软件环境:36.3
硬件:自定义载板,jeston agx orin 32G/64GB核心板
pcie设计:使用pcie UPHY1 接 I350-AM4网卡
板卡信息如下:
root@ubuntu:~# cat /proc/version
Linux version 5.15.136-rt-tegra (dev@8e8fbb755e79) (aarch64-buildroot-linux-gnu-gcc.br_real (Buildroot 2022.08) 11.3.0, GNU ld (GNU Binutils) 2.38) #1 SMP PREEMPT_RT Fri May 9 06:12:11 UTC 2025
Uphy配置为默认配置
ODMDATA=“gbe-uphy-config-22,hsstp-lane-map-3,nvhs-uphy-config-0,hsio-uphy-config-0,gbe0-enable-10g”; CHIPID=0x23; ITS_FILE=; OVERLAY_DTB_FILE=“L4TConfiguration.dtbo,tegra234-p3701-overlay.dtbo”; CMDLINE_ADD=“mminit_loglevel=4 console=ttyTCU0,115200 console=ttyAMA0,115200 firmware_class.path=/etc/firmware fbcon=map:0 net.ifnames=0 nospectre_bhb video=efifb:off console=tty0” target_board=“generic”;
可以通过lspci看到PCIE 网卡已被加载
root@ubuntu:~# lspci
0001:00:00.0 PCI bridge: NVIDIA Corporation Device 229e (rev a1)
0005:00:00.0 PCI bridge: NVIDIA Corporation Device 229a (rev a1)
0005:01:00.0 Ethernet controller: Intel Corporation I350 Gigabit Network Connection (rev 01)
0005:01:00.1 Ethernet controller: Intel Corporation I350 Gigabit Network Connection (rev 01)
0005:01:00.2 Ethernet controller: Intel Corporation I350 Gigabit Network Connection (rev 01)
0005:01:00.3 Ethernet controller: Intel Corporation I350 Gigabit Network Connection (rev 01)
可以看到当前已经降为gen1速率
root@ubuntu:~# lspci -vvv | grep LnkSta
LnkSta: Speed 2.5GT/s (ok), Width x4 (downgraded)
LnkSta2: Current De-emphasis Level: -3.5dB, EqualizationComplete- EqualizationPhase1-
LnkSta: Speed 2.5GT/s (downgraded), Width x4 (ok)
LnkSta2: Current De-emphasis Level: -6dB, EqualizationComplete- EqualizationPhase1-
dts文件配置如下,配置为gen1
pcie@141a0000{ vpcie3v3-supply = <&vdd_3v3_i350>; /delete-property/ vpcie12v-supply; max-link-speed = <0x1>; };
lspci -vvv 详细信息如下:
lspci-vvv-show-log.txt (21.8 KB)
开机log如下:
当PCIE配置速录为gen1时候,有少许PCIE BUS Error 报错,LOG如下
PCIE BUS Err Gen1.txt (184.8 KB)
当PCIE配置速录为gen2
的时候,会有大量PCIE BUS Error报错, 导致死机重启,无法进入登录界面, LOG 如下
sku2_pcie_bus_err_32g_pcle_gen2_core_dump.txt (261.5 KB)
