Welcome to the Google Deep Learning VM
Version: common-cu121.m118
Resources:
* Google Deep Learning Platform StackOverflow: https://stackoverflow.com/questions/tagged/google-dl-platform
* Google Cloud Documentation: https://cloud.google.com/deep-learning-vm
* Google Group: https://groups.google.com/forum/#!forum/google-dl-platform
To reinstall Nvidia driver (if needed) run:
sudo /opt/deeplearning/install-driver.sh
Linux instance-20240326-211639 5.10.0-28-cloud-amd64 #1 SMP Debian 5.10.209-2 (2024-01-31) x86_64
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Wed Mar 27 00:08:08 2024 from 35.235.243.82
(base) frederick@instance-20240326-211639:~$ docker run --rm --gpus all --volume `pwd`:`pwd` --workdir `pwd`/parabricks_sample nvcr.io/nvidia/clara/clara-parabricks:4.3.0-1 pbrun germline --ref Ref/Homo_sapiens_assembly38.fasta --in-fq Data/sample_1.fq.gz Data/sample_2.fq.gz --knownSites Ref/Homo_sapiens_assembly38.known_indels.vcf.gz.tbi --out-bam output.bam --out-variants germline.vcf --out-recal-file recal.txt --low-memory
Please visit https://docs.nvidia.com/clara/#parabricks for detailed documentation
[Parabricks Options Mesg]: Automatically generating ID prefix
[Parabricks Options Mesg]: Read group created for /home/frederick/parabricks_sample/Data/sample_1.fq.gz and
/home/frederick/parabricks_sample/Data/sample_2.fq.gz
[Parabricks Options Mesg]: @RG\tID:HK3TJBCX2.1\tLB:lib1\tPL:bar\tSM:sample\tPU:HK3TJBCX2.1
[Parabricks Options Mesg]: Checking argument compatibility
[PB Info 2024-Mar-27 00:25:02] ------------------------------------------------------------------------------
[PB Info 2024-Mar-27 00:25:02] || Parabricks accelerated Genomics Pipeline ||
[PB Info 2024-Mar-27 00:25:02] || Version 4.3.0-1 ||
[PB Info 2024-Mar-27 00:25:02] || GPU-BWA mem, Sorting Phase-I ||
[M::bwa_idx_load_from_disk] read 0 ALT contigs
[PB Info 2024-Mar-27 00:25:23] GPU-BWA mem
[PB Info 2024-Mar-27 00:25:23] ProgressMeter Reads Base Pairs Aligned
[PB Info 2024-Mar-27 00:25:47] 5043564 580000000
[PB Info 2024-Mar-27 00:26:09] 10087128 1160000000
[PB Info 2024-Mar-27 00:26:30] 15130692 1740000000
[PB Info 2024-Mar-27 00:26:51] 20174256 2320000000
[PB Info 2024-Mar-27 00:27:13] 25217820 2900000000
[PB Info 2024-Mar-27 00:27:34] 30261384 3480000000
[PB Info 2024-Mar-27 00:27:55] 35304948 4060000000
[PB Info 2024-Mar-27 00:28:16] 40348512 4640000000
[PB Info 2024-Mar-27 00:28:38] 45392076 5220000000
[PB Info 2024-Mar-27 00:28:59] 50435640 5800000000
[PB Info 2024-Mar-27 00:29:15]
GPU-BWA Mem time: 232.053483 seconds
[PB Info 2024-Mar-27 00:29:15] GPU-BWA Mem is finished.
[main] CMD: /usr/local/parabricks/binaries/bin/bwa mem -Z ./pbOpts.txt -l -F 0 /home/frederick/parabricks_sample/Ref/Homo_sapiens_assembly38.fasta /home/frederick/parabricks_sample/Data/sample_1.fq.gz /home/frederick/parabricks_sample/Data/sample_2.fq.gz @RG\tID:HK3TJBCX2.1\tLB:lib1\tPL:bar\tSM:sample\tPU:HK3TJBCX2.1
[main] Real time: 252.865 sec; CPU: 4256.537 sec
[PB Info 2024-Mar-27 00:29:15] ------------------------------------------------------------------------------
[PB Info 2024-Mar-27 00:29:15] || Program: GPU-BWA mem, Sorting Phase-I ||
[PB Info 2024-Mar-27 00:29:15] || Version: 4.3.0-1 ||
[PB Info 2024-Mar-27 00:29:15] || Start Time: Wed Mar 27 00:25:02 2024 ||
[PB Info 2024-Mar-27 00:29:15] || End Time: Wed Mar 27 00:29:15 2024 ||
[PB Info 2024-Mar-27 00:29:15] || Total Time: 4 minutes 13 seconds ||
[PB Info 2024-Mar-27 00:29:15] || Parabricks accelerated Genomics Pipeline ||
[PB Info 2024-Mar-27 00:29:15] || Version 4.3.0-1 ||
[PB Info 2024-Mar-27 00:29:15] || Sorting Phase-II ||
[PB Info 2024-Mar-27 00:29:15] progressMeter - Percentage
[PB Info 2024-Mar-27 00:29:15] 0.0
[PB Info 2024-Mar-27 00:29:20] 81.5
[PB Info 2024-Mar-27 00:29:25] Sorting and Marking: 10.002 seconds
[PB Info 2024-Mar-27 00:29:25] ------------------------------------------------------------------------------
[PB Info 2024-Mar-27 00:29:25] || Program: Sorting Phase-II ||
[PB Info 2024-Mar-27 00:29:25] || Version: 4.3.0-1 ||
[PB Info 2024-Mar-27 00:29:25] || Start Time: Wed Mar 27 00:29:15 2024 ||
[PB Info 2024-Mar-27 00:29:25] || End Time: Wed Mar 27 00:29:25 2024 ||
[PB Info 2024-Mar-27 00:29:25] || Total Time: 10 seconds ||
[PB Info 2024-Mar-27 00:29:25] || Parabricks accelerated Genomics Pipeline ||
[PB Info 2024-Mar-27 00:29:25] || Version 4.3.0-1 ||
[PB Info 2024-Mar-27 00:29:25] || Marking Duplicates, BQSR ||
[PB Info 2024-Mar-27 00:29:25] BQSR using CUDA device(s): { 0 }
[PB Info 2024-Mar-27 00:29:26] Using PBBinBamFile for BAM writing
[PB Info 2024-Mar-27 00:29:26] progressMeter - Percentage
[PB Info 2024-Mar-27 00:29:36] 0.0
[PB Info 2024-Mar-27 00:29:46] 0.0
[PB Info 2024-Mar-27 00:29:56] 0.0
[PB Error 2024-Mar-27 00:29:58][src/PBVcfFile.cpp:336] Expecting a .vcf or .vcf.gz as file extension, exiting.
[PB Error 2024-Mar-27 00:29:58][src/main.cu:617] Logic error: Popped null BinData from delete queue., exiting.
[PB Error 2024-Mar-27 00:29:58][src/main.cu:593] Logic error: Popped null BinData off write queue., exiting.
For technical support visit https://docs.nvidia.com/clara/index.html#parabricks
Exiting...
Could not run fq2bam as part of germline pipeline
Exiting pbrun ...
It runs just fine up until it says it is ’ Expecting a .vcf or .vcf.gz as file extension, exiting.’
