"pcie failed to prase device tree" using default UPHY1 and pcie config
Software Version
DRIVE OS 6.0.8.1
[*] DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
[*] Linux
QNX
other
Hardware Platform
[*] DRIVE AGX Orin Developer Kit (940-63710-0010-200)
other
SDK Manager Version
1.9.3.10904
[*] other
Host Machine Version
[*] native Ubuntu Linux 20.04 Host installed with SDK Manager
other
I find the default UPHY1 and pcie config as below:
1、using the default config, have error log :
tegra194-pcie 141a0000.pcie: Failed to parse device tree: -517
tegra194-pcie 141c0000.pcie_ep: Failed to parse device tree: -517
2、In document “Jetson_AGX_Orin_Series_Design_Guide_DG-10653-001_v1.6.pdf” and " Jetson AGX Orin Platform Adaptation and Bring-Up — Jetson Linux Developer Guide documentation (nvidia.com) " there is no 4 lane config option for UPHY1:
3、So, is the default 4 lane config for UPHY1 to pcie correct ? In this develop kit (DRIVE AGX Orin Developer Kit (940-63710-0010-200)) and SDK (DRIVE OS 6.0.6 & Linux) can config UHPY1 to 2 pcie 4 lane,if yes or not, how to modify?
Dear @huangxx8,
May I know when you notice this issue like flashing or compilation?. Did you make any changes or noticed issue with default files in DRIVE OS?
1、We want to use “nvscistream_event_sample” to test nvscic2c_pcie function, I follow " Chip to Chip Communication | NVIDIA Docs " when excute “sudo modprobe nvscic2c-pcie-epc” or “sudo modprobe nvscic2c-pcie-epf” there is no extra pcie log out
2、form the error log “tegra194-pcie 141a0000.pcie: Failed to parse device tree: -517” I think the driver is not ready, so i want to know is the default config correct?
3、There is’t any changes and I can’t find the default UPHY1 config in document “Jetson_AGX_Orin_Series_Design_Guide_DG-10653-001_v1.6.pdf” and " Jetson AGX Orin Platform Adaptation and Bring-Up — Jetson Linux Developer Guide documentation (nvidia.com) "
Dear @huangxx8,
Just to confirm is this error noticed in bootlog or running modprobe or nvscistream event sample?
In bootlog, running modprobe or nvscistream event sample have no extra pcie log out
I don’t see any such log using DRIVE OS 6.0.8.1
nvidia@tegra-ubuntu:~$ sudo modprobe nvscic2c-pcie-epf
nvidia@tegra-ubuntu:~$ sudo modprobe nvscic2c-pcie-epc
The above error is not notice in 6.0.8.1 bootlog.
Is it possible to test on 6.0.8.1?
I want to know is there the same error in SDK 6.0.6 on your side, Do you have test nvscic2c-pcie function in SDK 6.0.6? If same error and nvscic2c-pcie can not running OK, I will try to test on 6.0.8.1
Dear @huangxx8,
Currently, I have 6.0.8.1 flashed on target and unfortunately I don’t have c2c use case test setup for quick checking.
Dear @huangxx8 ,
May I know the used command for nvscistream event sample?
I use the sample in drive-linux/samples/ncsci/nvscistream/event, in README.txt, the command:
Hi SivaRamaKrishnaNV,
Any update for this?
Dear @huangxx8,
As I don’t have 2 P3710, I had used only one p3710 as PCIE master and slave. I connected the miniSAS cable port-A to miniSAS port-B in 1 P3710s. Followed the steps from Chip to Chip Communication | NVIDIA Docs
I could run nvscistream event sample
#Run on Devkit 1 Terminal
[sudo] password for nvidia:
#Run below steps on  Devkit2 terminal if you have connected two devkits
nvidia@tegra-ubuntu:~$ sudo -s
root@tegra-ubuntu:/home/nvidia# cd /sys/kernel/config/pci_ep/
root@tegra-ubuntu:/sys/kernel/config/pci_ep# mkdir functions/nvscic2c_epf_22CC/func
root@tegra-ubuntu:/sys/kernel/config/pci_ep# echo 0x10DE > functions/nvscic2c_epf_22CC/func/vendorid
root@tegra-ubuntu:/sys/kernel/config/pci_ep# echo 0x22CC > functions/nvscic2c_epf_22CC/func/deviceid
root@tegra-ubuntu:/sys/kernel/config/pci_ep# ln -s functions/nvscic2c_epf_22CC/func controllers/141c0000.pcie_ep
root@tegra-ubuntu:/sys/kernel/config/pci_ep# echo 0 > controllers/141c0000.pcie_ep/start
root@tegra-ubuntu:/sys/kernel/config/pci_ep# echo 1 > controllers/141c0000.pcie_ep/start
root@tegra-ubuntu:/sys/kernel/config/pci_ep# lspci
0005:00:00.0 PCI bridge: NVIDIA Corporation Device 229a (rev a1)
0005:01:00.0 Serial controller: NVIDIA Corporation Device 22cc
0007:00:00.0 PCI bridge: NVIDIA Corporation Device 229a (rev a1)
0007:01:00.0 Ethernet controller: Microchip Technology / SMSC Device 7431 (rev 11)
root@tegra-ubuntu:/sys/kernel/config/pci_ep# ls /dev/nvsci*
/dev/nvscic2c_pcie_s0_c5_1   /dev/nvscic2c_pcie_s0_c5_5   /dev/nvscic2c_pcie_s0_c6_11  /dev/nvscic2c_pcie_s0_c6_7
/dev/nvscic2c_pcie_s0_c5_10  /dev/nvscic2c_pcie_s0_c5_6   /dev/nvscic2c_pcie_s0_c6_12  /dev/nvscic2c_pcie_s0_c6_8
/dev/nvscic2c_pcie_s0_c5_11  /dev/nvscic2c_pcie_s0_c5_7   /dev/nvscic2c_pcie_s0_c6_2   /dev/nvscic2c_pcie_s0_c6_9
/dev/nvscic2c_pcie_s0_c5_12  /dev/nvscic2c_pcie_s0_c5_8   /dev/nvscic2c_pcie_s0_c6_3   /dev/nvsciipc
/dev/nvscic2c_pcie_s0_c5_2   /dev/nvscic2c_pcie_s0_c5_9   /dev/nvscic2c_pcie_s0_c6_4
/dev/nvscic2c_pcie_s0_c5_3   /dev/nvscic2c_pcie_s0_c6_1   /dev/nvscic2c_pcie_s0_c6_5
/dev/nvscic2c_pcie_s0_c5_4   /dev/nvscic2c_pcie_s0_c6_10  /dev/nvscic2c_pcie_s0_c6_6
root@tegra-ubuntu:/sys/kernel/config/pci_ep# exit
exit
#Devkit 1 terminal
nvidia@tegra-ubuntu:~$ ./nvscistream_event_sample -P 0 nvscic2c_pcie_s0_c5_1 -Q 0 f
Producer setup completed
Producer finished sending 32 payloads
#Devkit 2 terminal
nvidia@tegra-ubuntu:~$ ./nvscistream_event_sample -C 0 nvscic2c_pcie_s0_c6_1 -F 0 3
Consumer setup completed
Consumer disconnected after receiving 32 payloads
Note: I had used only 1 P3710 in my test. So I ran all commands on same p3710.
图像
may be we use the wrong Mini-SAS cable,we will use the supported cables late and update.
