Patching JetPack 4.3 for PCN211181 (DRAM change)
Will it be possible to patch older JetPack versions (like 4.3) with the required changes to support PCN211181?
Is migration to the new JetPack version generally expected or is there a planned route for users on prior versions?
Thank you for your assistance
Sorry that we’re not able to support on that JetPack 4.3 for PCN211181.
Thanks for the response.
would you or anyone here be able to share any perspectives or experiences with this, is this effectively impossible to patch in to older JetPacks or is there likely some solution that can be found with enough tinkering?
main concern is with running into problems testing integration with libargus that I experienced on an older version of JetPack 4.6.
We would suggest upgrade to r32.7.5. But you may try the overlay package for older Jetpack version:
Jetson Linux R32.7.5 | NVIDIA Developer
Additional Files
Overlay_PCN211181_r32.7.5.tbz2
