When do you expect it to be possible to parameterize complex geometries from the STL Module? Thanks in Advance
Good news! Support for parameterized STL will be available in 22.07 release (about 7-10 days from now). What is your use case?
Wow, that sounds amazing! Will it be possible to optimize the position of an stl object inside another stl object according to certain flow parameters?
