Dear Sir:
We happen PCIE NVMe SSD compatibility issues, can you tell me this error message mean?
You will probably want to post the result of this for more details on the error:
sudo lspci -vvv
Also:
dmesg | egrep -i pci
Yes. Please share the outputs of ‘sudo lspci -vvvv’ and ‘dmesg | egrep -i pci’
Also, please try disabling ASPM (Active State Power Management) and update your observations.
- Disabling ASPM can be achieved in the following ways for a platform
- Disabling from the beginning
- Appending ‘pcie_aspm=off’ to the kernel command line
- Removing “CONFIG_PCIEASPM_POWERSAVE=y” and setting “CONFIG_PCIEASPM_PERFORMANCE=y” in the kernel configuration
- Disabling after system boots to console
- Executing the below command once the system boots to console
- echo “performance” > /sys/module/pcie_aspm/parameters/policy
Hi jerry577577,
Have you tried the suggestion we mentioned above?
Please update the status then can move this issue forward.
