Passing a procedure(*) argument to another subroutine
Hi everyone
I am tryingto pass a subroutine f() as an argument to subroutine a() and then to b()
   call a(f)
subroutine a(f)
     procedure(sub) :: f
     call b(f)
end subroutine
subroutine b(f)
     procedure(sub) :: f
     call f()
end subroutine
but if fails with
PGF90-S-0448-Argument number 1 to b must be a subroutine name (r.f90: 24)
ifort and gfortran compile and run just fine.
Am I missing anything?
Thanks a lot,
Ionut
Here is a full code to play with:
  module m
      abstract interface
        subroutine sub(i)
            integer :: i
        end subroutine
    end interface
contains
    subroutine c(i)
        integer :: i
        print *, 'F was called with i=', i
    end subroutine
end module
program r
        use m
        call a(c)
contains
    subroutine a(f)
        procedure(sub) :: f
        print *, 'A calling B'
        call b(f)
    end subroutine
    subroutine b(f)
        procedure(sub) :: f
        print *, 'B calling F'
        call f(5)
    end subroutine
end program
Hi ionutg,
I passed this on to our compiler engineers and they determined that it is a compiler error. We have create TPR#18543 to track this issue.
Thanks for the report!
Mat
TPR 18543 - Error should not be detected for passing a procedure dummy argument
was corrected in our 12.10 release. A late update for you.
dave
