Hello everyone,
Sorry for the question, but I try to download the JetPack tool (ver 4.2.2) for jetson nano and in this link: JetPack SDK | NVIDIA Developer I can not find the download …
The only links that exist here, are the image and the sdk manager.
By the way, using the sdk manager I was unable to install the jetpack.
In older versions of jetpack, for instance : 3.3 in here: JetPack Archive | NVIDIA Developer
there is a download link, but nano is not supported.
Where I can find this tool ?
Thanks very much !
kayccc
September 10, 2019, 11:25pm
2
There is a way to update JetPack in Jetson Nano without create a new sd card image ?
I don’t want lose all my setups.
I already try install SDK Manager bit it is for AMD64 not ARM64 and can’t install.
gtj
September 17, 2019, 7:39pm
4
If you download and extract the latest Linux for Tegra (32.2.1), you should be able to grab the deb package files and manually upgrade.
Linux_for_Tegra/bootloader/nvidia-l4t-bootloader_32.2.1-20190812212815_arm64.deb
Linux_for_Tegra/bootloader/21104/nvidia-l4t-bootloader_32.2.1-20190812212815_arm64.deb
Linux_for_Tegra/nv_tegra/l4t_deb_packages/nvidia-l4t-3d-core_32.2.1-20190812212815_arm64.deb
Linux_for_Tegra/nv_tegra/l4t_deb_packages/nvidia-l4t-gstreamer_32.2.1-20190812212815_arm64.deb
Linux_for_Tegra/nv_tegra/l4t_deb_packages/nvidia-l4t-firmware_32.2.1-20190812212815_arm64.deb
Linux_for_Tegra/nv_tegra/l4t_deb_packages/nvidia-l4t-configs_32.2.1-20190812212815_arm64.deb
Linux_for_Tegra/nv_tegra/l4t_deb_packages/nvidia-l4t-ccp-t210ref_32.2.1-20190812212815_arm64.deb
Linux_for_Tegra/nv_tegra/l4t_deb_packages/nvidia-l4t-apt-source_32.2.1-20190812212815_arm64.deb
Linux_for_Tegra/nv_tegra/l4t_deb_packages/nvidia-l4t-wayland_32.2.1-20190812212815_arm64.deb
Linux_for_Tegra/nv_tegra/l4t_deb_packages/nvidia-l4t-weston_32.2.1-20190812212815_arm64.deb
Linux_for_Tegra/nv_tegra/l4t_deb_packages/nvidia-l4t-tools_32.2.1-20190812212815_arm64.deb
Linux_for_Tegra/nv_tegra/l4t_deb_packages/nvidia-l4t-xusb-firmware_32.2.1-20190812212815_arm64.deb
Linux_for_Tegra/nv_tegra/l4t_deb_packages/nvidia-l4t-core_32.2.1-20190812212815_arm64.deb
Linux_for_Tegra/nv_tegra/l4t_deb_packages/nvidia-l4t-cuda_32.2.1-20190812212815_arm64.deb
Linux_for_Tegra/nv_tegra/l4t_deb_packages/nvidia-l4t-x11_32.2.1-20190812212815_arm64.deb
Linux_for_Tegra/nv_tegra/l4t_deb_packages/nvidia-l4t-oem-config_32.2.1-20190812212815_arm64.deb
Linux_for_Tegra/nv_tegra/l4t_deb_packages/nvidia-l4t-camera_32.2.1-20190812212815_arm64.deb
Linux_for_Tegra/nv_tegra/l4t_deb_packages/nvidia-l4t-multimedia-utils_32.2.1-20190812212815_arm64.deb
Linux_for_Tegra/nv_tegra/l4t_deb_packages/nvidia-l4t-graphics-demos_32.2.1-20190812212815_arm64.deb
Linux_for_Tegra/nv_tegra/l4t_deb_packages/nvidia-l4t-init_32.2.1-20190812212815_arm64.deb
Linux_for_Tegra/nv_tegra/l4t_deb_packages/nvidia-l4t-multimedia_32.2.1-20190812212815_arm64.deb
Linux_for_Tegra/kernel/nvidia-l4t-kernel-headers_4.9.140-tegra-32.2.1-20190812212815_arm64.deb
Linux_for_Tegra/kernel/nvidia-l4t-kernel_4.9.140-tegra-32.2.1-20190812212815_arm64.deb
Linux_for_Tegra/kernel/nvidia-l4t-kernel-dtbs_4.9.140-tegra-32.2.1-20190812212815_arm64.deb
WARNING: I haven’t actually tried this but it should work.
