PDT: KIND and LEN type parameters are mutually exclusive
The following invalid code is erroneously accepted by nvfortran 21.9 and earlier:
  type :: bad_pdt (k,l)
     integer, kind, len      :: k = 1
     integer, len, kind      :: l = 1
     character(kind=k,len=l) :: c
  end type bad_pdt
end
The Fortran 2018 standard (and similarly earlier versions down to 2003) state:
F2018: 7.5.3.1  Type parameter definition statement
R732  type-param-def-stmt is
      integer-type-spec, type-param-attr-spec :: type-param-decl-list
R734  type-param-attr-spec  is KIND or LEN
(3) The type-param-attr-spec explicitly specifies whether a type parameter is a kind parameter or a length parameter.
Thus the KIND and LEN attributes are mutually exclusive.
The correct solution would be to reject the code sample.
Thanks,
Harald
Thanks Harald. I filed a problem report, TPR #30827, and sent it to engineering for further review.
-Mat
As of our 25.7 release, we now emit the following error message:
% nvfortran -V25.7 -c test.f90
NVFORTRAN-S-1293-Type parameter attribute can either be KIND or LEN, not both (test.f90: 2)
NVFORTRAN-S-1293-Type parameter attribute can either be KIND or LEN, not both (test.f90: 3)
  0 inform,   0 warnings,   2 severes, 0 fatal for MAIN
