Hi there,
I have some problems for Parabricks Version 4.0.1-1. Is any one can help? Thank you very much.
Here is full log message
Please visit NVIDIA Clara - NVIDIA Docs for detailed documentation
[Parabricks Options Mesg]: Automatically generating ID prefix
[Parabricks Options Mesg]: Read group created for /input_data/DBS_LO_1_R1_001.fastq.gz and
/input_data/DBS_LO_1_R2_001.fastq.gz
[Parabricks Options Mesg]: @RG\tID:HTHKLDSX7.1\tLB:lib1\tPL:bar\tSM:DBS\tPU:HTHKLDSX7.1
[Parabricks Options Mesg]: Checking argument compatibility
[PB Info 2024-Sep-30 03:17:30] ------------------------------------------------------------------------------
[PB Info 2024-Sep-30 03:17:30] || Parabricks accelerated Genomics Pipeline ||
[PB Info 2024-Sep-30 03:17:30] || Version 4.0.1-1 ||
[PB Info 2024-Sep-30 03:17:30] || GPU-BWA mem, Sorting Phase-I ||
[M::bwa_idx_load_from_disk] read 0 ALT contigs
[PB Info 2024-Sep-30 03:17:36] GPU-BWA mem
[PB Info 2024-Sep-30 03:17:36] ProgressMeter Reads Base Pairs Aligned
[PB Warning 2024-Sep-30 03:17:37][ParaBricks/src/check_error.cu:41] cudaSafeCall() failed at ParaBricks/src/memoryManager.cu/18: invalid argument
[PB Error 2024-Sep-30 03:17:37][ParaBricks/src/check_error.cu:44] No GPUs active, shutting down due to previous error., exiting.
For technical support visit Help - NVIDIA Docs
Exiting…
Could not run fq2bam as part of germline pipeline
Exiting pbrun …
[bgzip] No such file or directory: /raid/parabricks/u7815186/output//DBS.vcf
[Parabricks Options Error]: Input file /output_data/DBS.bam not found. Exiting…
[Parabricks Options Error]: Run with -h to see help
Here is the nvidia-smi
Mon Sep 30 11:52:09 2024
| NVIDIA-SMI 560.35.03 Driver Version: 560.35.03 CUDA Version: 12.6 |
| GPU Name Persistence-M | Bus-Id Disp.A | Volatile Uncorr. ECC |
| | | MIG M. |
| 0 Tesla V100-SXM2-16GB On | 00000000:06:00.0 Off | 0 |
| N/A 38C P0 73W / 300W | 13038MiB / 16384MiB | 38% Default |
| | | N/A |
| 1 Tesla V100-SXM2-16GB On | 00000000:07:00.0 Off | 0 |
| N/A 41C P0 71W / 300W | 13038MiB / 16384MiB | 14% Default |
| | | N/A |
| 2 Tesla V100-SXM2-16GB On | 00000000:0A:00.0 Off | 0 |
| N/A 39C P0 71W / 300W | 13040MiB / 16384MiB | 30% Default |
| | | N/A |
| 3 Tesla V100-SXM2-16GB On | 00000000:0B:00.0 Off | 0 |
| N/A 36C P0 74W / 300W | 13038MiB / 16384MiB | 39% Default |
| | | N/A |
| 4 Tesla V100-SXM2-16GB On | 00000000:85:00.0 Off | 0 |
| N/A 31C P0 42W / 300W | 1MiB / 16384MiB | 0% Default |
| | | N/A |
| 5 Tesla V100-SXM2-16GB On | 00000000:86:00.0 Off | 0 |
| N/A 33C P0 41W / 300W | 1MiB / 16384MiB | 0% Default |
| | | N/A |
| 6 Tesla V100-SXM2-16GB On | 00000000:89:00.0 Off | 0 |
| | | N/A |
| 7 Tesla V100-SXM2-16GB On | 00000000:8A:00.0 Off | 0 |
| N/A 31C P0 41W / 300W | 1MiB / 16384MiB | 0% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 3685742 C …local/parabricks/binaries//bin/htvc 13026MiB |
| 1 N/A N/A 3685742 C …local/parabricks/binaries//bin/htvc 13026MiB |
| 2 N/A N/A 3685742 C …local/parabricks/binaries//bin/htvc 13026MiB |
| 3 N/A N/A 3685742 C …local/parabricks/binaries//bin/htvc 13026MiB |
I can run BWA and GATK separate. But it don’t work together in pipeline.
