PCIe legacy interrupts not working with L4T 35.1
I am using a capture card on my Xavier that requires the use of legacy PCIe interrupts. The card is behind a Diodes Inc. PI7C9X2G608GP PCIe switch. The card worked fine on all of the L4T 32.x versions with kernel 4.9 but does not work on kernel 5.10. If I direct connect the card it works so it seems to have something to do with the switch. The card vendor tried it on another test system that uses a Broadcom PCIe switch and it worked for them.
I can see in /proc/interrupts that the irq never gets triggered and the system will completely lock up after closing mplayer with nothing printed to dmesg.
By the look of things there have been pretty significant changes to PCI interrupt mapping code between kernel 4.9 and 5.10 so I suspect that to be the cause but I don’t know how to actually fix it.
My current understanding is that the Jetson PCie controller only supports INTa and that PCIe switches swizzle INTA-INTD depending on the port in use. My best guess at what is happening is that INTA from the card is getting mapped to one of the other INTx that does not exist, but that doesn’t explain how it worked with 4.9
Sorry for the late response, is this still an issue to support? Thanks
This can be closed. The issue appears to be something else other than interrupts.
What kind of “something else” is that? Could you share it?
The post you sent me seems to have similar symptoms but I had the card vendor add MSI support to their driver and I can see that they register properly in /proc/interrupts. It still doesnt work though. I also tried a number of other capture cards and they all worked fine. Looking at the driver source all of the working cards handled buffer allocation on their own with dma_alloc_coherent(). My non-working driver relies on V4L2 to supply the buffers for DMA so I think it is either pointing to non-dma accessible memory or the PCIe switch is somehow interfering with the address mapping. I cant share the whole driver source code but here is the relevant dma address section:
#if LINUX_VERSION_CODE >= KERNEL_VERSION(4,4,0)
	 addr=vb2_dma_contig_plane_dma_addr(&buf->vb.vb2_buf, 0);
	 size=vb2_plane_size(&buf->vb.vb2_buf, 0);
#else
	 addr=vb2_dma_contig_plane_dma_addr(&buf->vb, 0);
	 size=vb2_plane_size(&buf->vb, 0);
#endif
	ng_write(NG_REG_BUFF_ADDR_L(buf->hw_buff_id), (addr & 0xffffffff));
	ng_write(NG_REG_BUFF_ADDR_H(buf->hw_buff_id), ((addr>>32) & 0xffffffff));
	ng_write(NG_REG_BUFF_SIZE(buf->hw_buff_id), size);
