Currently we are using a custom carrier board with an external Quectel RM520N 5G module via PCIe C1, the device tree is as follows:
output_agx.txt (317.1 KB)
Currently meeting the timing requirements of the 5G module, PCIe devices can be scanned. The 5G module responded to the MSI interrupt sent by AGX and replied, but it seems that AGX did not receive the response.
Hardware question: The AGX has only one PCIe_WAKE pin. Is it possible to connect multiple devices to it? we have NVME and 5G module.
tegra-ubuntu:~$ sudo cat /proc/interrupts | grep MSI
239: 22 0 0 0 0 0 0 0 0 0 0 0 PCI-MSI 537395200 Edge nvme0q0
240: 17219 0 0 0 0 0 0 0 0 0 0 0 PCI-MSI 537395201 Edge nvme0q1
241: 19865 0 0 0 0 0 0 0 0 0 0 0 PCI-MSI 537395202 Edge nvme0q2
242: 22818 0 0 0 0 0 0 0 0 0 0 0 PCI-MSI 537395203 Edge nvme0q3
243: 18634 0 0 0 0 0 0 0 0 0 0 0 PCI-MSI 537395204 Edge nvme0q4
244: 5410 0 0 0 0 0 0 0 0 0 0 0 PCI-MSI 537395205 Edge nvme0q5
245: 4597 0 0 0 0 0 0 0 0 0 0 0 PCI-MSI 537395206 Edge nvme0q6
246: 4044 0 0 0 0 0 0 0 0 0 0 0 PCI-MSI 537395207 Edge nvme0q7
247: 4326 0 0 0 0 0 0 0 0 0 0 0 PCI-MSI 537395208 Edge nvme0q8
263: 0 0 0 0 0 0 0 0 0 0 0 0 PCI-MSI 134742016 Edge mhi
0001:01:00.0 Unassigned class [ff00]: Qualcomm Device 0308
Subsystem: Qualcomm Device 5201
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0, Cache Line Size: 64 bytes
Interrupt: pin ? routed to IRQ 263
IOMMU group: 5
Region 0: Memory at 20a8000000 (64-bit, non-prefetchable) [size=4K]
Region 2: Memory at 20a8001000 (64-bit, non-prefetchable) [size=4K]
Capabilities: [40] Power Management version 3
Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0+,D1-,D2-,D3hot+,D3cold+)
Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=0 PME-
Capabilities: [50] MSI: Enable+ Count=1/32 Maskable+ 64bit+
Address: 00000000fffff950 Data: 0000
Masking: fffffffe Pending: 00000000
Capabilities: [70] Express (v2) Endpoint, MSI 00
DevCap: MaxPayload 256 bytes, PhantFunc 0, Latency L0s unlimited, L1 unlimited
ExtTag- AttnBtn- AttnInd- PwrInd- RBE+ FLReset- SlotPowerLimit 0.000W
DevCtl: CorrErr- NonFatalErr- FatalErr- UnsupReq-
RlxdOrd+ ExtTag- PhantFunc- AuxPwr- NoSnoop+
MaxPayload 128 bytes, MaxReadReq 512 bytes
DevSta: CorrErr- NonFatalErr- FatalErr- UnsupReq- AuxPwr+ TransPend-
LnkCap: Port #0, Speed 16GT/s, Width x2, ASPM L0s L1, Exit Latency L0s <1us, L1 <64us
ClockPM- Surprise- LLActRep- BwNot- ASPMOptComp+
LnkCtl: ASPM Disabled; RCB 64 bytes, Disabled- CommClk+
ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
LnkSta: Speed 8GT/s (downgraded), Width x1 (downgraded)
TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
DevCap2: Completion Timeout: Range ABCD, TimeoutDis+ NROPrPrP- LTR+
10BitTagComp+ 10BitTagReq- OBFF Not Supported, ExtFmt- EETLPPrefix-
EmergencyPowerReduction Not Supported, EmergencyPowerReductionInit-
FRS- TPHComp+ ExtTPHComp-
AtomicOpsCap: 32bit- 64bit- 128bitCAS-
DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis- LTR+ OBFF Disabled,
AtomicOpsCtl: ReqEn-
LnkCap2: Supported Link Speeds: 2.5-16GT/s, Crosslink- Retimer+ 2Retimers+ DRS-
LnkCtl2: Target Link Speed: 8GT/s, EnterCompliance- SpeedDis-
Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
Compliance De-emphasis: -6dB
LnkSta2: Current De-emphasis Level: -6dB, EqualizationComplete+ EqualizationPhase1+
EqualizationPhase2+ EqualizationPhase3+ LinkEqualizationRequest-
Retimer- 2Retimers- CrosslinkRes: Upstream Port
Capabilities: [100 v2] Advanced Error Reporting
UESta: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UEMsk: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UESvrt: DLP+ SDES+ TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
CESta: RxErr- BadTLP- BadDLLP- Rollover- Timeout- AdvNonFatalErr-
CEMsk: RxErr- BadTLP- BadDLLP- Rollover- Timeout- AdvNonFatalErr+
AERCap: First Error Pointer: 00, ECRCGenCap+ ECRCGenEn- ECRCChkCap+ ECRCChkEn-
MultHdrRecCap- MultHdrRecEn- TLPPfxPres- HdrLogCap-
HeaderLog: 00000000 00000000 00000000 00000000
Capabilities: [148 v1] Secondary PCI Express
LnkCtl3: LnkEquIntrruptEn- PerformEqu-
LaneErrStat: 0
Capabilities: [168 v1] Physical Layer 16.0 GT/s <?>
Capabilities: [18c v1] Lane Margining at the Receiver <?>
Capabilities: [19c v1] Transaction Processing Hints
No steering table available
Capabilities: [228 v1] Latency Tolerance Reporting
Max snoop latency: 0ns
Max no snoop latency: 0ns
Capabilities: [230 v1] L1 PM Substates
L1SubCap: PCI-PM_L1.2+ PCI-PM_L1.1+ ASPM_L1.2+ ASPM_L1.1+ L1_PM_Substates+
PortCommonModeRestoreTime=70us PortTPowerOnTime=0us
L1SubCtl1: PCI-PM_L1.2- PCI-PM_L1.1- ASPM_L1.2- ASPM_L1.1-
T_CommonMode=0us LTR1.2_Threshold=98304ns
L1SubCtl2: T_PwrOn=40us
Capabilities: [240 v1] Data Link Feature <?>
Kernel driver in use: mhi_q
Kernel modules: pcie_mhi
AGX log:
dmesg.txt (87.3 KB)
5G module log:
modem.txt (396.4 KB)
