Can I upgrade my Jetson nano to the latest release (4.3 version) using the below commands?
sudo apt-get update
sudo apt-get install nvidia-jetpack"
Current version is,
jetbot@jetbot:~$ cat /etc/nv_tegra_release
R32 (release), REVISION: 1.0, GCID: 14531094, BOARD: t210ref, EABI: aarch64, DATE: Wed Mar 13 07:46:13 UTC 2019
Regards,
Shankar
Hi Shankar, you need to re-flash your SD card with JetPack 4.3 image to upgrade to JetPack 4.3, so be sure to backup any files you wish to keep before re-flashing, as your SD card will be reset during the process. Future updates to JetPack will be delivered via the APT server, so once on JetPack 4.3 you will be able to update from the command line without re-flashing. However upgrading to JetPack 4.3 from a previous version requires a re-flash.
