i am getting this error while running clara parabricks deepvariant from singularity container,
gpu specs → Tesla V100-PCIE-32GB
run command → singularity run --nv clara-parabricks_4.0.0-1.sif pbrun deepvariant --ref /genome.fa --in-bam fq2bam_output.bam --out-variants output/deepvariant_output.vcf
[PB Error 2022-Oct-11 17:24:15][src/fileHandleCommon.cpp:732] Loop count 4294967277 was too big., expected count < LOOPSIZE, exiting.
[PB Error 2022-Oct-11 17:24:15][./inc/common.h:108] NvInfer ERROR: ../rtSafe/cuda/cudaConvolutionRunner.cpp (483) - Cudnn Error in executeConv: 8 (CUDNN_STATUS_EXECUTION_FAILED), exiting.
/usr/local/parabricks/binaries//bin/deepvariant hg38/genome.fa /path/fq2bam_output.bam 1 -o /storage/scratch2/clara_parabricks/output/deepvariant_output.vcf --model /usr/local/parabricks/binaries//model/70/shortread/deepvariant.eng -n 4 --channel_insert_size --pileup_image_width 221 --max_reads_per_partition 1500 --partition_size 1000 --vsc_min_count_snps 2 --vsc_min_count_indels 2 --vsc_min_fraction_snps 0.12 --min_mapping_quality 5 --min_base_quality 10 --alt_aligned_pileup none --variant_caller VERY_SENSITIVE_CALLER
Please visit https://docs.nvidia.com/clara/#parabricks for detailed documentation
also, i am getting a similar error for haplotypecaller as well,
[PB Info 2022-Oct-11 18:15:58] chr5:177456001 1.5 3777815 2518543
[PB Error 2022-Oct-11 18:15:58][src/fileHandleCommon.cpp:732] Loop count 4294967277 was too big., expected count < LOOPSIZE, exiting.
/usr/local/parabricks/binaries//bin/htvc hg38/genome.fa /path/fq2bam_output.bam 1 -o output/haplotype_caller_output.vcf -nt 5
Hello @devendra.kumar,
Thank you for submitting your question. Do you happen to have the full log file so I can look through it more closely?
Log file
Detected 1 CUDA Capable device(s), considering 1 device(s)
CUDA Driver Version / Runtime Version 11.6 / 11.2
Using model for CUDA Capability Major/Minor version number: 70
[PB Info 2022-Oct-13 14:27:46] ------------------------------------------------------------------------------
[PB Info 2022-Oct-13 14:27:46] || Parabricks accelerated Genomics Pipeline ||
[PB Info 2022-Oct-13 14:27:46] || Version 4.0.0-1 ||
[PB Info 2022-Oct-13 14:27:46] || deepvariant ||
[PB Info 2022-Oct-13 14:27:47] Starting DeepVariant
[PB Info 2022-Oct-13 14:27:47] Running with 1 gpu, each with 4 workers
[PB Info 2022-Oct-13 14:28:01] ProgressMeter - Current-Locus Elapsed-Minutes
[PB Info 2022-Oct-13 14:28:07] ProgressMeter - chr1:10000 0.1
[PB Info 2022-Oct-13 14:28:13] ProgressMeter - chr1:10000 0.2
[PB Info 2022-Oct-13 14:28:19] ProgressMeter - chr1:1964000 0.3
[PB Info 2022-Oct-13 14:28:25] ProgressMeter - chr1:6128000 0.4
[PB Info 2022-Oct-13 14:28:31] ProgressMeter - chr1:9709000 0.5
[PB Info 2022-Oct-13 14:28:37] ProgressMeter - chr1:14272000 0.6
[PB Info 2022-Oct-13 14:28:43] ProgressMeter - chr1:17501000 0.7
[PB Info 2022-Oct-13 14:28:49] ProgressMeter - chr1:24035000 0.8
[PB Info 2022-Oct-13 14:28:55] ProgressMeter - chr1:28066000 0.9
[PB Info 2022-Oct-13 14:29:01] ProgressMeter - chr1:37376000 1.0
[PB Info 2022-Oct-13 14:29:07] ProgressMeter - chr1:42204000 1.1
[PB Info 2022-Oct-13 14:29:13] ProgressMeter - chr1:47455000 1.2
[PB Info 2022-Oct-13 14:29:19] ProgressMeter - chr1:53859000 1.3
[PB Info 2022-Oct-13 14:29:25] ProgressMeter - chr1:73098000 1.4
[PB Info 2022-Oct-13 14:29:31] ProgressMeter - chr1:88212000 1.5
[PB Info 2022-Oct-13 14:29:37] ProgressMeter - chr1:106792000 1.6
[PB Info 2022-Oct-13 14:29:43] ProgressMeter - chr1:111282000 1.7
[PB Info 2022-Oct-13 14:29:49] ProgressMeter - chr1:115945000 1.8
[PB Info 2022-Oct-13 14:29:55] ProgressMeter - chr1:124464000 1.9
[PB Info 2022-Oct-13 14:30:01] ProgressMeter - chr1:150878000 2.0
