I did some investigation and Paraview Omniverse Connector appears to requires more than just the Paraview and the plugin.
The issue from the log file is “Failed to find local Omniverse installations Code 1”
Brad Carvey
Paraview Omniverse Connector Crash
This is a repeatable failure.
Computer information
Windows 11 Enterprise 24H2
NVIDIA 3090 driver 560.94
DirectX runtime version: 12.0
Detailed steps
Ran ParaViewOmniSetup.bat inside folder “paraview-connector-201.1.0.windows-x86_64.release”
Installed without errors.
Ran Paraview 5.12.1 on a Windows 11 computer.
Select disk_out_ref2.ex2 example (upper right) at startup.
Add second layout viewport.
“Create View” clicked “Omniverse Connector”
Omniverse Connector Settings dialog opens. Use defaults and click Create.
36 seconds later Paraview crashes. No errors are displayed.
Paraview Session was created with FullScene.usd and 5 empty folders.
I found a log in the Paraview\OmniverseConnector folder.
· ( 213.924s) [paraview ]pqOmniConnectLauncherCl:102 WARN| Failed to find local Omniverse installations. Code 1
· ( 255.345s) [paraview ]pqOmniConnectSettingsDi:267 INFO| Open view Settings saved
· ( 255.345s) [paraview ]pqOmniConnectSettingsDi:307 INFO| Omniverse Connector View Settings saved
· ( 255.374s) [paraview ]pqOmniConnectViewsSetti:372 INFO| Omniverse Connector View `OmniverseConnector1` created
· ( 255.374s) [paraview ]pqOmniConnectLogger.cxx:33 INFO| { connector_view_settings
· ( 255.374s) [paraview ]pqOmniConnectLogger.cxx:43 INFO| . OmniServer = localhost
· ( 255.374s) [paraview ]pqOmniConnectLogger.cxx:43 INFO| . OmniWorkingDirectory =
· ( 255.374s) [paraview ]pqOmniConnectLogger.cxx:43 INFO| . LocalOutputDirectory = D:/Paraview_Sessions
· ( 255.374s) [paraview ]pqOmniConnectLogger.cxx:51 INFO| . OutputLocal = true
· ( 255.374s) [paraview ]pqOmniConnectLogger.cxx:51 INFO| . CreateNewOmniSession = true
· ( 255.374s) [paraview ]pqOmniConnectLogger.cxx:51 INFO| . OutputBinary = true
· ( 255.374s) [paraview ]pqOmniConnectLogger.cxx:43 INFO| . UpAxis = Y
· ( 255.374s) [paraview ]pqOmniConnectLogger.cxx:51 INFO| . UsePointInstancer = true
· ( 255.375s) [paraview ]pqOmniConnectLogger.cxx:51 INFO| . UseStickLines = false
· ( 255.375s) [paraview ]pqOmniConnectLogger.cxx:51 INFO| . UseStickWireframe = true
· ( 255.375s) [paraview ]pqOmniConnectLogger.cxx:51 INFO| . UseMeshVolume = false
· ( 255.375s) [paraview ]pqOmniConnectLogger.cxx:51 INFO| . ShowOmniErrors = true
· ( 255.375s) [paraview ]pqOmniConnectLogger.cxx:51 INFO| . ShowOmniDebug = false
· ( 255.375s) [paraview ]pqOmniConnectLogger.cxx:47 INFO| . NucleusVerbosity = 0
· ( 255.375s) [paraview ]pqOmniConnectLogger.cxx:47 INFO| . No. Partitions = 1
· ( 255.375s) [paraview ]pqOmniConnectLogger.cxx:47 INFO| . Session No. = 5
· ( 255.375s) [paraview ]pqOmniConnectLogger.cxx:33 INFO| } 0.000 s: connector_view_settings
