- GPU: A100 x1
- CPU: 24 vCPU
- CPU RAM: 100 GiB
GPU info
# nvidia-smi
Wed May 4 16:38:39 2022
| NVIDIA-SMI 470.103.01 Driver Version: 470.103.01 CUDA Version: 11.4 |
| | | MIG M. |
| 0 NVIDIA A100-PCI... Off | 00000000:82:00.0 Off | 0 |
| N/A 36C P0 38W / 250W | 0MiB / 40536MiB | 0% Default |
| | | Disabled |
| Processes: |
| ID ID Usage |
| No running processes found |
# nvidia-smi -L
GPU 0: NVIDIA A100-PCIE-40GB (UUID: GPU-e72a7afe-ae40-ff53-9e07-e9e2674d37e7)
- MIG: disabled
Software
# pbrun version
pbrun: 3.7.0-1