[PB Info 2022-Oct-13 14:30:07] ProgressMeter - chr1:159168000 2.1
[PB Info 2022-Oct-13 14:30:13] ProgressMeter - chr1:170353000 2.2
[PB Info 2022-Oct-13 14:30:19] ProgressMeter - chr1:178455000 2.3
[PB Info 2022-Oct-13 14:30:25] ProgressMeter - chr1:193764000 2.4
[PB Info 2022-Oct-13 14:30:31] ProgressMeter - chr1:204470000 2.5
[PB Info 2022-Oct-13 14:30:37] ProgressMeter - chr1:214341000 2.6
[PB Info 2022-Oct-13 14:30:43] ProgressMeter - chr1:225764000 2.7
[PB Info 2022-Oct-13 14:30:49] ProgressMeter - chr1:239090000 2.8
[PB Info 2022-Oct-13 14:30:55] ProgressMeter - chr2:2007000 2.9
[PB Info 2022-Oct-13 14:31:01] ProgressMeter - chr2:16960000 3.0
[PB Info 2022-Oct-13 14:31:07] ProgressMeter - chr2:30157000 3.1
[PB Info 2022-Oct-13 14:31:13] ProgressMeter - chr2:45822000 3.2
[PB Info 2022-Oct-13 14:31:19] ProgressMeter - chr2:63061000 3.3
[PB Info 2022-Oct-13 14:31:25] ProgressMeter - chr2:74015000 3.4
[PB Info 2022-Oct-13 14:31:31] ProgressMeter - chr2:85903000 3.5
[PB Info 2022-Oct-13 14:31:37] ProgressMeter - chr2:105362000 3.6
[PB Info 2022-Oct-13 14:31:43] ProgressMeter - chr2:119161000 3.7
[PB Info 2022-Oct-13 14:31:49] ProgressMeter - chr2:135490000 3.8
[PB Info 2022-Oct-13 14:31:55] ProgressMeter - chr2:152341000 3.9
[PB Info 2022-Oct-13 14:32:01] ProgressMeter - chr2:166457000 4.0
[PB Info 2022-Oct-13 14:32:07] ProgressMeter - chr2:181684000 4.1
[PB Info 2022-Oct-13 14:32:13] ProgressMeter - chr2:197832000 4.2
[PB Info 2022-Oct-13 14:32:19] ProgressMeter - chr2:204659000 4.3
[PB Info 2022-Oct-13 14:32:25] ProgressMeter - chr2:218758000 4.4
[PB Info 2022-Oct-13 14:32:31] ProgressMeter - chr2:230872000 4.5
[PB Info 2022-Oct-13 14:32:37] ProgressMeter - chr2:240147000 4.6
[PB Info 2022-Oct-13 14:32:43] ProgressMeter - chr3:14540000 4.7
[PB Info 2022-Oct-13 14:32:49] ProgressMeter - chr3:25630000 4.8
[PB Info 2022-Oct-13 14:32:55] ProgressMeter - chr3:33771000 4.9
[PB Info 2022-Oct-13 14:33:01] ProgressMeter - chr3:41799000 5.0
[PB Info 2022-Oct-13 14:33:07] ProgressMeter - chr3:50431000 5.1
[PB Info 2022-Oct-13 14:33:13] ProgressMeter - chr3:72313000 5.2
[PB Info 2022-Oct-13 14:33:19] ProgressMeter - chr3:96486000 5.3
[PB Info 2022-Oct-13 14:33:25] ProgressMeter - chr3:106592000 5.4
[PB Info 2022-Oct-13 14:33:31] ProgressMeter - chr3:122910000 5.5
[PB Info 2022-Oct-13 14:33:37] ProgressMeter - chr3:133887000 5.6
[PB Error 2022-Oct-13 14:33:42][src/fileHandleCommon.cpp:732] Loop count 4294967277 was too big., expected count < LOOPSIZE, exiting.
[PB Error 2022-Oct-13 14:33:42][./inc/common.h:108] NvInfer ERROR: ../rtSafe/cuda/cudaConvolutionRunner.cpp (483) - Cudnn Error in executeConv: 8 (CUDNN_STATUS_EXECUTION_FAILED), exiting.
/usr/local/parabricks/binaries//bin/deepvariant hg38/genome.fa /path/fq2bam_output.bam 1 -o output/deepvariant_output.vcf --model /usr/local/parabricks/binaries//model/70/shortread/deepvariant.eng -n 4 --channel_insert_size --pileup_image_width 221 --max_reads_per_partition 1500 --partition_size 1000 --vsc_min_count_snps 2 --vsc_min_count_indels 2 --vsc_min_fraction_snps 0.12 --min_mapping_quality 5 --min_base_quality 10 --alt_aligned_pileup none --variant_caller VERY_SENSITIVE_CALLER --logfile /path/pb_deepvariant_log.txt --append
Thank you @devendra.kumar,
Are you able to try this run on 2 GPUs, so I can rule out some issues?
@gburnett …
We have only one GPU at our facility !
Attached GPUs : 1
GPU 00000000:01:00.0
Product Name : Tesla V100-PCIE-32GB
Product Brand : Tesla
Product Architecture : Volta
Though fq2bam runs smoothly !
What is the status of this bug ? @gburnett
Hey Devendra,
It look like your bam file could be corrupted. Can you run samtools quickcheck to verify?
