I have selected the part LAN7430, PCIe to Gigabit ethernet bridge. PCIe version supported in this part is PCIe 3.1.
Will TX2 be able to support this part? What will be maximum data rate of the ethernet that can be achieved in this case?
Added note: PCIe revisions 1 and 2 are supported. Anything revision 3 will simply reduce back to a gen. 1 or 2 speed. Even gen. 1 (revision 1) supports 2.5GT/s (after 8b/10b encoding, but not including other overhead, this means a single lane of revision 1 supports 2Gb/s…revision 2 is twice as fast as revision one). Basically a single lane at the slowest speed would support a single gigabit. I do not know how the bridge would set up (it isn’t a typical PCIe endpoint device) at the non-Jetson end, but it might show as only achieving revision 2 speeds (or even revision 1), but regardless of this the speed exceeds gigabit requirements.
