Failed to run pbrun deepvariant
Hi, there
When I tried to run pbrun deepvariant with the official sample dataset, I got the following error.
$ pbrun deepvariant --ref parabricks_sample/Ref/Homo_sapiens_assembly38.fasta \
>   --in-bam output.bam \
>   --out-variants output.vcf \
>   --x3
Please visit https://docs.nvidia.com/clara/#parabricks for detailed documentation
docker run --gpus all -u=1000:1000 --rm -w=/uploads/workspace --net=host -v /opt/parabricks:/INSTALL/ -v /uploads/workspace/DUUWMSRM:/uploads/workspace/DUUWMSRM -v /uploads/workspace:/uploads/workspace -v /uploads/workspace/parabricks_sample/Ref:/uploads/workspace/parabricks_sample/Ref parabricks/release:v3.5.0 deepvariant --ref parabricks_sample/Ref/Homo_sapiens_assembly38.fasta --in-bam output.bam --out-variants output.vcf --x3 --tmp-dir /uploads/workspace/DUUWMSRM
PARABRICKS Starting...
 CUDA Device Query (Runtime API) version (CUDART static linking)
Detected 1 CUDA Capable device(s), considering 1 device(s)
  CUDA Driver Version / Runtime Version          11.3 / 10.1
Device 0: "NVIDIA Tesla P100-PCIE-16GB"
CUDA Capability Major/Minor version number:    6.0
  Total amount of global memory:                 16281 MBytes (17071734784 bytes)
  (56) Multiprocessors, ( 64) CUDA Cores/MP:     3584 CUDA Cores
  GPU Max Clock rate:                            1329 MHz (1.33 GHz)
  Memory Clock rate:                             715 Mhz
  Memory Bus Width:                              4096-bit
  L2 Cache Size:                                 4194304 bytes
  Maximum Texture Dimension Size (x,y,z)         1D=(131072), 2D=(131072, 65536), 3D=(16384, 16384, 16384)
  Maximum Layered 1D Texture Size, (num) layers  1D=(32768), 2048 layers
  Maximum Layered 2D Texture Size, (num) layers  2D=(32768, 32768), 2048 layers
  Total amount of constant memory:               65536 bytes
  Total amount of shared memory per block:       49152 bytes
  Total number of registers available per block: 65536
  Warp size:                                     32
  Maximum number of threads per multiprocessor:  2048
  Maximum number of threads per block:           1024
  Max dimension size of a thread block (x,y,z): (1024, 1024, 64)
  Max dimension size of a grid size    (x,y,z): (2147483647, 65535, 65535)
  Maximum memory pitch:                          2147483647 bytes
  Texture alignment:                             512 bytes
  Concurrent copy and kernel execution:          Yes with 2 copy engine(s)
  Run time limit on kernels:                     No
  Integrated GPU sharing Host Memory:            No
  Support host page-locked memory mapping:       Yes
  Alignment requirement for Surfaces:            Yes
  Device has ECC support:                        Enabled
  Device supports Unified Addressing (UVA):      Yes
  Device supports Compute Preemption:            Yes
  Supports Cooperative Kernel Launch:            Yes
  Supports MultiDevice Co-op Kernel Launch:      Yes
  Device PCI Domain ID / Bus ID / location ID:   1 / 0 / 0
  Compute Mode:
     < Default (multiple host threads can use ::cudaSetDevice() with device simultaneously) >
deviceQuery, CUDA Driver = CUDART, CUDA Driver Version = 11.3, CUDA Runtime Version = 10.1, NumDevs = 1
Using model for CUDA Capability Major/Minor version number:    60
/usr/local/cuda/.pb/binaries//bin/deepvariant /uploads/workspace/parabricks_sample/Ref/Homo_sapiens_assembly38.fasta /uploads/workspace/output.bam 1 -o /uploads/workspace/output.vcf --model /usr/local/cuda/.pb/binaries//model/60/shortread/deepvariant.eng -n 4 --vsc_min_count_snps 2 --vsc_min_count_indels 2 --vsc_min_fraction_snps 0.12 --min_mapping_quality 5 --min_base_quality 10 --alt_aligned_pileup none --variant_caller VERY_SENSITIVE_CALLER
||                 Parabricks accelerated Genomics Pipeline                 ||
||                              Version v3.5.0                              ||
||                                deepvariant                               ||
||                  Contact: Parabricks-Support@nvidia.com                  ||
Invalid modelFileName /usr/local/cuda/.pb/binaries//model/60/shortread/deepvariant.eng. Exiting...
Please contact Parabricks-Support@nvidia.com for any questions
There is a forum for Q&A as well at https://forums.developer.nvidia.com/c/healthcare/Parabricks/290
Exiting...
Could not run deepvariant
Exiting pbrun ...
where the error is:
Invalid modelFileName /usr/local/cuda/.pb/binaries//model/60/shortread/deepvariant.eng. Exiting…
But it is fine to run pbrun germline (with HaplotypeCaller) or the single standalone tool pbrun haplotypecaller.
$ pbrun haplotypecaller --ref parabricks_sample/Ref/Homo_sapiens_assembly38.fasta \
> --in-recal-file report.txt \
||                              Version v3.5.0                              ||
||                         GPU-GATK4 HaplotypeCaller                        ||
ProgressMeter -	Current-Locus	Elapsed-Minutes	Regions-Processed	Regions/Minute
0 /uploads/workspace/output.bam /uploads/workspace/output.vcf
[03:58:29]	chr1:23827075	0.2	99611	597666
[03:58:39]	chr1:58579359	0.3	248439	745317
[03:58:49]	chr1:103487401	0.5	437443	874886
[03:58:59]	chr1:156993568	0.7	573674	860511
[03:59:09]	chr1:198172788	0.8	747203	896643
[03:59:19]	chr1:235333645	1.0	903616	903616
[04:09:29]	chr22:46147131	11.2	11232255	1005873
[04:09:39]	chrX:85146967	11.3	11560850	1020075
[04:09:49]	chrY:13803548	11.5	11865157	1031752
Total time taken: 701.162
||        Program:                         GPU-GATK4 HaplotypeCaller        ||
||        Version:                                            v3.5.0        ||
||        Start Time:                       Fri Jun 25 03:57:00 2021        ||
||        End Time:                         Fri Jun 25 04:10:00 2021        ||
||        Total Time:                           13 minutes 0 seconds        ||
nvidia-smi info
How can I resolve the deepvariant error?
Hi tsungjung411,
sorry you are having issues.
We are looking into this and will get back to you soon.
Best,
Myrieme
Hi tsungjung411,
We are sorry but Parabricks deepvariant does not support this GPU.
Best,
Myrieme
