I am unable to run a pipeline with 3D geometry from STL files (even from Modulus examples: Blood Flow in Intracranial Aneurysm).
I get an error when I define the mesh as True (to make it a closed surface):
interior_mesh = Tessellation.from_stl(
point_path + "/aneurysm_closed.stl", airtight=True
But then I get the following error:
And it seems there is an issue with the closed geometry.
Then, I try with False (meaning it would be an open geometry)
And I get an error for it not having any volume.
The machine being used is Dgx1 using redhat8 and I am running it inside a podman container. I am using an official Nvidia container for modulus with version Modulus v22.09. I have access to the GPUs and driver’s version.
I have successfully run other Nvidia examples that don’t involve STL files nor 3D geometries.
Any comment or feedback would be greatly appreciated, thank you for the help!
